Question about Canon I-sensys Fax-l150 Compact And Stylish Super G3 Fax
L150 dark copy
Dark copy
What will be the reason for canon sensys fax-L 150 coping dark page but faxing and printing is ok.
First things first. Try and print report from the fax. Any kind of report. If it is printing OK, then the next step is to check if:
Your clients receive your faxes OK? If they are dark as well, then your scanner head is at fault.
When you make Copy on your fax and it prints dark it could be simply set with dark settings _or_because of the white calibration strip or roller being soiled or dirty, which acts as the ultimate white reference point for scanner _or_ the Scanner CCD sensor is in paper jam release position (too far away from reading the originals) just pull it back to normal feed position.
Or simply faulty scanner.
Sep 30, 2016 | Canon i-SENSYS FAX-L150 Laser...
IF CONTROL PANEL IS OPEN,CLOSE&PUSH UNTIL LOCKED,SO,HOW CAN SOLVE?
Try unplugging it for a few moments they plugging it back in.
Feb 24, 2015 | Canon i-SENSYS FAX-L150 Laser...
Konica 1212 copies to dark
1st the basic cause of dark/grey copies DUST. Clean w/ alcohol cloth then dry cloth totally all mirrors and the platen glass both side. If still dark check the "Optic slit " right in the upper of your halogen lamp remove it, still dark Check your halogen lamp maybe it already oxidized. The last solution adjust the CVR .
Nov 27, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
How to reset factory
HI
how to reset factory canon L150
Jan 25, 2014 | Canon i-SENSYS MF4140 All-In-One Laser...
Canon l150 error code 225-0001
How to resolve the code 225 in Canon Fax 150?
Jan 24, 2014 | Canon i-SENSYS FAX-L150 Laser...
Coleman York L150-40f Limit Switch
Johnstone Supply carries York parts. They are also on the internet.
Jan 22, 2014 | Coleman York L150-40f Limit Switch 356208...
Canon Fax User Manual
hi
I need to CODE reset factory default printer
model : CANON L150
Apr 23, 2013 | Canon i-SENSYS FAX-L150 Laser...
Canon IR3570 Factory reset
how to reset cannon ir 3570 photo copier
Apr 07, 2010 | Canon Office Equipment & Supplies
Cant find download for drivers xp think vision L150 moniter
you dont really need a driver for this monitor but here is a link to where you can get the color setting and so on for it. click here
Nov 30, 2009 | IBM ThinkVision L150 (Black) 15" LCD...
Canon I-sensys Fax-l150 Compact And Stylish Super G3 Fax Logo
69 people viewed this question
old marine
old marine
