Question about Carrier Heating & Cooling
Cf appears after shutdown of aircon - Carrier Heating & Cooling
2 Suggested Answers
SOURCE: cf appears after shutdown of aircon
Check filter if its running ok.
Posted on Feb 25, 2012
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    What does CF means in aircon operation
    I turned of my airconditioner it turned off but a error came up saying
    CF .
    Feb 24, 2012 | Heating & Cooling
    A error code E154 appears, then I shut down the unit, and restart, no problem a few minutes, then the error code appears again. have you the solution?
    Hello there, I guess your Running capacitor is leaking already, when you start your aircon it will run after a minute the aircon will stop with errors, because the fan is stop running due to busted capacitor. thanks
    Apr 25, 2011 | Heating & Cooling
    Chart details not appearing after removal.
    Same problem I had. After resetting unit and checking CF on another unit, Raymarine tech. said, the reader is not working. All pins seems to be OK on first look. I opened unit by removing several screws in front, gasket and the whole chassis from the case. Simple repositioning of pushed down pins from inside into the Compact Flash corrected contact problem of reader. Since then, I never removed CF. It seemed, after several reinsertions of CF, I pushed down two pins in CF slot.
    Jul 26, 2010 | Raymarine C120 GPS Receiver
    Problem with the CF card
    Do both of these CF cards still function when you connect them to the computer?
    Inspect the CF connector on the camera using a flashlight (torch). It's possible that one or more pins on the connector may have been damaged, somehow. If this is the case, the camera will need to be repaired.
    Can you still operate the menus after the error message appears? If so, use the menus to reformat the card (see the manual for instructions).
    Aug 08, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
    Err 99 & err cF in my canon 350d camera
    had the same problem before
    found this guide online
    1. Turn off the camera.
    2. Remove the lens, battery, and CF card.
    3. Allow the camera to sit without power for approximately 20 minutes.
    4. Insert a fully charged battery, and turn on the camera.
    5. Depress the shutter button as you would to take a picture.
    Does the “ERR 99′ message appear? If it does, then the camera should be
    serviced. If it does not, then please proceed to the next set of steps:
    2. Insert the CF card.
    3. Turn on the camera.
    4. Format the CF card in the camera.
    Does the “ERR 99′ message appear? If so, then the CF card is the most
    likely source of the issue. Try using a different card.
    If the message does not appear, please complete the following steps:
    2. Clean the lens contacts by gently rubbing them with a pencil eraser
    or soft cloth. Be careful that you do not let any debris fall into the
    camera body.
    3. Reattach your lens.
    4. Turn on the camera.
    If the “ERR 99′ message only appears when one particular lens is
    attached, then that lens should be examined by a service technician.
    If you see the “ERR 99′ with a different Canon lens attached, then the
    camera should be serviced.
    Jan 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
    Heating & Cooling Logo
    10 people viewed this question
    Top Carrier Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Donni Steen
    Bill Long
    Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
