Panasonic Mini split, ductless system
How do you change from C to F on the remote(A75C3712)of a Panasonic mini split, ductless system?
3 Suggested Answers
  • 674 Answers
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
Posted on May 03, 2010
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
User manual. Where can I get a copy
Pioneer Mini Split AC - Wholesale Prices, Open to Public‎
Adwww.highseer.com/Pioneer-HVACInformation & Support
Download Manuals, Parts Diagrams
Sales, Technical Brochures & More
Nov 08, 2015 | Pioneer Ductless Mini Split INVERTER Air...
Panasonic mini split air conditioner css9nkua. what does run code h99 mean?
H99: Indoor heat exchanger anti-freezing protection
Causes: - Insufficient refrigerant;
- Air filter dirty;
- Clogged cross flow fan.
Apr 29, 2015 | Panasonic CS-S9NKUA Ductless Mini Split...
I have a goodman mini split.The remote is set to celcius,how do I get it to fahrenheit.model WMH24-1A
To change from Cecilius to Fahrenheit on the remote control, hold both the + and the - simultaneously and this will enable you to toggle between C and F. You will need to do this each time you change your batteries.
Aug 14, 2011 | Sanyo 09KHS51 Ductless Mini Split Air...
GE split air unit.remote is intermittent.I have 2 remotes same problem. Should I replace the display board or the pc board it plugs into?Which one controls the signal?
Replace new batteries and check. Switch off ac,remove any dc wire from indoor unit and then re-fix it.Now try. If still problem, repair/replace PCB
Jun 01, 2011 | GE Quiet-Aire Ductless Mini Split System...
May 02, 2010 | LG LA185HV Split System Air Conditioner
Air con stuck on cooling mode!
Is this a Mini Split Ductless type Heat pump? Has it worked in the heat mode for you before? Have you tried killing and reapplying power to both the indoor and out door sections? Does it have a wireless remote? Are the batteries new in it?
I have to assume a lot because there is a lot of information missing to really know how to help you.
If these items helped would you please grade me accordingly. Thank you and GOOD LUCK.
Mar 03, 2009 | Panasonic Heating & Cooling
Mini split AC's
they are excellent and very efficient sytems
i have a muti pass ductless in my home and swear by it so much i went to school for them
I am now a mitsubishi cert expert
and cannot sing the praisees high enouhg for the ductless systems
Jun 14, 2008 | GE Quiet-Aire Ductless Mini Split System...
Stand By Mode
1. use remote properly
2.first off the unit then again the unit
3 if same problem change remote by new one
Mar 18, 2008 | Sanyo 24KS62R Cool Mini Split Air...
Broken remote control of a continental electric minisplit
RemoteControlDirectory.Info/ just click for information the best remote cxontrol for aircon.
Jan 06, 2008 | Continental CE-AC75271 Ductless Mini Split...
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
