Duplo DP220L error on machine that says ink exchange. We have exchanged it but it still asks for ink also it will not print onto paper
Silan
  • 54 Answers
SOURCE: Faulty printer
1. Unplug the printer power cord and remove the back door.
2. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around.
3. Allow the rollers to dry completely, then close the rear door.
4. Open the print carriage access door.
5. Use a clean, dry cotton cloth to wipe the carriage rod. Move the carriage as needed to clean the full length of the rod. Do not lubricate the rod.
6. Close the printer, plug the power cord in, and turn on the printer power.
Unseating and reseating the cartridge
1. Turn the unit on and open the lid or top cover.
2. Remove the cartridges.
3. Re-insert the cartridges.
4. Close the unit's lid or top cover.
5. Cycle the power to the device by turning the printer off for a few seconds.
6. Turn the printer back on.
7. Print a test page. If this does not solve the problem, proceed to the next section.
Wiping the cartridge contacts
3. Using a clean, dry lint-free cloth (a coffee filter works well),
wipe the cartridge contacts, from the top to the bottom. The contact
area of the cartridge should be rubbed briskly to remove the waxy
lubricant material from the gold contacts.
4. The contacts inside the printer may also require cleaning. Using a
clean, dry, lint-free cloth, 5. gently wipe the contacts, from the
top to the bottom.
5. Re-insert the cartridges and close the printer's top cover.
Print a test page. If the problem persists, perform a hard reset as
described in the next section.
Thank you
Posted on Dec 22, 2007
  • 5 Answers
SOURCE: canon ip4000r doesn't print 3ebk (black)
First of all... have you tampered with the printer's firmware? If not, it's unlikely it became corrupted. But if replacing the ink cartridges with fresh ones, and using a new print head did not fix your problem, you may be out of luck.
Is this a new problem, or has it always been like this?
Could it be that the print driver is always printing photo? In that case, it uses the narrow black ink cartridge instead of the fat 3eBK cart. You should print a nozzle check pattern and verify that you see the 3eBK cartridge pattern. If you do, the problem is likely SOFTWARE... your driver settings, not the printer itself.
I hope this helps.
Posted on Feb 24, 2009
bschilz
  • 2049 Answers
SOURCE: k8600 printer was bought as an off the shelf at
Here's a link to the User Manual from HP.
Download it and go to page 49 where it will describe the head cleaning and alignment process...
http://h10032.www1.hp.com/ctg/Manual/c01325186.pdf
Posted on Nov 08, 2009
xeerie
  • 347 Answers
SOURCE: Put in new toner into KonicaMinoltaBizhub200,says exchange toner
Machine is still saying to exchange toner because toner is not feeding into the machine. to supply the toner always do this, 1-insert the new toner bottle in the toner section and close the cover. 2-Press "Utility/Counter" Button. 3-click on "USER CHOICE" or "USER SETTING" 4-click on "Toner Supply" 5-Toner bottle will start moving and hence the error message will not appear again.
Posted on Jul 06, 2010
  • 1218 Answers
SOURCE: My printer is not printing
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Posted on Sep 09, 2010
Why do my pictures have lines across them?
Try running one or two ink cartridge cleaning cycles to help clear the air out of the ink nozzles. New cartridges aren't always perfect to begin with. After doing the cleaning try running a test print from your printer setup or installation properties window. If this print is good try printing another picture on a plain piece of paper rather than photo paper. If it prints OK then use your photo paper. I say this so you don't waste your photo paper. If you get lines in the test print, return the cartridge and see if the place you bought it from will exchange it for another one. If they will not exchange it try to get them to make the cartridge print correctly. You may have to bring your printer to them. This is the best advice I can give you, I hope it helps.
May 27, 2015 | Canon PIXMA Office Equipment & Supplies
My printer is full of ink but when I print anything with colour it had horizontal lines going through it
This problem is pretty much the same as the question I answered a few seconds ago. I am going to give the same answer. Try running one or two ink cartridge cleaning cycles to help clear the air out of the ink nozzles. New cartridges aren't always perfect to begin with. After doing the cleaning try running a test print from your printer setup or installation properties window. If this print is good try printing another picture on a plain piece of paper rather than photo paper. If it prints OK then use your photo paper. I say this so you don't waste your photo paper. If you get lines in the test print, return the cartridge and see if the place you bought it from will exchange it for another one. If they will not exchange it try to get them to make the cartridge print correctly. You may have to bring your printer to them. This is the best advice I can give you, I hope it helps.
May 27, 2015 | Office Equipment & Supplies
Would like to download owners manual for Duplo DP21
YOU CAN DOWNLOAD IT VIA WWW.GETMANUAL BUT HAS TO PAY SMALL FEES VIA CREDIT CARD
Mar 31, 2010 | Duplo DP21L Copier
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
The light is blinking on my maching (i believe it's the ink--or lack of it). i'd like to find out if that is so, but i can't seem to find the route to that on my machine, which is a mac. How do i get that...
I can't tell you how you could find out on you Mac as I've never used one with my C86 but I can tell you that you can translate the light flashing into a more meaningful "message" by observing the patterns.
  • Paper & Ink lights flashing alternately (power light off) = service required (ie: waste pads need replacing)
  • Ink light flashing = ink cartridge is empty or printhead is in the exchange position. Try pressing the ink button once (don't hold it down) and see if it moves to the exchange position or moves back to park.
  • paper light flashing = paper jam or no paper in feed.. Remove a jam or feed it with paper as required then press the paper button
  • Power light flashing = printer is busy... If it's doing nothing trying pulling the power lead out of the back of the printer, wait 5 seconds and then plug it back in, turn it back on. This should clear any error.
  • Both ink and paper lights flashing (together) = General error.. This could be anything from a serious paper jam, loose wire in the printer, parking station disconnect or similar..
Hopefully that will give you something to go on and get you working again... As far as software information goes, someone else may be able to help but chances are Epson's own support site will have some software called Status monitor or similar for your operating system which may help.
Cheers
Martin
Aug 05, 2009 | Epson Stylus C86 InkJet Printer
Hp photosmart c3180 just hooked up, new, comunicates with computer on all levels. print or copy will not put anything on paper, goes through all motions but does not put anything on paper, new supplied ink...
There is no reason for it not to print ink onto the paper unless it's defective or both carts are dried up. I would return it for an exchange.
Hope that helps...
Geno
Mar 27, 2008 | Computers & Internet
Kodak 5100 wont print after paper jam
If you cant get the jam cleared from the back or the top access door you could exchange it from where you got it. Or try and open it up and fix it yourself but that will void the waranty and you wont be able to exchange it. Or you could check the yellow pages for a PC/printer repair shop. But I mostly recomend trying to exchange it from where you bought it.
Feb 16, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Received faxes with not print
Stop playing with it, Return it and exchange it. You have a year warranty.
Dec 28, 2006 | Lexmark F4270 Plain Paper Inkjet Fax
23 people viewed this question
k24674
