Question about Electrical Supplies
Mosa generator spare parts
My mosa ge 5000 sx diesel generator is not producing any power,suspect alteranator.
4 Suggested Answers
  • 1388 Answers
SOURCE: Generator dose not produce power,just stop working.
Check the rectifier board installed under gen cover that powers the brushes. This board has a capacitor about 1 inch long and 3/4 inch dia. If the capacitor looks swollen or burned replace board or carefully remove cap and replace with similar. You can use a larger capacitor with same rating, just tie cap to rear cover. Also check the condition of the brushes. Parts are not too expensive. Check with jacksmallengines on the web for parts. enjoy
Posted on Dec 05, 2008
  • 211 Answers
SOURCE: coleman 5000 generator will not idle up under load
Hi
You have to find the governor linkage.There is a spring adjusting by a screw to increese speed to get more power.Try to locate it.
best regards savumihai71
Posted on Feb 03, 2009
CarlGehrke
  • 169 Answers
SOURCE: gererator stops producing power
This sounds like a "flying open" in the rotor. Over time a small part of the wire that winds around the rotor has gotten cracked just enough to open up when it's warm and being pulled on by the force of the rotor spinning. To test this further, take the wires off the brushes and connect an ohm meter across them then run the generator, if you see the ohm meter indicate an open circuit you've found the problem. This can be repaired but it means removing the rotor and finding the weak spot in the winding. You could replace the rotor for a couple of hundred dollars or get a new generator.
Regards,
Carl
Posted on Mar 01, 2009
A diesel engin uses diesel fuel generates low power at low speed
Increase the speed for constand power output, or check the load it maybe more than the genset can power.
Apr 03, 2017 | Speed Electrical Supplies
Where can i get spare parts for a hyundai hy3000si generator [ie] voltage regulator
voltage output readings are governed by rpms of the motor
check that the engine rpms are correct by adjusting the governor setting
contact hyundai generator service center for parts
Jul 23, 2016 | Electrical Supplies
ETQ generator DG4LE cut off value under tank broke and no fuel comes thru
syphon the gas out,tip it up so whats left will not come out of the hole for the shut off,unbolt the shut off and it should be part number,ETQ 17150,,,or whats on the pic
http://theportablegenerators.org/manuals/ETQ/Diesel-ETQ-Gen-178F.pdf
http://theportablegenerators.org/manuals/ETQ/Diesel-engine-DG4LE-DG6LE-manual.pdf
May 12, 2015 | Eastern Tools & Equipment ETQ DG4LE 4,900...
5000s diesel will not start even on ether
mmost engines have a low oil switch. if generator is not level or it is low oon oil by just a little it will not start hope this helps bob
Mar 04, 2013 | Pramac Diesel Generator 5500 Surge Watts,...
I have a 6500 lp onan marquis generator in my rv. It starts then stops after 15 seconds or so. I did a code check on it using the manual and it read code 47. Controller not reading generator running. Any...
ONANS ARE PRETTY QUIRKY AS IT IS NOT CONSUMER FRIENDLY. THE GENSET IS DESIGNED FOR ROUTINE AND SIMPLE MAINTENANCE PERFORMED BY THE OWNER, AFTER THAT, U WILL NEED TO TAKE IT TO THE NEAREST DEALER OR CUMMINS DIESEL REPAIR SHOP.
Jan 10, 2010 | Watts Onan Portable Generator - 5000 ,...
Hi I have an eagle power generator (E65DRE) and it will not generate power. All the coils and components are alright. Do I have to (excite) the generator after it has been sitting for a while? Has any one...
Yes, that's exactly the issue. You should run it once a month to avoid this. Generators can't sit for a while or they will loose the charge that excites the coils for producing power
Sep 07, 2009 | Eagle 10000 W Portable Generator
Gererator stops producing power
Regards,
Carl
Feb 23, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman 5000 generator will not idle up under load
Hi
Feb 03, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
