Question about Plumbing
Nicolazzi faucet schematics
Need kitchen faucet part.. A112.18.1m 2 2 gpm83 . Plastic tip came out of thend of faucet. When turned on water comes out in a strong spray. Where can I find replacement airator for faucet in Alanta , Ga. Nicolazzi kitchen faucet
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
arealplumber
  • 33 Answers
SOURCE: delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Posted on Dec 09, 2008
SOURCE: Unable to loosen and unscrew kitchen faucet screen...
If you have a lime problem, try soaking the tip in boiling water with vineger added to it. The acetic acid in the vineger disolves the lime. I did it just last week when I serviced my kitchen faucet. It may take quite a while for the lime to disolve, but in the end you will achieve your goal.
Posted on Jan 07, 2009
SOURCE: need to fix a broken moen kitchen faucet
I had the same problem with my Aberdeen single lever with a pull-out sprayer a few months back. If you are the original owner of the faucet, it's under warranty; you shouldn't have to pay for any parts. Call: 1-800-BUY-MOEN (1-800-289-6636) and tell Customer Service what the problem is. They will send you the Handle Mechanism Kit at no charge. (Mine was part #93980 for my Aberdeen faucet, but yours may be a different part number.) It's tricky to take apart and get back together but my husband and I have zero plumbing experience and got it all fixed in about 20 minutes. The Moen.com website also has exploded parts diagrams of all their faucets so you can identify exactly what part you need, and they have some little videos and slideshows to show how to replace parts. If you can't reach Customer Service on the phone, you can go to "Contact Us" on their website and email them a description of your problem.
Posted on Jun 18, 2009
  • 5 Answers
SOURCE: The kitchen sink makes a loud popping noise
Try removing the aerator on the faucet. If that resolves the popping sound, try replacing it with one that allows for a higher flow of water. (Also the existing aerator may be clogged).
Posted on Feb 10, 2010
Do you mean the popup that stops water from draining? if so, you can easily buy that at a home improvement store as they are mostly universal. You will have to unscrew the arm underneath the sink and then insert it back into the hole of the new one so that your popup works correctly. If you cant get one for what you have, then get a new popup assembly.
Nov 13, 2013 | Plumbing
Nicolazzi faucet dripping - where to find parts?
Parts can be found at amazon, here: Amazon com Nicolazzi faucet. I hope this helped.
John
Oct 07, 2012 | Plumbing
New moen kitchen single handle. Worked for one full day. Now no water pressure.
Unthread end of faucet (aerator) where the water comes out into sink, under the aerator is a screen & a plastic valve.It has sediment & rust which will disrupt the flow & pressure.Careful not to flush it down the drain. Tip upside down, while holding it together with finger. Flush it under the faucet. It is not uncommon to get plugged up initialy because of the new installation.
Nov 01, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Slow water flow
first try and clean the air ratter where the water comes out the faucet it is a screen that un screws off the tip of the faucet. these can get clogged up over time from sediment and particles in the water. if the screen is fine then you can try and replace the supply lines to the faucet if that still doesn't fix it then you will need to replace the faucet because it has clogged up from minerals and particles in the water and there is no way to clean out the inside of the faucet.
May 16, 2010 | Globe Union N58022CP Do it Best 2Handle...
Lift up leaver and no water after 10 seconds
The aireator is clogged with dibri. Thats the part right on the tip end of the faucet where the water comes out. It will look something like this.
It will screw off, make sure you remember how it is assembled as you dissassemble the aerator to clean it. They typically consist of a few screens, a washer, and a plastic flow desperser.
Oct 01, 2009 | Kohler K-12176-CP Fairfax Single Handle...
Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
Mar 24, 2009 | Delta Model 470: Signature Kitchen...
Portable dishwasher won't stay connected to the kitchen faucet
it the faucet connector has a lever u push in order to latch on to the faucet, just jam something under it so it maintains upward pressure and wont come unlatched when the water starts flowing
Jan 30, 2009 | Maytag MDB9600A Jetclean II Built-in...
Low water flow from kitchen faucet
Their is likely rust build up behind the valve connections to the hot and possibly cold water supply lines. Turn the water off to the house relieve the pressure and remove both valves. Once removed use a screwdriver to break up the rust. With a small bucket under both lines turn the water main back on slightly to clear rust. Replace both valves with new ones.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Jan 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Plumbing Logo
694 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
