Question about Mackie Onyx Blackbird Premium 16x16 FireWire Recording Interface
How to stop firewire light flashing
Firewire light keeps flashing
CHANNEL MONTIOR LIGHT WILL NOT STOP FLASHING
You've pressed the "solo" button by accident.
Jun 01, 2014 | Allen & Heath Xone:92 DJ Mixer
I have mine on the dmx setting for it to turn constantly and it's stopping and starting irratically flashing on and off so I'm getting hardly any effect from it at all I'm thinking it's a problem with the...
I am not sure if you are using a DMX controller or a standalone setting. If on standalone, sound triggers a random reversing, stopping and flashing mode. I am NOT sure that a stationary mode is available without being commanded by a DMX controller. If you are using a DMX controller get back to me and we will analyze what the problem is. If using a DMX controller, tell what address you are using and the length of the control cable.
May 01, 2011 | Chauvet 2) Chauvet Double Derby X Dmx Led...
With my pc, the presonus firestudio tube got solid blue light but it makes audio cripples, with cubase it can't make the asio multimedia setup. i have latest driver and firmware
Check your latency settings and try something higher that what it is currently set to. 1024 samples is usually a good starting point for most newer PCs.
Feb 23, 2011 | PreSonus FireStudio Tube Audio Interface...
Is there an aftermarket mackie onyx 1640 firewire interface?
The Mackie 1620,1640 or 1220 mixers are designed to be used with this card. Here is a link for you:http://www.mackie.com/products/onyxfirewire/
Nov 03, 2010 | Mackie Onyx Firewire Card
I have the dreaded all lights on on my Tascam fw1082
I would vote for a power supply issue on this one.
Jan 26, 2010 | Tascam Music
Power light flashing but getting nothing through the tower
If the fuse went, there probably is a failure. To avoid further damage, if you replace the fuse, put a 150 Watt lamp in series with the hot power wire. Make an adapter to do this safely.
The lamp will light instead of the fuse blowing and hitting the amp with a high current surge that could do more damage. If the lamp goes out, it is probably safe to operate.
I would recommend carrying a spare amp with you... These Passport systems are HARD to work on due to the way they are assembled.
Nov 14, 2009 | Fender Passport Deluxe 500watt Sound...
Pc not recognizing phonic helix 18 universal mixer
I have a Yamaha AW1600 and I had to go into my firewall settings and add it to my exceptions to allow the program access to my computer through the firewall. This may help. Thanks!
May 30, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Mackie Onyx Blackbird Premium 16x16 FireWire Recording Interface Logo
231 people viewed this question
Top Mackie Music Experts
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
