Question about Ardisam Inc Earthquake Mini Cultivator
Rally tiller 5hp j5000er
Need to find where to put oil or lube in transmission
Troybilt tiller, rough,grinding noise when tines engaged
make sure there is nothing caught in them rubbing the shroud. check to be sure there is oil or lube in the drive transmission. if the oil leaks out it will make a grinding noise.
Jul 09, 2016 | Garden
RALLYS 17 CRT 5HP ROTOTILLER MANUAL
What kind of spark plug is needed for a rally 17 CRT tiller?
Feb 29, 2012 | Yard Machines Garden
Trying to find a maintenance manual (exploded view of transmission) for a craftman rear tine tiller (may have been made in Canada), with 5hp Brigs & statton (1985 from motor serial). The tiller serial...
Go to sears.com. at top of page about center of page find parts. put in model #. It will give you a breakdown of the whole tiller.Try 917. as the first part of model #.
RGS
Mar 17, 2011 | Craftsman Garden
1997 bmw 328 ic what type of fluid do i put in transmission and how much
hi this will depend on a few things, i will write all the data you need, you will have to see what yours is,
automatic transmission fluid ZF transmission: 3HP22/4HP22/4HP22EH/4HP24 = DEXRON II A5S 310Z (5HP-18): Black Plate = DEXRON III Green Plate = Lifetime oil/ESSO LT 71 141 A5S 325Z (5HP-19) =Lifetime oil/ESSO LT 71 141 A5S 440Z (5HP-24) =Lifetime oil/ESSO LT 71 141 A5S 560Z (5HP-30) =Lifetime oil/ESSO LT 71 141 Black Plate = SHELL LA 2634 Green Plate =Lifetime oil/ESSO LT 71 141 GA6HP (6HP19)/GA6HP26Z (6HP26)/GA6HP32Z (6HP32) = SHELL M-1375,4
total drain and refill 3.0 ltrs
sorry its so confusing but you gotta make sure you have the right oil for the right gearbox...hope this is comprehensive for you
Apr 06, 2010 | 1997 BMW 328
My neighbor let us use his troy built tiller and it needs oil but he doesn't know what type of oil to put in the transmition. please help
The recommended lube for a Troy Bilt transmission is 140 Gear Lube. It's tough to find. If you use lighter oil, the trans seals will likely start to leak.
Jun 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Can't find filler plug on transmission
Jim the older tillers did not have a place to put grease in. You have to break the case apart then it takes 00 grease. These are sealed units and don't need additional grease. Check with Sears.com parts lookup for a new manual. I am on my second Craftsman r/t tiller now rebuilt the transmission on the first and wore it completly out then bought a new about 8 years ago. About to rebuild the transmission on it.
Apr 24, 2009 | Craftsman Rear Mount Tiller
Need a downloadable copy of owners manuals.
my 17 in dual tine tiller fouls up the air filter with oil and the spark plug. The prefilter, I can't tell if I put it in backwards or not. Also, the manual says to "fill the oil reservoir almost to overflowing." I don't believe that was right, because I am not sure if that is the reason oil is entering the filter box or not, but I am not going to do that again. I don't know how much oil to add, but it certainly won't be to overflow level. I am going to reverse the prefilter(screen/foam) in the filter chamber and pray that the oil does not foul up the spark plug and filter chamber again. Does anyone agree or disagree?
Apr 22, 2009 | Craftsman Garden
Ardisam Inc Earthquake Mini Cultivator Logo
Top Ardisam Garden Experts
Jay Finke
Jay Finke
Shehu Pro
Shehu Pro
Larry Maranto
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
