Panasonic viera TH-50PZ80BA
Any ideas pls..my 50" panasonic TH-50PZ80BA flashes 10 red lights when i try to turn it on . Iv managed to turn power off few mins then it switches back on ..this s the second time its happend im affraid it was a warrnin that something serious needs replacing . Im unable to find fault codes for this modell and im unshure if other modells are sort same code ..any ideas please .
SOURCE: red light flashes 10 times - Panasonic TH-42PX6U
hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
Posted on Nov 25, 2008
djchillsnyc
  • 151 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
  • 8457 Answers
SOURCE: i have a plasma panasonic viera TH-42PV60A stand
Not power supply,it the backlight video board it dead.
Posted on Nov 23, 2009
Testimonial: "cool thanks alot"
tvhelp-Dave
  • 178 Answers
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Posted on May 10, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: error codes. no picture or sound after turning
When the SUB5V or MAIN9V/SUB9V, short or over-voltage 15V short condition occurs, the TV shuts down and the power LED blinks 10 times.
Posted on May 16, 2010
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Panasonic th-50pz800u shuts down and i can not turn back on, red light flashing 2 times, sometimes 10 times
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 20, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
I have a Panasonic TH-50PE700U
I think if you Google research the model with "10 blinks" you will likely find it is bad power supply or related to it.
Apr 29, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Jun 22, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Plasma panasonic headache
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Power lite blinks 10 times. no pic no sound. cant turn on or off
red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
May 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Televison & Video Logo
206 people viewed this question
Top Televison & Video Experts
Electro Med Services...
