Question about Dell Inspiron 8100 Notebook
Hard reset How to i completely erase information from my hard drive? I am giving this laptop away but I want to erase everything off of it first
  • Dell Master
  • 32,281 Answers
If you want to wipe the hard disk and not reinstall Windows then -
Wipe Data off Hard Disk with Darik's Boot and Nuke, (DBAN)
Create a Darik's Boot and Nuke on CD disc, then boot up the computer with this disc.
http://www.dban.org/download
Posted on May 09, 2013
Erase hard drive
I use this free utility to wipe computers before I dispose of them: http://www.dban.org/
I hope this helps.
Feb 08, 2014 | Compaq Presario 5280 PC Desktop
I want to give away my iqon laptop,how do I clear the memory
You can boot from a source other than your hard drive, a usb stick or a bootable cd. then use the format command to erase the hard drive. You are now good to give it away.
Jan 27, 2013 | Samsung SyncMaster Computers & Internet
I would like to give my Zire 31 to a friend but need to erase all my information from it. How do I do this?
Do a HARD RESET on your PALM ZIRE 31.
A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings.
  1. Press and hold the Power (on/off) button on the front panel of your device.
  2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  3. If you see a progress bar (see below), keep holding the Power button.
  4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Jun 28, 2011 | Palm Zire 31 Handheld
I want to give away my D620 emachines laptop, but want to reset if first so all my personal information is erased. How do I do this?
In order to completely reset all personal information, the only failsafe way is to wipe the hard drive (and even this is not failsafe).
Look at this program. This program will allow you to make a bootable disk (eg USB). After you create the disk, reboot your computer and press the Boot Order key (on a Dell D620, its F12). Select USB. The Kill Disk program will load, allowing you to completely wipe your hard drive (eg. by overwriting everything with 0's). This will probably take a while, depending on the size of your hard drive.
Apr 30, 2011 | E-Machines (T2958) PC Desktop
My asus eee pc 1005HA's battery port can no longer charge my laptop or the battery AT ALL! I just want to erase the information and give the laptop away to someone who probably can fix it....I just want...
Take out the hard drive and hook it up to a desktop pc. Navigate to the drive and delete the files through the desktop pc. Then put the hard drive back in the laptop.
Mar 23, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I want to erase everything on my external hard drive. How do I do this?
If you aren't sure what you're doing, bring it to a service tech or you may render that external hard drive completely useless:
Before you start cleaning make sure you back everything up onto another disk. If you are giving your computer away check with the person or organization to see if they plan on cleaning your hard drive for you. However, the best thing to do is to clean it yourself.
Download a hard drive cleaning program or go to a computer store that sells computer software and buy the program. This is the safest way to make sure the hard drive is all wiped clean. Running the software program over writes all the data on your drive, making the hard drive impossible for anyone to read. The software works by over writing the drive many times.
Make sure you give yourself plenty of time in wiping your hard drive clean because if you have a lot of stuff it will take longer to clean.
Once your running your program and the box comes up to erase your hard drive don't forget that this process is irreversible. You will now type in the word format drive letter and hit confirm that you want to erase everything on your computer.
Installing a new external hard drive if you are not getting rid of your computer, is another option you have. You still go about erasing the old drive because you're getting rid of your hard drive. Install the new one.
Jan 01, 2011 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
Eraseing a sandisk 2 gb flash drive
To Erase everything on the drive you can format it. To do this, plug it in, then go to 'my computer' Right click on the drive, and select 'format'. BE AWARE, THIS WILL COMPLETELY ERASE EVERYTHING ON THE DISK! So make sure that there is nothing that you want to keep on there.
Jul 27, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Reset pssword
Boot up the laptop as normal. Then insert the install disc.
The disc will mount and a window will open to show the install icon.
double click on this. The computer will prompt to restart. Do so.
DO NOT HOLD DOWN THE 'C' KEY. The laptop will boot from the install disc. After selecting the prefered language, select 'Disc Utilitiy' from the 'Utilities' menu on the top tool bar. Choose the laptop hard drive in 'Disc Utility' and select 'Erase'. If you are passing the laptop onto another person, choose the 7 pass erase from the secutity options to completely over-write the hard drive. This will make all your data un-recoverable and keep your personal details secure. (Normal erase only destroys the index on the drive. Your data is still there and can be recovered).
Jun 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Erase info
You should do a hard reset, which will set it back to factory status and erase everything.
