Question about Sewing Machines
Rimoldi industrial serger
Adjust stitch length
  • 3 Answers
SOURCE: How do you adjust the stitch length on Consew 226 R-1?
if it is like the other industrial machines I've used, here is the general principle:
On the machine there is a button with no label. Hold button while turning the handwheel toward you. When you feel the button depressl you can adjust the length. Hold the button in the machine and crank the hand wheel back to decrease the length of ths titch and foward to increase it. I usually put a notch on the fly wheel for my standard length with some nailpolish. Release the button and sew to test the length.
Posted on Jun 16, 2009
Mimito7
  • 128 Answers
SOURCE: Consew Industrial Machine 2270 stitch length dial not working
Sounds like it is either out of time or the adjuster spring needs to be replaced.
Posted on Apr 19, 2009
SOURCE: Pfaff 463 Industrial Sewing Machine needs Hook & Needle Re-Timing
ne sece konac
Posted on Dec 20, 2009
SOURCE: The stitch length adjustment will not switch the length
since the dial won't move, the machine needs to be checked
Posted on May 29, 2012
  • 1564 Answers
SOURCE: industrial serger needs oil drained
That might be a good question for the manufacturer. They are still in business.
http://www.pegasusofamerica.com/index.html
Posted on Jul 20, 2012
Threading diagram for rimoldi 3 thread serger model 627
Rimoldi Serger Manual PDF And Ebook Files - DocsFiles
docsfiles.com/pdf_rimoldi_serger_manual.html
Rimoldi Serger Manual PDF Files, Manual For Rimoldi Serger honda nx 250 service ... Manual FREE Parts Crochet - Loopers RIMOLDI 8 8 Kl 327 , 527 , 627 , F27 ...Rimoldi Serger Manual Rimoldi B.27.77 Industrial Serger, 3-Thread, Nov 26, ...
rimoldi 329 threading diagram Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your rimoldi 329 threading diagram question. ... Rimoldi orion 627... rimoldi overlocker how to thread Which Model Rimoldi? ... Level 3 Expert.
rimoldi pdf - P(1) - Docs-Engine.com
Feb 05, 2016 | Sewing Machines
I need to adjust my baby lock and just can not understand how it works,the tension Dial with the Blue,Green,Orange,Yellow and purple, What is the right tension for light weight Fabric for the side sea
Try setting up your machine with the 4 different thread colors as the guide--use yellow thread in the yellow guide, blue in the blue, etc. This is a good way to figure out what is not working with your tension dials. To start out with a 4-thread stitch, set the tension dials at the midway point on each and then test your stitch. You should be able to see which thread colors are off. If one color is wrapping over the edge of the fabric, then that tension is too loose and the opposite thread may be too tight. The tensions are correct when the threads meet in the middle of the fabric. It's a matter of sitting down and playing with it to see what happens when you make changes to the settings. Also, one particular setting that works on a particular fabric may not work on another, so learning how to test and adjust is a big part of using a serger.
As for stitch length, that is mostly a personal decision. The shorter the stitch length, the closer the stitches will be.
The anatomy of perfect serger tension Sew McCool
Serger Tension Made Easy Do It Better Yourself Club
There are many web sites and videos that could be helpful.
Feb 10, 2018 | Sewing Machines
Rimoldi serger Hi I have a 629 Rimoldi serger and
I have a Rimoldi 629 and to rethread the back part with the tube ...
you take of the front of the thread plate there is 2 screws...
then look down the left hand side you will see a dial ...
you need to take the 2 or 3 screws out of that panel and the dial actually holds it on just undo the dial a bit ...
you need to get some wire and thread it through the tube ... when it reaches the end of the tube make a tiny loop so that when you thread the back tension disk you can pull the thread through the tube ....
i have the proper threading guide if anyone need it
My email address is Richardjames1985@hotmail.com just email me and i will send it to you
Hope this all makes sense thanks
Richard james
Aug 07, 2013 | Sewing Machines
How do I adjust the stitch length on my Juki DDL 552?
hello, i recently purchased an old juki ddl-552, and it don't have a stitch locater, and a reverse button! how do i adjust the stitch length ??? thanks
May 31, 2013 | Ludwig LG8B2 Industrial Sewing Machine
How do I adjust the stitch length on a Janome "My Lock" 234?
Is there a dial on the right above the flywheel? This is where you adjust the stitch length on most sergers. It might be numbered from 0 to 5 or 4.
If it has differential feed, there would be a dial there for this too, possibly under the stitch length knob - it would have numbers like -1, -0.5, 0, 0.5 and 1 on it.
If you are new to sergers/overlockers I highly recommend a class, demonstration or investing in a good book to get you started as they are not like sewing machines and many of the techniques are best demonstrated such as rolled thread edging and flat lock seams.
I've borrowed he Singer book "Sewing with an overlocker", or "Serge with Confidence" by Nancy Zieman from my library but there would be other titles too.
Apr 13, 2011 | Janome 2049LX Mechanical Sewing Machine
How do I change the stitch length in my Juki LU 563
hi there
the graduation of the stitch length is marked on the feed graduation plate attached t the main shaft,to adjust the stitch length rotate the hand wheel slowly as you keep pressing the push - button stop the bed until the tip of the push- button enter groove of the accentric mechanism, when it is entered rotate the hand wheel eigher towards you or away from you as you keep pressing the push - button until the desired stitch length indicating mark on the graduation plate appears on the hole of arm. when appear release the push - button and check stitch length.
BEST REGARDS
AHRAF ABOZID
CAIRO - EGYPT
Apr 02, 2011 | Ludwig LG8B2 Industrial Sewing Machine
How to adjust stitch width on babyloc eclipse lx serger
Here is the info about this serger from the baby lock's website. It says the stitch length is a dial. I couldn't find the manual for download, but they say they stand behind their products with support. I would follow the customer support link at the bottom of the page and request a user manual. It looks like they sell an instuctional video and optional workbook too. Might be worth the price to help you get the most out of your seger. Hope this helps!
http://www.babylock.com/sergers/previous-models/eclipse-lx/
Feb 04, 2010 | Baby Lock Eclipse Serger
I was given a Huskylock 430 serger and need to know if someone can tell me the correct tensions.
There are really not any #s you can set to give a good stitch. You have to just use the #s as a guide. Most sergers from the factory will give you something decent around 4 across the board. Start there and make slight adjustments as needed. It also depends on the stitch and type of material used.
Aug 17, 2009 | Sewing Machines
Mar 14, 2009 | Sewing Machines
Sewing Machines Logo
65 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
