Question about Garden
I have a Flymo strimmer/cutter model MET 850DL. I need a spare part for the bottom of the device where you roll on the plastic cord. Where can I get such a part in Cape Town area?
SOURCE: how do you put the plastic line into the flymo
how do i replace nylon line in my flymo
Posted on Jul 10, 2009
  • 50 Answers
SOURCE: i have a flymo ct250 strimmer. when charged the
could be battery or just needs grease inside the shaft
Posted on Oct 16, 2009
bbreton
  • 437 Answers
SOURCE: How to remove the 'governor?' so that I can remove
What you are calling the "governor" is accutally the clutch drum. The is a screw in the center that needs to come out, then you will need to remove the clutch with a small punch and small hammer, by unscrewing it. Then you should be able to get to the recoil assembly.
Hope that helps.
Good day, mate.
Posted on Oct 23, 2009
jdlipscomb41
  • 157 Answers
SOURCE: I'm looking for a Flymo XLT 250 Strimmer manual
check on ebay.com for what you need thanks jd
Posted on Oct 27, 2009
bbreton
  • 437 Answers
SOURCE: Hi Good Day I wonder if you could please help
Wendy, Have you tired going to www.flymo.com.
I went to that site and for the durban area, they showed three service centers. You might have more luck doing a search yourself because my geography of South Afirca is a bity rusty.
HTH
Posted on Dec 14, 2009
How to replace the switch on a flymo grass strimmer.
Hi Johnstone
Before replacing the power switch, try some other approach or you have need to analyze first. I have a question for you, Is your strimmer a cord less unit ? or with ac cord? If its cordless unit so its a battery operated, if so, try to check the battery. But if its with cord or ac cord, try to check the continuity of ac cord by using multimeter or ohm meter,
Jun 04, 2015 | Cars & Trucks
How do I replace cutting head in a Flymo contour 500 strimmer?
Stan try winding the cord in the opposite direction. It may just be wrongly wound.Also make sure it's the right diameter.
Jun 27, 2014 | Garden
I need to replace the cutting cord on my Flymo Contour 500 XT strimmer but cant get the cap off, please advise
the cap has left hand threads so to loosen it turn it like you would tighten most other bolts
Aug 07, 2012 | Garden
Spool cover required for hg500b grass trimmer
Hi, mine broke yesterday (Sovereign HG500B Grass Trimmer). I took the grass trimmer to Homebase but they've told me that this model has been discontinued and they don't sell spare parts for it. I believe it's still within the guarantee period so if I can find the reciept they'll organise some sort of replacement, but if I can find somewhere that sells a replacement spool cover I'd rather just buy that and replace it...so far no luck.
Aug 04, 2010 | Garden
I have a flymo ct250 strimmer. when charged the
Sep 19, 2009 | Garden
Lack of information before purchase
Hi. I think I can put your mind at rest.  I work in a Flymo service agency. The Flymo Contour Cordless Power Plus has a guide wheel for accurate edging but, in common with all other Flymo edgers and trimmers, the actual cutting is done by a whirling thin (1.5mm) plastic cord that is designed to wear out and is fed from a replaceable reel under the cutter shield.  The only risk in cutting up to stone, concrete or other hard material is rapid wear of the plastic cord.  Unless your step is made of exceptionally soft stone there is no reason to think that the step will be damaged at all.
Good luck.  If this helps, please rate my response.
Apr 14, 2009 | Vacuums
Ryobi petrol strimmer model RCT 2800 refuses to start
Has anyone got a spare cord Pulley for a Ryobi RCT 2800C . The engine seized but I have freed it and now see the plastic spines are damaged on the pulley. I understand the part no is Hayter 683856.
Nov 07, 2008 | Garden
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
