Question about Food Mixers
Kitchenaid 4kg25h3xsl My Kitchenaid Professional HD mixer model 4KG25H3XSL came with a whisk only. I subsequently bought a paddle attachment that said on the packaging that it would fit lift bowl models. Well, it didn't. What is the part number for a paddle that would fit my mixer please
SOURCE: Paddle Scraping - KitchenAid Professional 600
There is an adjustment screw and a system for setting it. You can find a video of it here (or just a ton of people who know all about these mixers). I just found it while trying to troubleshoot the same problem for my wifes mixer.
http://forum.kitchenaid.com/forums/forum.asp?FORUM_ID=196
Posted on Nov 02, 2007
  • 9 Answers
SOURCE: KitchenAid 575 Professional Mixer
Read the instruction manual. There is a screw to adjust the beater height, it is where the mixer joins to the stand.
Posted on Mar 25, 2008
defrankond
  • 65 Answers
SOURCE: KitchenAid Countertop Food Mixer
ok firstly if you have a stand mixer with the lift bowl you have to put a dime on the side of the bowl at the base and see how much clearence is needed to be taken away. if the dime gets moved the mixer is ok. if not take off the flat beater, take out the bowl, and look at the back of the stand. just below the motor about 2 inches you will see a screw. turn it to the left a quarter of a turn. dont over adjust do it slowly. if you have the one that you tilt the head back on do the same thing with the screw up to you get to the adjusting part. the screw will be in a different spot on those mixers. it is located in the neck of the mixer. it is right in the area that tilts back. the dime shouldnt fly around the bowl it should just gently get tapped. and never use the wisk when adjusting always use the flat attachment. and always adjust slowly never over adjust.
Posted on May 05, 2008
  • 145 Answers
SOURCE: KitchenAid Parts
Given the age of a 3-C stand mixer, finding additional parts for it will be exceedingly difficult. The best recommendation is through E-Bay or antiques stores - a specialty dealer. Kitchenaid parts distributors will no longer have anything in inventory for the 3-C mixer.
Posted on Jul 08, 2009
  • 53 Answers
SOURCE: my 6 quart kitchenaid mixer paddle is rubbing the ...
Find the screw in the picture as shown and screw it counter-clock-wise which will drop the bowl level down when it is in the raised position and the mixer paddle will not rub on the bowl.
http://www.fixya.com/uploads/images/07F1BE1.jpg
Posted on May 31, 2010
Kitchenaid stand mixer motor head fell off
You didn't say which model KitchenAid mixer you have. Assuming that it is a tilt-head, and that the metal portion of the motor housing joining it to the base did not break, the Service Manual can be had at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Apr 16, 2017 | KitchenAid Food Mixers
The beater to bowl screw is locked in position and cannot be adjusted. flat beater and whisk hit bottom
Without looking at it myself I can' think what the problem would be but a cheating solution would be to undo the 4 screws that hold the pedestal to the motor housing and put 4 washers there between the pedestal and motor housing and replace the screws.I assume you mean the flat paddle beater because that's the only one to use to set the bowl height.
Dec 02, 2015 | KitchenAid KSM50PR Professional Series...
No i'm only looking for attachments for my kitchenaid mixer model no. ksm90ww
State your country and someone will direct you. What is a batter blade, is that the flat paddle or a dough hook?
Jan 08, 2015 | KitchenAid Food Mixers
Kitchenaid whisk will no longer slip past the locking pin to rotate and attach on the spindle.
this might help... the whisk has a slightly larger whole then the other attachments. it is also inset. there is a washer that holds the spring on. if that is slightly off or bent it won't sit in the Whisks inset right. look a little closer to that and the spring. if there happened to be dried on food that could be the slight difference that can prevent it from staying one. Hope this helps!!!
25298509-2el2bftwapqh2uesegcwr3xp-2-0.jpg 25298509-2el2bftwapqh2uesegcwr3xp-2-1.jpg
Nov 27, 2014 | KitchenAid Professional 620 6-quart...
I need a replacement motor on a KitchenAid Professional HD Stand Mixer (Model KG25H7XSL).
The loud pop was probably the soft start circuit board on the motor. You can buy this board at repair sites or Ebay. And yes, they make 220V versions of this mixer.
http://www.samstores.com/product-kitchenaid-5ksm5ebu-heavy-duty-mixer-for-220-volts-%28cobalt-blue%29-16220.html
Dec 31, 2012 | KitchenAid Food Mixers
Brand New Kitchenaid Artisan Mixer - Mixer head is stuck
Unplug the mixer, turn the whisk the opposite of normal rotation in a quick motion, the remove a per normal.
Feb 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Whisk is stuck..can't be removed. what can i do? mixer is kitchen aid c 4. thanks for any suggestions!!
We had this same issue with our KitchenAid Mixer. Whether it is the whisk attachment or the paddle, the problem is that stuff (most likely sugar based) got into the attachment connection area and dried. It seems like a little sugar couldn't possibly glue the attachments to the stand mixer, but it does.
The solution is to turn the mixer on it's side and pour a kettle or two of boiling water on the section that joins the mixer to the attachments. Pour slowly to allow boiling water to penetrate grooves. Wiggle a little, pour more water, repeat... that should allow you to get it off.
In the future make sure to soak the attachments in boiling water every once and a while to allow all the gook to loose. And let it fully dry before reattaching to mixer.
Jul 13, 2009 | KitchenAid K45SS Classic Stand Mixer
Feb 28, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Sep 04, 2007 | KitchenAid KP2671 Professional 6 Series...
Food Mixers Logo
77 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
