Question about KDS Valiant 6480iPTD Notebook
How to disable the temperature sensor.
Hi gang, I would like to know how can i disable the temperature sensor. Im transforming a notebook into a picture frame, but, somehow, the computer keeps turning off ecause of temperature issues but the processor isnt that hot at all. One thing i realize is that the small board (the one that have the battery conectors) must be install in order to avoid the sensor to turn off the computer. Unfortunately this is not working and Im desperate to figureout how to just disable this sensors. any ideas??? thank you guys in advance PC
  • pcapelo Aug 12, 2007
    Hi again,
    There is nothing on the BIOS to disable that and the computer shutdown right after the boot. when the windows appear. There is also nothing on the power managment settings.
    I was thinking about the serie of 10 jumpers right next to the coller. does anybody knows what that jumpers for???
    Before i have this problem without the board i was getting the same problem. Thats why i tought if I am able to workaround the sensor i would never have this problem again, and i would be able to make the computer work whitout the small board
    thank you for your help.
    PC
    Scholar:
  • 181 Answers
Hi, Are you aware of any power management settings in the bios which would be shutting the system down? How long does it run before it shuts down? Also check in the os for power management settings. The power board indeed needs to be in place for the machine to operate. Good luck.
Posted on Aug 11, 2007
SOURCE:
Diagnostic code P1290 means what? I can not find it anywhere. Please help Thank you
P1290 Ford
P1290 Ford - Cylinder Head Temperature Sensor Signal Less Than Self-Test Range
Repair Importance Level: 3/3
Repair Difficulty Level: 3/3 What does this mean?
http://engine-codes.com/p1290_ford.html
Forum Code
Possible causes
- Wrong thermostat
- Not at operating range
- Engine overheated
- Low engine coolant level
- Faulty Cylinder Head Temperature (CHT) sensor
- Cylinder Head Temperature (CHT) sensor harness is open or shorted
- Cylinder Head Temperature (CHT) sensor circuit poor electrical connection
When is the code detected?
The Engine Control Module (ECM) detected the cylinder head temp below expected values
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
P1290 Ford Description
The Cylinder Head Temperature (CHT) Sensor is mounted into the wall of the cylinder head and is not connected to any coolant passages. The CHT sends a signal to the Powertrain Control Module (PCM) indicating the cylinder head temperature. If the temperature exceeds 126°C (-258°F), the PCM disables four fuel injectors at a time. The PCM will alternate which four injectors are disabled every 32 engine cycles. The four cylinders that are not being fuel injected act as air pumps to aid in cooling the engine. If the temperature exceeds 154 °C (310°F), the PCM disables all of the fuel injectors until the engine temperature drops below 154°C (310°F).
Read more: http://engine-codes.com/p1290_ford.html#ixzz3iX7EnL32
Aug 11, 2015 | Cars & Trucks
How to disable/enable touch pad on hp 6735s
well you will have to go to your bios settings first and disable you touch within the bios. plz let me no if you need help with the touch pad
or bois
Mar 21, 2014 | HP Compaq 6735s Notebook
I have a problem when I turn on my spa the control plannel just shows (= = = )and nothing will work dose any one have any ideas what it could be
Balboa Control Packs -
(---) = Unknown water temperature.
Spa Builders Control Pack -
(---) = "Watchdog". Water temperature has reached 118?F. Entire system is disabled. Contact qualified service technician.
This error code is related to sensor malfunction or failure.
Disconnect and reconnect sensors (while system is disconnected from electrical supply), if that does not help start by replacing the Temperature or Hi Limit sensors.
Jun 03, 2012 | Garden
I have a magic chef stove Im not sure the age however it keeps beeping and showing me a F2 message
Hi pamelajo,
The failure code F2 means the Oven temperature is too hot. Please check the sensor harness. Replace relay board, if present, or oven temperature sensor (RTD).
Hope it helps.
Thank you for using FixYa.
Feb 07, 2011 | Magic Chef 31000 Gas Kitchen Range
We want to replace our bathroom exhaust fan. We like the Harbor Breeze 'Rosemont' model at Lowes. It's a decorative combo fan/light unit. The unit is equipped with 2 13 watt (60 Watt incandesant...
It does not matter whether you turn on the switch or the switch is motion
activated, the light does not know who turns it on.
The switch must be designed for florescent.
What do you mean by proper base, you have a single gang wall box,
that's a box inside the wall, with the electric and a switch,
The gang could be single or hold 5 switches, which ever is installed.
Most all switches fill fit into any gang box.
Feb 08, 2010 | Dryers
Dash borad symbol
Sounds like your engine temperature warning lite - thermometer with two wavy lines under it. Upper left hand lite in gang of 4 lites
Apr 28, 2009 | 1995 Audi Cabriolet
I HAVE A FRIGIDAIRE ELECRTIC STOVE,GETIN F2&F3 CODES
Hi, these codes represents a fault within the oven temperature sensor. Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Please rate and god bless:)
Apr 18, 2009 | Ovens
KDS Valiant 6480iPTD Notebook Logo
453 people viewed this question
Top KDS Computers & Internet Experts
Thomas F. Schneider
Siul Oyaratgam
Steve Allison
Steve Allison
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
