A
Anonymous Posted on May 08, 2013
Lipi line printer 6620 weld not detected
Weld not detected after half document printing
5 Related Answers
Anonymous
  • Posted on Nov 24, 2008
SOURCE: occasionally bottom line of document only partially prints
Goto Office button-> Print-> properties-> Change paper size to A4
Anonymous
  • 94 Answers
  • Posted on Aug 13, 2009
SOURCE: print half of full page
If the printer starts to print and stop in the middle check the eletricity of your place, this may have a variation. If the printer prints a half page and give you the paper, with no jam, check the cartridges and then the main board.
Anonymous
  • Posted on Aug 17, 2009
SOURCE: Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Anonymous
  • Posted on May 19, 2010
SOURCE: problem for lipi 6312 tally genicom line printer
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Anonymous
  • Posted on Jul 12, 2010
SOURCE: Lipi 6306 Line printer
i want to knwon the which operating system supports the lipi tally genicom line printer model 6306
Weld not detect
Hi
The cartridge weld was not detected.
1.Clear the fault message.
2.If message persists, replace the cartridge.
3.If necessary, replace the weld sensor.
2helpful
2answers
In Lipi 6306 line printer "Checksum fault block 8".It is not going on offline.What should I do now.I have not faced this type of problem before.
In Lipi 6306 line printer "Checksum fault block 8".It is not going on offline.What should I do now.I have not faced this type of problem before. os window xp
1helpful
How to print pdf document in lipi 6306 printer
It depends on what you mean by printing a PDF.
You can not "Direct Print" PDF documents on the 6306, you will need to pass the document through an appropriate printer driver / filter depending on the operating system used.
Simply sending a PDF document to the printer will not work
If you are using Windows simply print the PDF from Adobe Acrobat using the appropriate Windows Printer driver. If you can print a Windows Test Page, you should be able to print a PDF document- The quality of the print may not be of laser printer standard- Remember this is a Line Dot Matrix printer
2answers
My system is Vista. The Lipi Printer Driver is not support. Please Help me.
What is the Lipi printer model you are using, for most of the Lipi printers, the Drivers are inbuilt in Vista Database.
26helpful
3answers
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
2answers
Print is blank on middel side
check the margins of what you print..then check when you click print it will show the dialog box prompting you that you will print the blah blah blah...then click properties,,another dialog box will appear check if the page layout of your printing document and your printer settings are the same...hope it can help you..
5helpful
2answers
Printer cuts off last line of text on document
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see thie website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
7helpful
4answers
k24674
ADMIN Andrew
ADMIN Andrew
