I am unable to set up my old electrohome tv with my new philips univeral remote. Is the philips universal remote compatible with my electrohome tv? do you have any codes for me to try? i have tried the two in the book but they don't work. i have tried the code search and that didn't work either.
Me thinks IF you tried the 'code search' function and none worked, I sincerely doubt if any other 'codes' will marry your Philips Remote to your electrohome TV.
This is because your "SEARCH" effort already went through ALL of the possible codes THAT Philips Remote knows and can deliver. It is also possible that a different MODEL of Philips Remote MAY stumble on codes that DO work!
IF you have a 'original' remote, SOME NEWER remotes can LEARN the proper codes from the original remote! BUT you NEED that original remote to send the desired IR data pulses to the smart student remote.
And GOD ~ those TV's are SO OLD, did they even HAVE remotes??
Anthony
SOURCE: TROUBLE PROGRAMING
I have a jumbo universa remote....can you tell me how to programme a viewsat extreme (fta)
SOURCE: remote codes for "ph301s" universal philips remote
www.remotecodelist.com .............................T.
SOURCE: Code search for Philips PH301S universal remote
Go to any store that sells universal remotes, such as Walmart. The codes for different TVs are listed in any new universal remote control package. A new one only costs $10.00 or so anyway!
SOURCE: i lost my remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
