Question about RCA L32HD31 32 in. LCD HDTV
Need 3 Digit Dish Network Code for Proscan TV PLCD3717A
Just purchased the tv and cannot get the Dish Network remote to respond to Dish setups...Help !!
SOURCE: User Guide for Proscan TV
http://www.oncorpus.com/down/ENG/42LA45H%20English%20UM.pdf
Posted on Sep 18, 2008
  • 3 Answers
SOURCE: missing code for comcast remote to work new rca tv
Hit tv then hold the setup button untill in flashes....then you type in 991 and then hit tv power tv power.... untill your tv turns off when it dose hit setup to lock the code
Posted on Jun 11, 2009
SOURCE: RCA L32HD31R/Dish Network Remote Code Problem
The word from RCA technical support is that the remote for the L32HD31R operates on a different frequency and there is currently NO universal remote on the market that will work with the set. They say that they have plans to market a universal remote and that they are working with other manufactuers of remotes but there is no resolution or time frame available. In short, you will have to use two remotes and keep checking the RCA website for a breakthrough.
I'm not sure that I would have bought the TV if I'd known.
Posted on Aug 21, 2009
SOURCE: I have the RCA model L32HD31R LCD TV and I need
I have a RCA model L32HD31R LCD, also but the codes from comcast will not turn tv on or off.
Posted on Oct 06, 2009
  • 3 Answers
SOURCE: Comcast Remote Codes for a RCA L32HD31R LCD TV Also Panasonic
Hi Attychase,
Comcast actually has several different remotes for their different set-top boxes and the remote codes aren't always the same. They list all of their current remote devices on the following page. If you click on view manual it will give you a list of remote codes.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Hope this helps.
Posted on Nov 20, 2009
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
Need tv code to enter into remote dish remote cannot find it
Need tv code Robert, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
By Code MyDISH DISH Customer Support
http://www.dish.com/remote-setup
How to Program Dish Network Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
May 03, 2016 | Televison & Video
Need tv code, to give to Dish TV, for my new Cielo TV
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts
Dec 07, 2013 | Televison & Video
I cannot program my tv to the remote
Try a code search method. If there is a code in the remote controller's programmed memory, it will respond. Otherwise, buy a new remote control. If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Nov 26, 2013 | RCA Televison & Video
Saludos necesito los codigos para el control remoto de dish, tv Proscan modelo pld3283d. Agradecida por la ayuda que me pueda dar.
002,007,000,018,052,011. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 10, 2013 | DISH Network IR Remote Control
Need 4 digit code for dish network remote
Hello! My name is Becki, with DISH Network. Here are some simple steps to program the remote to the TV, adn the codes to do so. You only need a 3 digit code in this case.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
505
594
627
633
Becki Barned
DISH Network Customer Service
Jun 21, 2011 | Coby 40 TFTV4028 LCD TV
It does not wake up bi itself
Hi ed87230my name is Mike Houston of DISH Network and I was going over your post andthere are some things you can check. If your batteries have been in yourreceiver for more than 6 months you will want to replace them. Then press andrelease the SAT button and press Select. If the remote did not respond press theSystem Info button on the receiver to reprogram the remote, I will send a linkto help with these steps. http://www.dishnetwork.com/SupportSection/remote-setup
Feb 21, 2011 | DISH Network ViP622 DVR DTV Receiver /...
I need a dish network code for a 52" Sharp Aquos.
Hi deidrapleasmy name is Mike Houston of DISH Network and I was going over your post and thecodes for your 52" Sharp Aquos are 628, 739, 521, 629, 741, 679, 112, 605, 625,111, 608, 740, 526, 585, 607, 652, 654, 655, 658, 669, 670 and 674. I will sendthe link to help with the setup for the remote to TV. http://www.dishnetwork.com/SupportSection/remote-control
Feb 14, 2011 | DISH Network IR Remote Control
I need the dish control code for panasonic tv
Hi jennyhilariomy name is Mike Houston of DISH Network and I was going over your post and Iwanted to give you the codes for your Panasonic TV. The codes are: 700, 734,864, 512, 673, 685, 566, 644, 234, 247, 676, 765, 625, 668, 662, 663, 689, 508,698, 716, 701, 239, 510, 761, 672, 509, 651, 747, 638, 439, 852 and 500. I willsend the link that will help with the setup http://www.dishnetwork.com/SupportSection/remote-setup.
Feb 13, 2011 | DISH Network IR Remote Control
Is there are remote code to operate an onyko tv-sr303 receiver.
Hi tmister318 this is Mike Houston of DISH Network, there are codes thatwill set your DISH Network remote to your Onkyo receiver the codes are 660,642, 678, 264 and 662. I will send alink to help with the setup for this. http://www.dishnetwork.com/SupportSection/remote-setup
Feb 06, 2011 | DISH Network ViP722 DTV Receiver /...
RCA L32HD31 32 in. LCD HDTV Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
