Question about GE 24 in. Profile PDW7300G Built-in Dishwasher
Why does my ge dishwasher take 111 minutes to complete its cycle
It used to take 70 minutes from start to finish but now takes 111 minutes. Any thoughts on why?
SOURCE: GE Dishwasher Problem
Here is a link with solutions that for the water draining issue. http://www.myhomestyle.info/how-to-repair-your-dishwasher/
Posted on Apr 26, 2008
  • 276 Answers
SOURCE: Dishes not being rinsed thoroughly in our GE Nautilis Dishwasher
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Nov 19, 2008
  • 113 Answers
SOURCE: dishwasher with one inch of water in bottom when complete
undo the drain hose from your drain and put it in a 5 gallon bucket and see how it drains your sink drain maybe stopped up or if it drains into a disposal it may be stopped up
Posted on Apr 24, 2009
SOURCE: Standing water in the bottom of the dishwasher
I had the same problem - a 10 minute fix. The issue tends to be that the trap gets clogged by debris (like broken glass etc.) and restricts the amount of water that can be evacuated by the tub.
1. Undo the trap cover (two hex headed screws)
2. Remove the trap cover
3. Remove the inner trap grate
4. BE CAREFUL NOW ! Gently remove debris - this can have broken glass in it !!! - You can use a wet vac if you have one. Ensure all debrs is removed and the trap is clear.
5. Clean trap cover and grate
6. Re-install cover and grate
7. Bingo !
Posted on May 10, 2009
heatman101
  • 43501 Answers
SOURCE: dishwasher not draining
Here is a tip that I wrote that will help you with your problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Apr 18, 2010
My dishwasher suddenly won't wash hot on either the normal auto setting nor the eco one.
Do you find water left in the dishwasher bottom at cycle end???? It sound like your drain line is partially or completely blocked or possibly a bad drain pump depending on model. If it can't drain completely it can't refill with hot water. That will also explain an increase in the cycle time. Some dishwasher add time because it is trying to heat the water up. Its a loosing battle if the water isn't partially hot to begin with.
Apr 03, 2015 | Dishwashers
I have a GE PDW8400JO3BB dishwasher.It use to take 53 minutes to do a normat load and now takes 83 minutes. Why
There could be a few reasons for this..
Most likely the water temperature is not reaching the optimum temperature required for cycle.
The incoming water supply pressure could be lower which means it takes longer to fill.
The turbidity sensor might not be functioning properly causing the dishwasher to prolong the wash cycle.
Best to run the dishwasher empty with a Finish dishwasher cleaning kit that you can purchase from the supermarket. The instructions are written on the kit.
this should help clean dirt from all the sensors that are located in the tub.
Hope this helps.
May 16, 2011 | GE Dishwashers
Beeping sound when cycle is finished just started after 8 years. how do I turn it off?
Welcome to FixYa.
I think can answer your question..."beeping sound when cycle is finished just started after 8 years. how do I turn it off?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
? If the display blinks with a "0", you will hear
no signal (indicates OFF).
? If the display blinks with a "1", you will hear a
LOW volume signal.
? If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
? If the machine beeps, then the Cycle
Completion Signal has been enabled.
? When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Nov 06, 2010 | Bosch SHU9915UC Dishwasher
Why does my siemens dishwasher take 4 hours to finish running
Should only take 120 minutes to run a complete cycle. Your drain pump might not be expelling all the water.
Jul 18, 2010 | Siemens 24 in. SL34A006UC Built-in...
Whirlpool Dishwasher GU3600XTSB 3 - 4 hours to complete washing
Wash time is determined by the cycle you select, the incoming water temperature and the installation location. The new machines will heat the water to a predetermined temperature and it takes roughly 1 minute for each degree of rise, If the incoming water is at 120 deg and the wash cycle wants 165 than it will take 45 minutes just for that one cycle to complete, Factor in an outside wall with poor insulation or lower water temperature and it could take even longer. Eric
Dec 30, 2009 | Whirlpool GU3600XTS Dishwasher
GE Dishwasher GSD2000 door latch/sensor malfunctioning
The latch could need a simple adjustment or may require replacing.
Is the catch (the part that sticks out of the dishwasher, not the door part) loose?
Maybe try to loosen it (dont unscrew it completely) and re-adjust it to suit.
Hope this helps!?
Jun 18, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
GE 24 in. Profile PDW7300G Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
