Lipi line printer 6620 weld not detected after some pages
Weld not detected between printing after some pages
  • 202 Answers
SOURCE: I have Epson Passbook Printer having some printing problem
this is problem of software you are using to print(ie: word ,notepad etc) plz check the setting and try again.
check page setting ,properties,prefrences.
it is due to page layout also(ie: letter,a4,a5 etc)
Posted on Jan 24, 2009
SOURCE: problem for lipi 6312 tally genicom line printer
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Posted on May 19, 2010
SOURCE: Lipi 6306 Line printer
i want to knwon the which operating system supports the lipi tally genicom line printer model 6306
Posted on Jul 12, 2010
  • 114 Answers
SOURCE: t6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
Posted on Jul 18, 2010
  • 60 Answers
SOURCE: when printer initializing ,printer shows
MAY BE LOGIC CARD PROBLEM.
Posted on Feb 02, 2011
Weld not detect
Hi
The cartridge weld was not detected.
1.Clear the fault message.
2.If message persists, replace the cartridge.
3.If necessary, replace the weld sensor.
Feb 15, 2014 | Printronix P7220 Matrix Printer
WELD NOT FOUND ERROR
Sounds like a failing weld sensor. Clean it first its on the left side, you can see it when the ribbon is out. If that doesn't help replace it.
May 08, 2013 | Printronix LineJetĀ® P7010 Matrix Printer
How to print pdf document in lipi 6306 printer
It depends on what you mean by printing a PDF.
You can not "Direct Print" PDF documents on the 6306, you will need to pass the document through an appropriate printer driver / filter depending on the operating system used.
Simply sending a PDF document to the printer will not work
If you are using Windows simply print the PDF from Adobe Acrobat using the appropriate Windows Printer driver. If you can print a Windows Test Page, you should be able to print a PDF document- The quality of the print may not be of laser printer standard- Remember this is a Line Dot Matrix printer
Apr 03, 2013 | Tally 6312 Matrix Printer
T6312
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
I have a line matrix printer lipi 6306L. When I switch on the printer it shows a fault : Platen Cal Cable How to solve it
platen calibration has to be done . in offline press lf and enter for tech access on , then go to test menu, select diag,then select call engine , then select platen cal and press enter , it will ask remove ribbon and remove paper , then it will automatically calibrate . then ur problem will be sloved
Jan 25, 2010 | Tally 6312 Matrix Printer
Oct 16, 2008 | Office Equipment & Supplies
210 people viewed this question
k24674
jasbo
jasbo
