Bosch wfm 4030
Even after cleaning drum is not moving
3 Suggested Answers
  • 330 Answers
SOURCE: 600 and 900 spin lights
its the motor the 600 & 900 flashing lights is a error code for motor
Posted on Jan 05, 2011
Macmarkus
  • 2605 Answers
SOURCE: remove wfm 3200 pump
Hello, welcome to FixYa.
I understand you are having trouble removing/locating the filter access cover on your Bosch Nexxt washer, correct ?
I've posted my solution to error code E13 which should in turn explain to you how this covered should be removed...the first 3 steps should explain/illustrate how this is done, you can omit the rest if you like or review for cleaning procedure.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs, and a pair of mechanics gloves are recommended due to EXTREMELY sharp edges...safety first**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water that is typically the reason for a locked door, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine as you know (about 6" in diameter, lower rightcorner)
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free...it will not rotate unless the release tab is pushed in. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a green ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.macmarkus_28.jpg
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Oct 25, 2011
Hi. I have a problem with my washing machine bosch wfm 4030 ... working but bowel not moving . No spin
Spinning won't help Eat more greens you need fibre surprised you could even type query
Jul 09, 2017 | Bosch Washing Machines
How to operate a Bosch WFM 2000 washing machine
Anon, could not find WFM 2000, go to the link below or Google search your make and model# manual.
Download instruction manuals
Apr 29, 2016 | Bosch Washing Machines
Bosch WFM 3030. Why the belt falling?
was it noisy in spin. the bearing need to be changed
Jun 26, 2014 | Bosch Washing Machines
Looking for service manual for Bosch was28469gb
Drum is split tub, not even a qualified engineer likes doing this as it takes a couple of hours. If drum needs a clean out, run a couple of 90 degree cycles with a capful of baby sterilising fluid directly in the tub. Or you can purchase a drum cleaner from Bosch direct via their website (Accessories shop)
Apr 02, 2013 | Bosch Washing Machines
Bosch wfm 2010 user manual
Hi ,
I am looking for a user manual, for my w/machine BOSCH model WFM2010/08
Jan 13, 2013 | Washing Machines
Hi there, have got a bosch 1200 classixx WF02466GB/01 - pumps working but will not spin the drum. Belt is ok and drum does move when you push it.
To make sure it is not due to water left in the drum, remove the filter, and clean.
If it still does not spin, then it is more than likely that the brushes need replacing in the motor..
You will have to remove the motor to check them..
If they are less than 3 or 4 mm long, then they need changing.
Hope this helps.
Dec 22, 2009 | Bosch Washing Machines
Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Oct 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Drum will not rotate or spin
oooops - the motor was stuck under the carriage. Once
moved it came off easily.
Jun 17, 2008 | Bosch WFK 2401
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
