Question about Garden
Garden master 5020d belts
What type of belt is used to drive the wheels?
crayzeetrayn
  • 837 Answers
SOURCE: replace motion drive belt garden tractor craftman 917273080
On what make and model riding mower ..
Posted on Jan 19, 2009
  • 3 Answers
SOURCE: New belts on Garden Star Tiller but now no neutral
It may be your belt tension or you may have the wrong belt it may be to short.
Posted on Mar 15, 2009
  • 57 Answers
SOURCE: replace drive belt
Not an easy fix. There are likely 2 belts which should be replaced as a pair. Engine pulley must be lowered to remove long belt. Pay special attention to belt routing. Most times small belt requires removal of transmission pulley. Good Luck.
Posted on May 15, 2009
  • 57 Answers
SOURCE: need owners manual
Sears.com should have this. You will need actual model # from underneath seat.
Posted on May 21, 2009
  • 148 Answers
SOURCE: is it very difficult to replace the mower blade
No actually it's pretty simple. You have to remove the deck. If you have the manual it explains the steps for deck removal and belt replacement.
If not go to www.managemyhome.com and download a free copy of the manual.
If you have any questions report back and I'll answer your questions.
Mike
Posted on Aug 21, 2009
Model 944.601380 Wouldn't pull up even a small hill. How thick should the rubber on the friction disc be? It doesn't seem worn but that is all that I can see drives the wheels. Can't find any belts to...
If it is a Craftsman riding mower, it has to have a drive belt unless it is shaft-driven. Its behaving precisely like a mower which has a drive belt that is so worn its "hanging by a thread - literally". That's why it won't pull a hill but is OK on level ground. You need to replace the drive belt, but you need to find it first. Consult your manual about what belt to use (you can get it at Sears) and the routing pattern.
May 24, 2016 | Craftsman Garden
How to change drive belt
  1. Step 1 - Loosen tension and remove belt. Locate the adjustment fastener and loosen it. ...
  2. Step 2 - Inspect drive and drive pulleys. Check the drive and pulley wheels. ...
  3. Step 3 - Select correct replacement belt. ...
  4. Step 4 - Install V-belt. ...
  5. Step 5 - Correctly tension new belt. ...
  6. Step 6 - Start the engine.
Mar 24, 2016 | Huskee Tractor Replacement Riding Lawn...
Garden master tiller 5020d
Get behind the tiller as if you are ready to use it. Look down towards the tines. There's a protective cover. Remove it and you will see the belt running vertically between the motor and the tines.
May 08, 2013 | Ardisam 5.5 Hp Rear Tine Rototiller
Belt routing on a 60 inch toro grounds master 220
You are almost there with what you have. Just get the belt around that third pulley that you don't have it on yet. Have someone hold the tension wheel lose while you get the other pulley in the belt loop and then let go of the tensionor.
Oct 20, 2012 | Garden
I have a Honda HRR2165VXA mower that is having issues with the smart drive.
hello, hello, Drive belt replacement for front drive mowers. remove the belt coved on top of deckand clean out grass,turn mower on side where carb is facing up,use a pair of vice grips on side of mower deck so the blade can stop,remove the blade,remove the belt cover and clean out the grass,remove belt from rear and front pulley pulleys. install new belt,put belt cover and blade back on,put front belt cover on, should work,if that is not the problem; wheels will not prepeal the mower,wheels turn only when raised off ground, Check the gears or groves on the inside of the wheel for access wear that is a common problem,check the axle drive gears to make sure turns ok, to check gear box if ok pull mower back wards while drive is engaged,if wheels turn backwards than the trams is bad,all of this is caused by the operator,by not disengaging drive while pulling mower backwards or by holding mower back not allowing to propel self completely,hope this helps,any comments welcome,thank you.
Feb 15, 2012 | Garden
Fix belt on 1200 sportster 0
I assume you want to know how to replace a final drive belt on a Sporty. First off, be glad you ain't working on a Big Twin. Sportster's are much easier than Big Twins to replace the belt on.
First, get the bike off the ground where you can remove the rear wheel. Then, remove the rear shock on the right side. Remove the bolts from the rear master cylinder and the large nut that holds the right foot peg on. Remove the front pulley cover.
Take the new belt and install it with the right leg of the swing arm through the belt. You may can work the belt over the front drive pulley. If not, use an air wrench to remove the pulley and install the belt. Retorque the pulley to 110-120 foot pounds. Remember the threads on this nut are left handed.
Reinstall the rear wheel and shock absorber. Adjust the belt to the proper tension. Then replace the front pulley cover and rear master cylinder.
Check the rear brakes for proper operation.
Good Luck
Steve
Jun 14, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
How to change engine belts on a jaguar x-type 2003 3.0
To Remove BELTS : Drive Belt :
Disconnect battery ground cable
Remove wheel and tire
Detach accessory drive belt
detention drive belt
detach accessory drive belt
Remove accessory drive belt
slacken the tensioner
remove accessory belt drive
Install in reverse order
WATER PUMP BELT : Remove battery tray
Remove water pump belt
De-tension water pump belt
Installation in reverse
Hope this is helpfull
Jul 11, 2009 | 2003 Jaguar X-Type
Mar 14, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
