Question about ASUS V8420/TD Graphic Card
High Ping When playing Battlefield 2142 Online
When playing Battlefield 2142 online I am getting kicked off the server because of a high ping rate ( sometime up to over 300, but mostly around 260). I have turned off the firewall on my dsl modem and wireless router. I have added this game into my exceptions list with window xp firewall. Please help. Rockmiester
  • 3 more comments
  • Anonymous Apr 01, 2008
    Ping rate too high... 300 +.... how do i fix it?
  • Anonymous May 26, 2009
    When I play bf2142 my ping is anywhere from 275 to about 700. How do i fix this.
  • Geoffrey Voeth
    Geoffrey Voeth Nov 14, 2013
    get the server ip address or www name and then ping it from the command console if its the same its too far away and find a closer server.
  • Geoffrey Voeth
    get the server ip then using the commans console ping that ip, if the ping is too high find another server closer to your location.
  • Geoffrey Voeth
    if you tracert the ip i think you also see the other servers you must go through and each ones ping.
    Problem Solver:
  • 17 Answers
There are a lot of factors that can affect ping rates. Server location, server load, local internet load, and your computer and network setup. The server you access for Battlefield may be too far from you. Try typing "ping 69.147.114.210", at the command prompt,(usually found in "All Programs/Accessories") also without the quotes. You should get numbers in the 40-60ms range. (thats Yahoo.com by the way), then put in the IP number of the Battlefield server. Any returned numbers under 100ms are ok, if your getting higher numbers, check the Battlefield forums to see if there is a server closer to where your located. If your getting numbers over 250-300ms at both sites, then download Lavasofts Adaware SE which is free, and Spybot Search & Destroy, also free and run them both, (once a week after as well) they will remove spyware and adware from your computer. There is a possibility that spyware or adware is using network resources.
Posted on Aug 13, 2007
    Problem Solver:
  • 15 Answers
Your pc might be infected by spyware, before running game, kill the spyware activities by press cltr+alt+del the choose process, find powers.exe, clik and end task. run your game
Posted on Aug 12, 2007
Just upgraded my internet speed. Went from a ping speed around 85ms to 800ms. Because the Ping speed is so High I can not play my 2 online game I get lag.look at the ISP but it did not say what to do.
You may have to configure your new router to pass gaming traffic with a priority over other traffic. Can't help you much more than that without knowing more.
Jul 23, 2016 | Computers & Internet
Online gaming ping getting high suddenly then it starts to go down
I am not familiar with that specific MMORPG, are you logging into a dedicated host or is another player hosting the game, if it is another player hosting the game the problem could be on that players end and not yours.
You can try doing a hard rest on your router and then setting it back up, if you write down the old passcode you should be able to manually reenter it into the corresponding block in your router so you do not have to use a new one and setup all your wireless devices again.
It could also be someone else on your network hogging bandwidth" watching videos, downloading a large file"
Jan 23, 2013 | Computers & Internet
While playing games high ping,decrease it?
Whenever your ping gets high,You can reset the modem and un plug the connection ,then restart the pc ,then connect and try to play again.This may helps to reduce the ping.You can check the Local LAN Connection Ping using the steps below..
Start->Run->Cmd Prompt ->Ping ip or ping website name
To Ping a website you can visit the site Whoisxy.com/ping.aspx
Aug 31, 2012 | Computers & Internet
I have a Broadband connection and i play online games and my ping is to high please help mee ..!
the faster your broadband connection the lower your ping will be.
broadband speed, is affected by company,area, how far you house is from the telephone exchange, could also be a problem with your line.
things to do to begin with is www.speedtest.net speed test
then if you are in the uk, use this site http://freeola.com/broadband/broadband-speed-availability-check.php
should tell you what speed your broadband should be.
Jun 17, 2012 | Video Game Consoles & Games
Online play is very choppy and I often get kicked off line.
There are a number of things that can cause this, namely your internet speed.
Make sure you have high speed internet with at least 10mbps download and 1mbps upload for best results. Game play can also be affected by wireless. If you are connected to your router via wireless, try using a network cable instead. If your wireless signal quality varies a lot it can cause disruptions in your connection. If you have any P2P programs running such as emule, limewire, torrents, etc... Shut them down as they tend to sap your upload speed which in turn, affects your game. If your computer is not that fast and doesn't play the game without online mode very well, it could be worse online being you are now rendering more elements into the game. Lastly, EA Servers may be over loaded at peak hours which could also affect your game play.
Check your internet speed here http://www.speedtest.net and also your link quality here: http://www.pingtest.net
Make sure your ping is at least below 80ms and your link quality is A or C. Any less and you may have trouble playing some online games. And again, for the speed, it's good to have at least 10mbps download and 1mbps upload. My connection is 50mbps download and 3mbps upload with ping grade A and ping 3ms, so I have never had any problems myself with online games and real-time streaming J
Hope this helps!
Chris
Sep 08, 2011 | EA Sports Computers & Internet
Very high ping
1 - Remove router from the network (pc/PS3 directly to inet)
2 - Call your ISP if that didn't fix it.
Side Note - To trace where the high ping occurs....
Start Menu > Run...
Type Cmd, Press Enter.
Type "tracert google.com" hit enter.
Each line shows a Hop ( like another router or switch). Find where the ping jumps to help pinpoint the problem...
May 22, 2010 | EA - Electronic Arts Battlefield Bad...
Need a better ISP, cannot play Online Games as i get ping kicked for my ping being wayy to high and there no way for me o decrease it except find another ISP, need an ISP with a plan which is super...
OK, the first thing I need to know is What System Are You Running? (i.e.: Windows XP, XP Pro, Vista? also, Manufacturer & Model of your PC)
May 15, 2010 | Computers & Internet
Counter strike steam high ping
Ping is based on your distance from the server, and that's it.. Nothing you can do to make it any better.. You can try game booster to help with the game performance, but still won't help with the ping.. Just choose lower ping servers to play in..
Sep 07, 2009 | Electronic Arts Counter-Strike 1:...
I get kicked due to high ping what should i do?
When choosing a server try to sort the list by ping rate and go with the lowest ping you can that is offering the map and amount of players you are looking for. If you frequently get disconnected or see connection_error on your screen while playing it could be a problem with your actual internet connection dropping packets. To test that you will need to ping a well known server like google or microsoft and see what ping times you get and if any packets are lost. This can by done by clicking start -> run and typing cmd then pressing ok. In the dos box that pops up type ping -n 20 www.google.com and press enter. Significant packet loss and high ping times could mean your connection is saturated from other downloads/uploads, there is some bad cabling or network hardware somewhere, or your ISP is having some problems. If you are connected to a router or other network equipment and assuming you have a high speed connection try connecting directly to the modem provided to you and see if that helps. If the problem continues you will need to contact your internet provider for additional troubleshooting.
Mar 17, 2009 | Electronic Arts Counter-Strike: Source for...
ASUS V8420/TD Graphic Card Logo
2,178 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
