Question about Behringer Music
Pmp2000 cutting out - Behringer Music
My Behringer pmp2000 is now only giving an output through the tweeter horns of my speakers so the sound is very tinny. Any suggestions as to what might be wrong?
Your woofers are probably blown. To check plug a 1/4 inch or speakon into the speaker cabinet with the two bare wires exposed on the opposite end and touch with a 9volt flat battery if the driver doesn't move ir sound it's blown
Dec 15, 2014 | Behringer PMP2000 800 Watt 10 Channel...
Behringer PMP 2000 lost audio output
Sounds like a few capacitors have just blown, easy fix if your handy with a soldering iorn,
Aug 01, 2014 | Behringer PMP2000 800 Watt 10 Channel...
How to set up a behringer pmp 2000
http://www.behringer.com/EN/Products/PMP2000.aspx
You will find the manuals on this web page under "Documentation"
May 09, 2014 | Music
I need to know where can I purchase a fuse for Behringer PMP2000 10 Channel Mixer
If the fuse blew, you ARE going to need a lot more than a fuse as the cause is usually internal damage to the amp module and or power supply. Replacing the fuse without repairing the cause USUALLY causes more damage.
Oct 09, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Hi! I need a SM of my europower pmp 2000
This site for the PMH2000 should be near identicla to your unit:
http://elektrotanya.com/behringer_pmh2000.pdf/download.html
Scroll down to "get manual" and click to download schematic. IGNORE other download links.
The HCA2400 amp module in this has a chronic failure and is hard to work on.
Aug 28, 2011 | Behringer Pmp2000 Europower 800w 10ch...
My band plugs into the input channels on the SX2442FX mixer, which we then hook up to the PMP2000 to use as a PA. Since the SX2442FX is not a "Powered" Mixer, I figured that we should be going...
Either way will work, however your friend's method probably would be slightly better since it goes through less stages within the PMP2000. The "left and right power amp inputs" are the INPUTS to the power amp in the PMP2000 and hence are the best places to connect the mixer if using the PMP2000 as only a power amp. Note doing this will LIKELY disconnect any other input to the PMP2000 from the power amps in it... that is all the preamps in the PMP2000. DO USE TRS cables!!! and power both units from the same receptacle to avoid ground bounce.
Aug 25, 2011 | Behringer Sx2442fx Eurodesk 24channel...
Some of my eq sliders are broke off and i was wondering if i could get just a nother circut from behringer if it is fixable Terry
Depending on how its built and if your good with circuits i couldnt see why not. If its under warranty though make em give you a new one
May 09, 2011 | Behringer PMP2000 800 Watt 10 Channel...
Music Logo
41 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
