Question about MSI (P1102A2M) Server
Download msiserver zip - MSI (P1102A2M) Server
I have downloaded my designs and I can not get them open, what zip download do you use? I have zip elite.
WinZip? Also Win7 has zip support(assume, Win10 as well). Check if files saved with no errors. Download a couple of times and compare sizes.
Jun 29, 2017 | Computers & Internet
Tip
How to make windows installer work in safe mode
Windows Installer will not work under Safe Mode, this means that programs cannot be installed or uninstalled in safe mode without giving a specific command using msiexec in command prompt.
To make Windows Installer work under safe mode, you need to create a registry entry for every type of safe mode you are logged in to.
1.Safe Mode.
Type this in a command prompt:
REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MSIServer" /VE /T REG_SZ /F /D "Service"
and then
net start msiserver
This will start the Windows Installer Service.
2.Safe Mode with Network
REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MSIServer" /VE /T REG_SZ /F /D "Service"
and followed by
net start msiserver
on Mar 15, 2010 | Computers & Internet
Tip
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Windows Installer will not work under Safe Mode, this means that programs cannot be installed or uninstalled in safe mode without giving a specific command using msiexec in command prompt.
  1. Safe Mode.
and then net start msiserver This will start the Windows Installer Service.
  1. Safe Mode with Network
and followed by net start msiserver This will start the Windows Installer Service.
on Mar 15, 2010 | Microsoft Windows XP Professional
Can I open zip file in disk
How to Unzip and Zip files
cvs.bio.unc.edu/.../unzip.../un...
University of North Carolina at Chapel HillThis is very useful when disk space is limited or when people download files. Since multiple files can be stored in a zipped file, a single file can be downloaded ...
How to Open ZIP Files in Internet Explorer - For Dummies
www.dummies.com/how.../how-to-open-zip-files-in-internet-explorer.ht...
Sometimes when you download files from a website they arrive compacted into a form called ZIP. Compressed files download faster, so ZIP can be an ...
Zip File Spanning - WinZip Computing :: Knowledgebase
kb.winzip.com > KB Home > WinZip > Zipping and Unzipping
WinZipMar 11, 2015 - WinZip Pro will automatically create a Zip file that spans multiple discs if ... To unzip a spanned Zip file, first insert the last disc of the spanned ...
Multiple Disk Spanning - WinZip
kb.winzip.com/help/help_span.htm
WinZipTo make a Zip file that spans multiple disks, simply create a new Zip file on a ... Toextract files from a spanned Zip file, insert the last disk of the series and open ...
unzip - Python: downloading and unzipping a .zip file ...
Jan 27, 2016 | SanDisk 4GB Memory Stick Micro M2 Memory...
I need a dongle only not the whole adapter where can I get one?
im not sure what you are reffering to the dongle or a dongle usb driver
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
there are many of the blutooth dongle drivers BTD-601 Flat Bluetooth USB Dongle
http://www.cdrking.com/downloads/bt_flat.zip
http://www.cdrking.com/downloads/btd602.zip
http://www.cdrking.com/downloads/bt_slim.zip
http://www.cdrking.com/downloads/btd605.zip
http://www.cdrking.com/downloads/btd608.zip
http://www.cdrking.com/downloads/btd609.zip
http://www.cdrking.com/downloads/transit.zip
hope one of these will help you
TM-1040 U-Bluetooth USB Dongle
http://www.cdrking.com/downloads/tm1040.zip
Mini Bluetooth USB Dongle
http://www.cdrking.com/downloads/bt_mini.zip
TM-1041 Bluetooth CSR V2.0
http://www.cdrking.com/downloads/tm1041.zip
TM-1042 Bluetooth CSR V2.0
http://www.cdrking.com/downloads/tm1042.zip
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetooth-driver-ver-5/3000-2110_4-149801.html
to suit multiple usb devices
ยท Operating system: Windows 95/98/2000/XP/2003/NT/XP 32-bit/AMD 64-bit/2003 32-bit/AMD 64-bit
hope this helps
Jun 04, 2011 | HP Computers & Internet
Vista window installer cannot be accessed/incorrectly installed for some downloads
Start the Windows Installer service
  1. Click Start, type Services.msc and press {ENTER}
  2. Double-click Windows Installer
  3. Set the Startup type of Windows Installer to Manual
  4. Click Start to start the service. (Write down the error message if any).
  5. Click OK.
Windows Installer Registry Fix If the above steps do not help or if the Windows Installer service is not listed in the Services applet, follow these steps:
  1. Download msiserver.zip and save it to Desktop.
  2. Unzip the file and extract msiserver.reg to the Desktop.
  3. Right-click msiserver.reg and choose Merge.
  4. Click Yes when asked for confirmation.
  5. Restart Windows.
May 27, 2009 | HP Pavilion a1610n PC Desktop
Error 1719
Error 1719 occurs when the msiexec.exe program becomes disassociated with .msi files. Under Windows XP x32 this is usually fixed with rebooting into safe mode, renaming the msiexec and DLL's and letting Windows File Protection reinstall them. This doesn't always work in x64.
Error 1719 occurs in x64 when the 32-bit version of msiexec is registered as the msiserver. Here's the fix:
  1. Open regedit ( Start -> Run -> regedit.exe -> OK)
  2. Go to the following key: My computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\MSIServer
  3. Look at the ImagePath entry. For Windows XP x64 it should read:
CODE - C:\WINDOWS\SysWOW64\msiexec.exe /V
If it doesn't edit the registry to match that.
4. Restart the Windows Installer service from the Admin Control Panel -> Services CP
OR
Click on the below link or copy the URL and paste it in your web browser.. Follow the steps....
http://support.microsoft.com/kb/315346
Thank you......
Oct 01, 2008 | HP Computers & Internet
MSI (P1102A2M) Server Logo
81 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
