Question about Garden
John deere ltr180 diagram
Mower blades lose power when cutting
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
SOURCE: John Deere Lt 166 ride on mower
jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
Posted on Jun 21, 2009
  • 10865 Answers
SOURCE: John Deere LA110 mower blades got disengaged
yes. your mower has a blade engagement cable attached to the drive sheve. i am providing a link to the manual which shows this.
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
Posted on Jun 25, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
nova2nv
  • 197 Answers
SOURCE: my john deere lt 133 mower with a double blade
This model mulching deck uses a flat/ribbed serpentine belt that is set at very high tension.When belt breaks under the cover only one blade will turn due to IT being driven from PTO clutch as the other blade being turned from serpentine belt.This deck was Deere's first and last shot at making a true mulching deck and only made it a couple years.When you buy the VERY expensive belt it will come with detailed instructions on how to install it.Goog luck.
Posted on Nov 14, 2009
John deere d110 not cutting grass
check belt and pulleys --if belt to loose wont turn blades to cut the grass
Aug 31, 2016 | John Deere D110 42 in. 19.5 HP...
I need a belt diagram of John Deere L120 mower deck
Belt path for JD 100 series, 42" cutting deck, 2 blades.
Sep 14, 2014 | John Deere L100 Series
I need a diagram of a john deere L110 riding mower's blade engage
You go to searspartsdirect.com enter the model number and get the manual for any lawn mower
Jul 17, 2014 | John Deere Garden
Why does the engine slows down when engaging the blade
check fuel filter and pump pressure starving for gas
Jul 02, 2014 | John Deere Garden
I wish to know which direction do i turn the bolt to take the cutting blade of a john deere ride on/ clockwise or anticlockwise?
As you are looking at the blade and bolt from under the mower, if the blade is rotating counterclockwise, then the blade bolt is standard threaded and will turn counterclockwise to loosen. If the blade is turning clockwise, then the bolt is left hand threaded and will turn clockwise to loosen. John Deere produces mower decks with both setups.
Dec 30, 2010 | John Deere Garden
Blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Jun 07, 2009 | Garden
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