Mar 21, 2009 | Palm Tungsten E Handheld
Software upgrade makes bluetooth unworkable
I think this can help you:
Treo 650 only
A zero out reset will regress a device that has non-volatile memory to its factory-fresh state. When done correctly, it completely rewrites your device's internal memory with zeros and ones, ensuring that any data is expunged. It should be used only if you want all information completely obliterated (example: you're selling your handheld, or you're sending it in for repair, and want to protect your privacy). Tungsten E2 note: a hard reset (above) produces the same results as a zero out reset - completely rewrites data on internal memory. No need to perform the steps below. Warning: A zero out reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings. Don't perform a zero out reset unless you want to eradicate everyting.
spacer.gif HotSync note: Some third-party applications change the way your device backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost.
There are two ways to perform a zero out reset.
  1. Read through these instructions before attempting the reset. We made this method of zero out reset extremely awkward to perform, so that it would not happen by accident. You may need the help of a dextrous friend if you find it too difficult to do by yourself.
  2. Connect your device to its HotSync cable or cradle. The HotSync cable does not need to be connected to your PC, and it does not need to be connected to power.
  3. Press and hold the Power button and UP on the 5-way navigator.
  4. While continuing to hold Power and UP, press and hold the HotSync button on the HotSync cable or cradle. As you press HotSync, make sure your other finger doesn't slide to LEFT or RIGHT on the 5-way navigator; it needs to be exactly on UP during the entire process. Although you are pressing the HotSync button, a HotSync operation should not begin.
  5. While continuing to hold Power, UP and HotSync, press and release the RESET button on the back panel of your device (where's the reset hole?). This is very difficult to do with only one person; you may wish to hold the stylus in your mouth and use your hands to press Power, UP and HotSync.
  6. Release Power, UP and HotSync.
  7. If you did this reset correctly, the screen of your device will go blank, and you will not be able to turn it on. The charging LED will not light up, even if it's connected to power. It will appear to be "dead." (any other activity — such as the Palm OS logo or a rainbow-colored Boot Log screen appearing — means the reset was performed incorrectly; try again)
  8. Your device will appear "dead" for several minutes (up to 10 minutes). During this time, your device's internal memory is being reformatted. If your device doesn't appear "dead" for several minutes with the screen completely blank, the zero out reset was performed incorrectly; try again.
  9. After several minutes, your device will "wake up" and the Palm and Palm Powered logos will appear as if you had performed a hard reset. Eventually, you'll be taken to a series of screens to calibrate the touchscreen and set date & time.
  10. If you want your handheld to remain in factory state, stop here. If you want to restore data to your device, follow the steps for recovering after a hard reset (a zero out reset is a special type of hard reset).
Quick Erase, Secure Erase
LifeDrive only When you perform a hard reset on a LifeDrive mobile manager, you will see two options on the reset screen: Quick Erase and Secure Erase. Both of these are types of hard reset. Quick Erase: Perform a Quick Erase reset for a regular hard reset, to get your device to wake up and respond again. This eliminates user information on the drive in such a way that there is no info available to anyone using the device. A Quick Erase reset takes approximately 5 minutes.
spacer.gif spacer.gif spacer.gif Secure Erase: Perform a Secure Erase reset if you are turning the device over to a new owner. A Secure Erase helps prevent your files from being restored or recompiled by a new owner who might remove the hard drive and use a drive reader to access your information. This completely deletes all user info on the drive. A Secure Erase reset takes about 30 minutes.
Note: If you use a password to protect your device, you must do a Secure Erase when you hard reset your device; the Quick Erase option does not appear on the reset screen.
  1. Slide the power switch to the right and hold it in that position.
  2. While holding the switch to the right, use the tip of the stylus (or a similar object without a sharp tip) to gently press and release the reset button on the bottom of your device.
  3. Wait for the reset screen to appear (it will say "Warning, Erase all data?"). Then release the power switch.
  4. Choose your type of reset:
    • Press Up on the 5-way navigator to perform a Quick Erase (5 minutes)
    • Press Down to perform a Secure Erase (30 minutes).
  5. During the reset process, a status screen appears with the words "Quick Erase" or "Secure Erase" and a progress bar, followed by screens showing the Palm, Palm Powered and LifeDrive logos.
  6. Then you will be prompted to tap the screen to align the digitizer and select the language you want to use on your device. A screen appears showing the Palm logo and a progress bar.
  7. When the "Welcome: Setup your device" screen appears, the hard reset is complete. Follow the onscreen instructions to set up your device.
Nov 09, 2007 | Palm Treo 650 Handheld
Dell Inspiron 8100 Notebook Logo
62 people viewed this question
Alun Cox
