DSP PCB 06B885-22
Where can I buy a replacement part DSP PCB 06B885-22? It's an effects board.
2 Suggested Answers
  • 73 Answers
SOURCE: Where can one buy a replacement pcb control board for a iomega 'ultramax plus' unit? My existing one has a damaged IC component at 'U4'....and possibly more elsewhere on the board.
No one sells what you're looking for. I'm assuming the drives were in a raid configuration which means you can't put them in an enclosure to get the data off. Your best bet is to purchase another unit and replace the drives. This thing is hella expensive. If you don't need the data you can get a different one bigger and cheaper. http://www.sears.com/iomega-33991-esata-firewire-800-firewire-400-usb-2.0-500gb/p-00389575000P
Posted on Oct 19, 2012
Testimonial: "."
No effects output xenxy 1204fx
Likely needs the DSP board replaced. It is the small board held on by 2 screws(if I remember correctly) and is easily replaced. I think retail cost is about $30 and can be ordered directly from Behringer.
Aug 03, 2013 | Behringer Xenyx 1204fx
Crate flexwave 120 tuner and all effects stoped working
Hi there,I have the same problem with my flexwave 120. I opened the amp to measure several capacitors on the small effect circuit board. If one of this capaciters have internal short circuit, wich will effect the others causing effects to fail. I removed them one by one to find possible short circuit. All capacitors were ok. I think the problem is in the processor wich is to diffucult to replace. I think it's easier to replace the effects circuit board. But where do we find this board??10_29_2011_6_25_35_am.jpg
Aug 07, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
I need to know where I can buy a "grate gtx 65 dsp circuit board the board number is 06B885-20. the existing board is beyond repair!
THe CRATE board is not available anymore. This is the DSP effects board for GTX, RFX, and Taxi amps. If you can find an old one of these units, they are interchangeable directly.
Jul 30, 2011 | Audio Players & Recorders
I just picked up a sylvana lc320ss9b it has a cracked screen i was wondering what to do
Sorry the tv it is worthless as a whole tv set.Very exspensive if tries to fixed.By replacing the tv LCD screen panel it is not possible,because the tv LCD screen panel will cost the same as a new tv.Because u only can buy the tv LCD screen panel by the tv corporation themselves only,they'll sell it to u but they charge u like a new tv for the LCD screen panel.Tv set now only can be used as salvage tv only for it PCB boards only now,for other tvs to used as salvage tv electronic PCB boards only for repair for other tvs as for PCB boards as parts that it.
Jul 30, 2011 | Sylvania LC320SS9 32 in. LCD TV
My new (used) Sony Trintiron recently took a fall and the screen was damaged. The damage appears to be a gash approximately 4-41/2 inches long and 1/4 inch wide. Is there a way I can fix this or get a...
The tv CRT-(tv tube) screen itself is broken now or dying already and tv PCB board broken require replacing too,tv will still work after replacing PCB board or repairing it but tv will not be watchable becauuce tv screen will all mess up like screw up picture colors will have black and blue colors be all over the tv screen.Tv now will not be worth repairing if require replacing CRT-(tv tube) will cost the same as a new tv if tries replacing CRT-(tv tube) if u still can buy it.Can't buy analog CRT-(tv tube) anymore.Sorry time to buy a new tv.
Apr 14, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
On any channel I've begun to get a intermittant
If this has a digital effects processor read on.., I had a SIMILAR problem on a Behringer GX110.
The electrolytic filter cap for the 5 volts of the DSP effects had gone bad. The 5 volts was dipping when the DSP reset and it would repeatedly reset causing a clicking at about once a second. 50 cent part fixed it. The part is a little undersized electrically so is more prone to failure in the unit I have.
That particular one had the DSP as a seperate board with its own 5 volt supply from the main transformer.
Dec 18, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
My effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Oct 19, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
DSP Card (Onkyo TX DS787)
You should be able to get this directly from Onkyo. What is the problem tthat leads you to believe that the board needs to be replaced? Realize that the board could cost upwards of $100 or more.
Dan
Dec 16, 2008 | Onkyo TX-DS787 Receiver
Pioneer VSX-36TX popping and crackling during warm-up period
I have the exact same amplifier with what sounds like the exact same problem. I opened up the amplifier, and while it was powered on started tapping around until I heard the popping and crackling suddenly increase. I was using a piece of wood and the plastic part of a screw driver for this. The popping and crackling suddenly burst out onto all channels when I was tapping on the DSP board (encased in a metal enclosure to the very right of the amplifier).
I took off the metal enclosure (with the receiver turned off, of course :), and with the receiver on, and started tapping around the DSP board, and I found that the biggest crackling effect was achieved when I tapped on the Cirrus Logic CS493292-CL chip which does all the decoding and switching.
I detached and took out the DSP board and looked at it very carefully but of course couldn't find any bad connections. I tried resoldering all the feet of the Cirrus Logic chip and many many components all around to no avail.
Finally I tried applying pressure to the chip while the popping was going on, and it stopped. Further investigation revealed that bending the board around the chip produced the same effect.
For the life of me I couldn't figure out why bending the board eliminates the problem, but my solution was to put a piece of eraser wrapped in masking tape and taped to the Cirrus Logic chip, and two other pieces on the back of the board in such a way that when the metal enclosure was replaced onto the board, it put gentle but firm pressure onto the Cirrus Logic chip and at the same time bent the DSP board slightly.
It's been a few days without popping, clicking or static, but time will tell. Good luck!
Oct 31, 2008 | Pioneer VSX-36TX
HTR-5240 Will not play audio when switching to DSP
Most likely your DSP board is bad, usually a pretty costly repair and sometimes the board is hard to find in stock.
DSP--Digital Signal Processor
Dec 01, 2007 | Yamaha HTR-5240 Receiver
54 people viewed this question
 Grubhead
Grubhead
