Question about Health & Beauty
Rascal taxi 4 mobility scooter
Scooter switches on but will not run green light flashes in a sequence of 8 short flashes a pause and then continues to repeat the 8 flash sequence. Bateries have been changed out for newer ones, all contacts have been cleaned and made sure that all spring loaded contacts are free. No loose wires and fuse in head is ok. Motor works as tested on a separate battery supply. Any ideas as to what to check next?
gewiz
  • 1271 Answers
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
Posted on Jun 13, 2009
gewiz
  • 1271 Answers
SOURCE: no drive,flashing green light
Are you sure the FREELEVER is in the right position ? , to test try to push the scooter ?
Battery Low ?
  • 61 Answers
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Posted on Mar 19, 2010
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
FixinFax
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
My scooter wont go all of a sudden and the red light on the console is blinking a sequence of 4 times
Amigo Scooter Oxygen Tank Holder Light flash key turned ...
www.fixya.com > ... > Amigo > Amigo Scooter Oxygen Tank Holder
... key on my phoenix 3 scooter the red light flashes 5 times and the scooter will ...scooter wont move,although on the little speedo there is a red light flashing on ... ...light is flashing when the key is turned on. the scooter does not move at all ... flash up and down the console light and you at this point have to turn the key off ...
My pharmore wizard diagnostic light flashes 9 times and my ...
www.fixya.com/.../t25197681-pharmore_wizard_diagnostic_light_flashe...
Oct 8, 2014 - my pharmore wizard diagnostic light flashes 9 times and my scooterdoes not go, can someone help me please - Mobility Scooters question. ... Have no manual for pharmore 4 wheeled wizzard light on but wont move ... Why did it stop working suddenly and is blinking console light in 5-blink sequence?
Jan 31, 2016 | Video Game Consoles & Games
Rascal Candy Apple. Why did it stop moving while I was driving it?
On the rascal, if your driving along and it suddenly stops, the throttle lever could be bad or the speed control could be bad or both. A battery lead maybe loose. The tiller cable may have slid back causing line interruption.
The flashing 4 indicates current timeout, the scooter may have been going up a steep hill, over heating the motor, turn off and allow motor to cool. then try again. if this happens on flat ground then check the parking brake, it maybe hanging up causing the motor to over work. Other trouble-shooting information for rascal, scooters on my free app.
Scooter Doctor App
Aug 11, 2015 | Health & Beauty
Will not run fault indicator flashes continually without pause
you can check to see if it is in free wheel at the rear of the scooter there shoulb be a lever make sure it is in the lock mode
Jul 20, 2014 | Mercury Prism Coloured Travel Mobility...
What dose it mean win the led power light blinks 4 to or 8 times
The sequence of beeps are for recognising the fault.A scooter repair shop given this info,will tell you what is required to get you running again.Note,you will be lucky if a repar shop will look at it if you have attempted to fix it yourself & Shoprider unless i am wrong,do not sell to the the public.
Mar 31, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
How to bypass key switch on rascal 600
hi, to bypass the key switch by removing the tiller cover, that is the cover in with the key lock is attached to.
Then all you need to do is short the pins and watch the scooter light up. how ever if there are more than two pins, take the black wire on and short that either to one of the others, do this with care not to touch any other wires within the control panel.
Regards
Please give me feedback..
Dec 20, 2012 | Rascal 600 T Electric Scooter w Seat Lift...
Celebrityx scooter blinks 5 pause 5 everytime i turn key on
Either your parking brake is engaged or if your scooter is more like mine i have a Rascal 600t it gives a code 5 service code when it thinks its in free wheel. The freewheel mechanism is located on the trans-axle which if you go outside across grass it gets wet. This device doesn't like moister and will get stiff will partially engage or disengage. In that mechanism there is a micro-switch which if the lever when slipped into the engaged position doesn't go all the way to the seated position the switch will see the mechanism as being disengaged [in free wheel] and will inhibit the motor from running. I lubricate the entire assembly with pure silicon spray oil,WARNING, do not use WD-40, It will eat some plastics.After lubricating the lever should move smoothly. I have to lub my scooter about once a month in the winter.
Now if this doesn't work check the connector that are all the wires are connected. Disconnect the connector check the pins are ok reconnect check to see if your still getting the failure. If you are still getting this problem do continuity checks on the wiring. You will need a multimeter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8 Check the switch in the freewheel assembly. Select ohms the highest scale, short the leads together, zero the meter by turning the zero adjust knob. There is only one wire we are interested in. On some scooters you can visually see the switch and the wire running from it. The wire usually goes to a spade connector. Disconnect the spade connector put a probe on that connector leading to the switch. Disconnect the battery put other probe on the positive side of the terminals that were connected to the battery not to the battery it side.Work the switch does the meter needle deflect to zero, no, try the negative side. Does the meter deflect, no, put the probes directly on the switch terminals, does the switch.when worked now cause the meter to deflect, no, replace switch, yes, the problem is in the harness, don't panic, use can use that meter to trace the wire through the harness. Wiggling wires and flexing connectors usually makes the meter flick at some point. Thats how i do it i'm never without my trusty meter. My scooter a Rascal are notorious for having problems of this type my mid-frame harness fell apart in the middle of a six lane intersection, the scooter simply locks up tight .I can do nothing but sit in the middle of this huge intersection. People try to move me but the scooters wheels are locked, my illness makes it so i can't communicate with people, it was a mess. So i modified the connector so its no longer a latch type connector. I drilled it for a quick pin which is much stronger than what its using now. Hope this helps
Jul 05, 2012 | Pride Celebrity X 4-Wheel Electric Scooter...
Light flashing on mobility scooter
Hi check if the free wheel lever is in drive ...cheers
Dec 27, 2017 | Health & Beauty
I disabled the brake on the scooter. When I enabled the brake and turned on the power, the green light flashes and cannot move forward or reverse. There is plenty of power showing on the gauge.
I need to know how many flashes you are getting of the green light. i.e. 4 flashes pause 4 flashes
Also check the freewhell lever again to make sure it is in the drive position Hope this helps
May 05, 2011 | Electric Strider Mini 4 Wheel Mobility...
My Lynx L4 4-Wheel scooter green light flashing but it said it is charge it wont go forward
the green flashing light indicates an error with the scooter. Count the number of flashes 4 flashes pause 4 flashes pause etc and your manual should give you the meaning of the flashes Check to make sure that you are not in freewheel move the lever at the back of the scooter up and down a few times and make sure you leave it in drive mode turn on the power and see if the light stops flashing and the scooter will operate correctly Hope this helps
Oct 03, 2010 | Activeforever Lynx L4 Portable Mobility 4...
Health & Beauty Logo
49 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
