Dacor Epicure ERD36 Dual Fuel  Kitchen Range
Problem for Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen...
Oven door won't open
By sytiff on Aug 11, 2007
Hi -
My husband tried to use the self-cleaning feature in our new home's oven, but turned it off before it finished. Since then, the door will not open (I moved it manually, but then when I shut it, the door still latches shut and won't open). It is a Kenmore range with the model #362.75571691.
Thanks in advance for your help!
Same Problem
Feb 27, 2008
-   I have a Kenmore oven but i dont know what model, the problem is that i press the bottom of Flex clean and appears (ERR) i think it means error and know the door doesn´t open
Can anyone help me please ): ?
Thank you Vivi Novelo-   Biivi
Feb 09, 2008
-   My Maytag oven door seems locked. Haven't used the cleaner, it just won't open. How can you fix it "with an open door" if the door won't open?-   Guest
Dec 28, 2007
-   I used the self cleaning feature with my GE Spectra Model # J B878W B2WW . A fire started on the bottom-I guess from leftover grease. I turned off the oven and unplugged it. Now the door won't open. I don't want to pay for a servcie man-any help?
marjo24_99@yahoo.com-   Guest
Solution #1
posted on Aug 12, 2007
Somewhat Helpful)
albinoviper
Rank: Wiz
Rating: 87%, 76 votes
Best bet on this one is to replace the lock assembly.
Although you could make a minor adjustment that may help. what you would do is with the door open put latch in lock position and then slightly bend latch to the left, making sure not to twist it. This works about 80% of the time.
Was this helpful?
Yes
No
Popular Solutions for Dacor Epicure ERD36 Dual Fuel
Questions and Unsolved Problems for Dacor Epicure ERD36 Dual Fuel
Do you recommend Dacor Epicure ERD36 Dual Fuel (Electric and Gas) Kitchen Range?
Answer
Answer
About a 4 inch square in the center of the broiler does not burn after lighting. We have self... (More)
Answer
Bought the stove in 2005 when we build our home. Had to have a switch replaced in 2007 to broil. ... (More)
Answer
when i select bake to preheat oven the bake element does not glo on only the broil burner. then when... (More)
Answer
I have a similar problem with thr F1 warning alarm that goes off at all hours of the day and night.... (More)
Answer
We have had a problem with the control panel since we bought this unit. Dacor rep says to turn stove... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Ranges Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
