Question about Icom Operation, Alignt Data On A cd For R7100 R 7100
Icom 710 marine ssb
No tx no tune
  • Icom Master
  • 17,093 Answers
BLown PLL circut.
Posted on Jun 10, 2013
ICOM M802, can't run SEA 1612C coupler.
uk-repair.com/repair/hard-reset/icom-radio-marin-ic-ssb-m802/369/6891.html
Try this site
Oct 18, 2017 | Icom Radio Communications
It is a MF/HF transmitter JRC 196GM, when I pressed on TX Tune on the sender it says on display No ATU
Details on the unit are here
http://www.jrc.co.jp/eng/product/marine/product/jsb196gm/jsb196gm_outline.html
Something isn't right with the connection to the unit and antennae. Did you use the proper factory parts?
Component Model Quantity Remarks
Antenna Tuner NFC-196 1
Included Accessories
ATU Control Cable 7ZCJD0044A 1 L=5m
ATU RF Cable 7ZCJD0045 1 L=5m
Terminal 5JTCD00393 2 1.25-3
Terminal 5JTCD00001 2 2-3
Terminal BRTE00395 2 5.5-3
Washer BSFW06000B 2 W6Bs
Check out Post number 4 in this forum and the following posts. Different unit, but similar problem
http://www.cruisersforum.com/forums/f13/icom-ic-m801e-with-manual-tuner-91425.html
Sep 23, 2015 | JRC Boating
How to change frequency of ssb fs-1503
For direct frequency input: i.e 2061.4khz transmit - (TX), (2), (0), (6), (1), (4), (ENT) - use (RX) for receive frequency.
For ITU channels - (CH), (4), (1), (2), (ENT)
Direct frequency inputs are restricted to authorized marine band frequencies.
Jun 09, 2014 | Furuno FS1503 HF SSB Radiotelphone EMail...
How to repair Icom IC-M700 HF transeiver?
Does it have an external speaker plugged in the back? If so try unplugging it see if the internal speaker works, if it doesnt have an external speaker plugged in try one, maybe the internal speaker went bad from moisture.
May 28, 2014 | Icom M700 Pro - IC AT-130 automatice tuner
Icom ic-m35, no transmitting
Contact the Icom service center. Their main web-page is www.icom.com. From there you can select your geographic area and service (commercial, marine, amateur, etc).
Aug 17, 2013 | Icom IC-M36 VHF Marine Radio
Icom m505 no rx
See the sensitivity if it is low then change the filter (wide) of your Radio.
May 23, 2013 | Icom M505 VHF/DSC Marine Transceiver -...
Icom 7410 won't transmit in SSB works in CW and RTTY
I'd contact Icom, if its under warranty get it fixed
Jan 18, 2012 | Icom Radio Communications
I have a Philips GPS Dantronik Navigater MK9 an now a Northstar VHF Marine Radio Explorer 710. I want to connect both over NMEA to get the position form the GPS to the radio. There are 7 different...
I connected my ICom using the NMEA in. I had the leads reversed first time, moved them around and worked. This was a connection from Furono to iCom but should be much the same
Jun 01, 2010 | GPS
Off freq on ssb TX.
.002 Mhz is really not that much off, try having them tune to your signal When I talked SSB I would have everybody tune to my signal.
Jun 09, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
SSB radio
If you are using the radio on a boat, then no, the grounding does not matter that much. However, an SSB transceiver would be hassle to install on a boat because of the amount of power they use to transmit. If the transmission is bad, try using the radio's internal tuner instead of the separate tuner. This may help improve the quality of transmit, however, some radios have a tough time clarifying incoming and outgoing signals and create a garbled sound when it receives a signal or when it transmits. If that doesn't work, then you can try grounding. But if you want a radio that doesn't require all this nonsense tning, you might want to think about investing in a Yaesu. They are pricey, but are one of the best HAM radios.
Sep 04, 2008 | Ranger TR-696F SSB CB Radio
Icom Operation, Alignt Data On A cd For R7100 R 7100 Logo
79 people viewed this question
Top Icom Radio Communications Experts
Steve
johncassells
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
