SaNyo Tv. MODEL NO.PDP50G2T000
Turn tv on it stays on for 3 to 4
sec then go's off,I get nothing what do i do.
    Genius:
  • Televison & ... Master
  • 2,432 Answers
Tried to re seat connectors first going to the main board and other connector to reset the power supply.
Posted on May 09, 2013
Raditronic
  • 196 Answers
SOURCE: tv won't stay on. turn power on and it goes right off again.
Change cap c626 1000mf-16v to 1000mf-35v
Posted on Jan 31, 2009
romsky79
  • 822 Answers
SOURCE: When I turn the TV power on, the TV picture won't display, but the timer display (red blinking light) blinks momentarily and then clicks off. What is the problem and how much would it cost to have rep
check the horinzontal out transistors. call qualified personnel to fix.
Posted on May 30, 2009
jan mczeal
  • 632 Answers
SOURCE: How can I reset a Sony Wega tv without a remote
You can only reset the TV when you have the remote as it requires holding down the RESET button on the remote control, then pressing the POWER button on the TV front panel. The TV will turn itself off, then back on again. Then release the RESET button.
Regarding your problem with the TV not staying on for 3 seconds, you can try unplugging the unit for at least an hour to perform a hard reset of the microprocessor. If the unit still doesn't stay on, you need to check the power supply or the entire board for any blown or bad capacitor, shorted terminals due to accumulation of dirt, or broken solders. It may be a tedious task and requires an electronic prowess to do.
Kudos and thanks for using Fixya.
Posted on Nov 08, 2009
SOURCE: My Sanyo TV Model number DS20425 will not stay on.
look for d482 to be shorted if it is ecg 552 will replace and r482 will be open too iused a one ohm 1 wat res to replace so far it working just fine
Posted on Dec 04, 2009
gopakumarg43
  • 75283 Answers
SOURCE: My Sylvania 32" Tv Model #SRT2232S won't turn
Hello
There is a fuse inside the power supply bard of your sylvania TV. Check whether it has blown out. If bllown out, replace it with same type bothe in size and amperage. If the newly inserted fuse also blow up as soon as you switch on the set, make sure that the power supply section has some short circuit in it, and should be cheked well. OK.
Posted on Sep 28, 2011
Sanyo tv model FW55D25F LOST REMOTE trying tv on power up says hold down ok on remote for 3 secs but don't have remote
Look in the manual make sure you are pressing correct button on to. No manual go to websites
Feb 18, 2018 | Sanyo Televison & Video
DP46841 SANYO TV PICTURE GOES OUT AFTER 2 SEC. SOUND STAYS ON
Sounds like you may have a problem with the lighting...If a backlight goes out the volatage will not be correct and the tv may have a sensor which will shut the tv off after a designated time of voltage irregularity. Also might be the t-con board...
Nov 04, 2013 | Sanyo Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
We have 42" Sanyo tv
Check first the menu setting.If the setting is in VIdeo or in Tuner.
Sep 04, 2011 | Sanyo Televison & Video
My Sanyo TV Model number DS20425 will not stay on. It comes on for about 2 sec then turns back off. You can do this for about three times then it will not even try to come on.
Sep 29, 2009 | Sanyo DS20425 20" TV
Will not turn on and stay on
May be its Faulty transformer is making Noise,Please check the model number of yout TV and check for Warranty ...Contact customer support for replacement or service(click here)
Hope this info is useful for you..
May 31, 2009 | Hitachi Televison & Video
Programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
Mar 11, 2009 | RCA RCR450 Remote Control
Sanyo plasma 42 TV Turn off for no reason
Ok Fellas I found the Problem!
The Problem is the V4 Y-Main Board. This board is located on the left side of the case looking upright from the back. I spoke with may suppliers, and Sanyo all confirming this. Apparently it has been an issue for some time. Sanyo has replaced the V4 Y Main board with a W1 Y main board in newer models. The W1 Board is NOT compatible for us tho. Just to be sure... If your T.V is taken apart (like mine) Disconnect the peripheral cable from the V4 Y Main, and turn on the set. I bet it will power up with audio and channel function just NO picture. When you plug the board back in... POOF set shuts down. Replacement boards are VERY hard to come by. So Happy Hunting!
42' HD V4 Y-MAIN
PCB: LJ41-02760A LJ41-02761A LG92-01200A BN96-03352A
Oh yeah.. just FYI, Sanyo, Phillips, and Samsung all use the same parts. Hopefully that will help your searching.
Aug 26, 2007 | Sanyo DP42746 42 in. Plasma Television
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
