Question about Ibanez Tbx150h Tone Blaster Xtreme Guitar Amp Head
Fix amp It just wont turn on..
My line 6 amp has blown. I havent used it alot and when i do use it I never turn it up very loud. I think i pugged it into a bad electrical socket. I plugged it in and turned it on and the volume shot up...
Is it potentially fixable, but probably not worth it. By the time you have paid for spares and an engineer to fix it it would be more than the amp is worth. If it is within warranty then take it back to the shop. It may well have been a fault with the amp.
Sep 15, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
I recently got a Marshall mg100hdfx head for free because it wont turn on, so I am investigating possible parts that may need replacing. The only description I got as to why it wont turn on anymore is...
You may find almost anything in this. I think the power amp is on a separate board so the connections to that might have been broken. Possibility include cracks in the circuit board. First thing is to do after visual check is to check power supply voltages to verify power switch/fuse/transformer/rectifier/capacitor/regulator health. Switches are sometimes damaged... and also wires can fall of or break.
May 02, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
The amp was working fine and than just stoped , it wont turn on and all power is working.
The most likely problem in this instance is damage to the power supply, probably caused by a power surge. The second most likely cause is damage to the power cord. If you can take it to a shop that has similar amps on display, you can probably test it on one of there power cords. If the power supply is damaged, it will be a bit more challenging. At this point, if you know a bit about circuit boards and soldering, you might be able to fix it. If not, you will probably have to pay someone, or simply replace the amp.
Mar 14, 2011 | Line 6 Spider Iii 75 Guitar Combo...
Hi, my amp just died, i turned it on than the led lighted um and died, now i wont turn on ...
UNPLUG THE AMP
First you need to check any visible fuses either in the plug or on the back of the amp.
If you have an electrical testing screwdriver or meter you can test the fuse. If this sounds like gobbledegook (daft talk) then stop and take it to the dealer where you bought it.
If you can remove the fuse or fuses then replace them if it is obvious they have blown - dark and kinda burnt looking.
If replacing the fuses doesn't fix it - STOP.
Valve amps are serious bits of electrical hardware - they are not for home repairs - take it to a GOOD dealer / repair shop that deals with valve amp - nowhere else should play with it. When they have it sorted you can have the valves re-biased/changed to adjust the amp for the sound you want - yes the valves can change it.
Hope this helps - don't mess with it - even when turned OFF valve amps can give you a shock!!
Keep on Rockin'
Feb 18, 2011 | Orange Amps Orange Amplifiers AD Series...
My amp, was working fine last night, it wont turn on, and i tried switching guitar, cables, even power supplys and still wont turn on, i heard a pop last time i used my amp, and then the signal was lost...
The unit will require repair and if you are not adept at electronics, you will need to take it to a shop. Likely there is failure in the power supply or amplifier that has blown the fuse. Replacing the fuse WITHOUT repairing the cause MAY do additional damage.
Dec 28, 2010 | Fender Hot Rod Deluxe Guitar Combo...
I am no longer able to turn on my amp. I was running a bass head through it a few months ago, and havent used it since. Now the amp wont turn on at all. I have tried turning the master volume down to 0,...
probolly all you did was run a head into another amp and just caused your marshall to overheat/overpower and blew your output transistor. i you drop the chassis out and look at the chip on the heatsink is it blown? also check all internal and external fuses.
Nov 24, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
My electric guitar wont play with my amp
Yes its probably the wirring but if u look at it
it kinda crazy, so you wont be able to do it on ur own unkess ur a guitar tech so just go to a shop and they will fix it for u, problem is that if it is the wirring it willl have problems, so u might want to replace the WHOLE wirring system... Depending on the guitar u have, FENDER< GIBSON<IBANEZ, CORT, the wiring colors will be different
DONT TRY TO FIX IT URSLEF
Jan 05, 2010 | First Act Music
Amp goes dead
A few things come to mind. The power transformer could be failing or a capacitor is failed or has a broken solder connection..or a series of bad connections. Spider II's and especially III's are known to do this sort of thing. There is nothing you can do to fix it without taking it to an authorized repair center with your receipt. Repair centers simply get a whole new circuit board to replace the existing one since most of the components are surface mount and programmed chips. If its the transformer then if may be more expensive to fix than it's worth (unless it's still under warranty). With dozens and dozens of components inside these amps, there is no way to pinpoint the problem without hands-on servicing. Check Line 6's website for your nearest repair center. Best of luck!
http://www.line6.com/support/serviceCenters/
Aug 25, 2009 | Line 6 Spider Iii 120 Stereo Guitar Combo...
No power is going to my amp
This sounds like there may be something loose inside of the amp. Please dont go pokeing around in side there your self. Unless you are a fix it kind of person. There could be electric charges , even if it has been unpluged for days. Have some ck. it out if you can not. I bet ya its not to serious , all so ck the fuse. Some times they will play around just befor they blow out for good . keep on playing DFD
Mar 29, 2009 | Line 6 Spider Iii 30
Ibanez Tbx150h Tone Blaster Xtreme Guitar Amp Head Logo
18 people viewed this question
Top Ibanez Music Experts
Wayne Tolonen
Ted Maxwell
Kyle Steven OHare
Kyle Steven OHare
Are you an Ibanez Music Expert? Answer questions, earn points and help others
