Question about Garden
Parklander I AM AFTER SOME BLADES AND AN IGNITION SWITCH FOR MY XD52Z ZERO TURN PART NUM:148-005 BLADE PART NUM:700-137 REGARDS GEOFF
  • Roger Barnes
    Roger Barnes May 17, 2016
    Gravely blades are a match
defadad
  • 351 Answers
SOURCE: Blades won't engage on 23 hp 50
belt tensioner may need adjusting or the cutter head bearings may have seized,
Posted on May 11, 2009
Dolfoff
  • 148 Answers
SOURCE: CUB CADET ZERO TURN Z-FORCE 3-BLADE CONFIGURATION
Under each blade is one single nut holding each blade on. It is not left-hand thread and there is nothing special about it.
Standard thread - Standard hardware - Standard tools. (If memory serves, you need a 15/16" socket to remove these.)
There is no need to index or time the blades. They cannot hit together unless something is bent or damaged on your mower deck.
Hope this helps,
Dolf-
Posted on Oct 15, 2009
cardenderek
  • 783 Answers
SOURCE: I own a 42" Troy Bilt zero turn. The PTO switch
What the problem is (im not sure if they are called this) but the deck pulley brakes are worn out.
Basically if you look under the rider frame side (on top of the deck). There are on each side for each spindle pulley a flat metal tab. On the underside of that is just like a brake on your car. So when you raise the deck the pulley brakes hit the top of the pulleys and stop them from spinning. Which cause the blades to stop spinnign. There are probably turning at 10% of there normal speed. If that sound like what its doing check the brakes.
They are a replaceable part. Sorry I just cant remember exactly what they are called. Over the years they just wear out like a set of brake pads on your car. And the mower cuts and just work fine. Thats where I would start. When they wear out, the friction material is gone. Best Reguards, Premium FixYa Support
Posted on Jul 27, 2011
  • 640 Answers
SOURCE: I have a JD 160
Most likely cause is the seat safety switch is not functioning properly, ie. when sitting in it to allow blades to engage, if failed it will act like there is no one on the mower and the blades get engaged it will kill the engine, like having the ignition shut off.
I hope this is helpful to you.
Posted on Aug 10, 2011
  • 6468 Answers
SOURCE: Grassshopper 425 Mower - Ignition key will not turn. Blades are not engaged and it is in neutral. Any suggestions?
if the key will not turn its a bad switch even if a safety switch was bad the key would turn
Posted on Apr 08, 2012
My RZ4824 Husqvarna zero turn mower cuts deep into the grass & dirt on zero maneuvering. it also does this deep cutting with reverse. Can you help me?
Check the blades are not bent or damaged, if ok check the deck alignment from side to side, measure the distance from the floor to the tip of the blade with the blade facing forward check both r/h and l/h blades.
Jul 24, 2017 | Husqvarna Garden
Why aren't the blades engaging all the time?
Faulty connection or partially broken wire, from ignition to blade engage switch or from engage switch to electric clutch.
Aug 07, 2015 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
I have a Toro 42 zero turn mower and the blades stop turning while mowing. The PTO switch knob melted. I replaced the PTO switch and the blades turned for 5 min. and then the PTO switch melted again.
Elertric blade drive clutches are a real pain when they go wrong
It sounds like a electrical short is causing the wires inside the switch to heat up beyond the safe melting point thereafter five mins the circuit gets between the fault gets broken as the switch fails the blades stop and the switch melts a bad eaRth corroded may cause this check the deck safety switches are not exposed e.g. they been damaged and the decks metal is shorting them out
a wire has been stripped of protective covering and is touching some metal shorting out something that vital to the blade controls operation the switch is getting a overload and subsequently melting your might need an lawnmower engineer to diagnose to the fault fully and repair
Apr 23, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
How do I change blades on a toro 42 in zero turn
Lift front of machine and secure,
Use a pipe wrench over top of blade and against deck, to keep blade from turning,
Use 1/2 " breaker bar to loosen bottom bolt,
Remove blade,
If the bottom bolt doesn't loosen, you may need a wrench at top of deck, above the bottom bolt, to loosen the bottom bolt.
Replace, or sharpen blades, install in reverse order.
GOOD LUCK FRIEND.
Sep 16, 2014 | Toro 42 In 22 Hp Kawasaki Vtwin...
Why when riding along mowing and the blades just quit turning, belt is not off?
If you hit a bump too hard, I believe it's equipped with a shock sensor that shuts down the blades or if you slightly lift off the seat the blades will shut off. If this is the case simply stop and restart the blade switch. Hope this helps
Jun 08, 2014 | Mustang Rzt 50" Zero Turn Riding Lawn...
Toro timecutter42 blades squealing and won't turn
just had a guy tuesday bring me a zero turn that did the same thing xcept his fell off his trailer ramp and bent one of the blade spindles so now blade digs into cover , engine off blades spin sort of free?
May 07, 2014 | Toro Zero Turn TimeCutter MX Series MX4260...
Toro 42 " Zero Turn; In tall grass and even in moderate grass it is leaving a double strip of uncut grass, that lines up with the division between the centre blade and both outsice blades, resulting in...
Your blades may be erroded on the edges? Or the center blade hub might be damaged or worn.
good time to inspect all the blades and spindles for wear or damage.
Jun 26, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
What would cause my craftsman zero turn to die when i engage the blades?
First, sort out between two possibilities: 1. The safety system is killing the engine -- for example, if the seat switch is faulty or misadjusted, the engine ignition is killed when you activate the blade engagement switch. 2. The blades, spindles, or belts are binding or stuck, which would "drag" the engine to a stop. I suggest you remove the belt that drives the mower from the engine. If the engine still dies when you engage the blade switch, it's problem #1. Check all connections, and check the seat switch with an ohmmeter. If the engine does not die, then you have mechanical drag. With engine off and the belts taken off, turn each spindle to find out if one is frozen or binding. Good luck!
Apr 05, 2010 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Removing wiper blades
6eb8291.gif To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Turn the ignition switch to the ACC.
  3. Set the wiper switch to the PULSE.
  4. Turn the ignition off when the wipers are in the innerwipe position.
  5. Depress the wiper blade clip button
  6. Remove or disconnect the following:
    • The wiper blade from the inside of the wiper arm
  • The wiper arm out through the opening in the wiper blade
  • To Install:
    1. Install or connect the following:
      • The hook of the wiper arm through the wiper blade opening
      • The wiper blade pivot into the inside radius of the wiper arm hook
      NOTE: Pull the wiper blade until the pivot locks into the hook.
    2. Check wipers for proper operation.
    Mar 30, 2009 | 2003 Pontiac Montana
    Garden Logo
    53 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
