Lines at the top of screen
I have a Sylvania SRT2227S 27" television. I got the TV from a friend. When I plugged it in, there appeared to be nothing wrong, until I started changing channels. I noticed something strange, there were thin white lines across the top of the screen. But this didn't occur on all channels. It only appears on programs and commercials where the picture goes within an inch from the very top of the screen. It also occurs, when I change channels, the panel that displays the channel number, and name of the program appears to 'roll over' and appear upside down again on the top of the screen. This is very strange and I have never seen or heard of this happening before. I have no clue as to what is going on.
    Top Expert:
  • Televison & ... Master
  • 75,404 Answers
Check and replace all the electrolytic capacitors at its vertical output section. The lines you refer here are technically called, vertical retrace lines, and are mainly due to capacitors itself. Check all the solder terminals of vertical output IC for any loose solder terminals. Resolder all the suspected solder terminals by applying a little more solder to each point. When replacing capacitors stated above, replace them all at one time. There will be 5 of 6 numbers of them, the most, and wont cost more. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
Posted on May 09, 2013
  • 1694 Answers
SOURCE: picture appears to be trying to scramble
Bad hyper board == No longer available
Bad electrolytic capacitors on board need changing-
Let me know if you need more info......T.
Posted on Nov 01, 2007
  • 121 Answers
SOURCE: lcd tv picture,on start up
is this a rear projection tv? a table top one? how old is it because if it's over a few years old, then it sounds as if the bulb may be going out but without having more info, it's hard to give an accurate advice.. please let me know if this helps..
Posted on Feb 27, 2008
SOURCE: Unable to resolve concave issues
I am also having the same problem. I tried to replace ICs but no luck. I am also looking for service manual in case if some one can give it to me.
Thanks,
Sanjay
Posted on Jun 26, 2008
daniel719
  • 240 Answers
SOURCE: 53 Hitachi Ultravison TV : Getting Horizontal lines rolling up
ok
this is called viedo noise
you will need to replace capisitor Cc10 its Value is 1000uf @ 16v the cap is a filter On Sw +9v Line , on pin 20 of Ic01, ( or corma Jungle IC)
Posted on Jan 12, 2009
  • 1779 Answers
SOURCE: Squiqqly lines on TV
Hi Tammy, Yes it can be repaired, most companies charge about $250.00 to repair the convergence circuit. Have them check to see if the SRS/WOW 3D pcb has been modified also!
Posted on Jun 05, 2009
Color problem on tv
The TV remote control can recovery your color as you want
Jun 08, 2012 | Sylvania LD320SSX LCD TV
Screen got wide; nasty acrid smell like chlorine or ozone started
One or more electronic components was burned or deteriorated inside the tv.
Replace the TV.
May 24, 2009 | Sylvania 6427TE 27" TV
No TV
Do you have the remote? Try changing the INPUT to AVI, AV2, Compnent, etc.
Mar 07, 2009 | Sylvania 6427TE 27" TV
Getting Error Message "wrong file format"
indid the formate is wrong when recording to the usb the format you want to used must be used.not all cd decks plays mp3 e.g
Mar 02, 2009 | Sylvania 6427TE 27" TV
Xbox
I have the same problem with a 6420ff sylvania tv with a xbox 360. I plug the red white yellow into the front of the tv and it wont come on.
Oct 16, 2008 | Sylvania 6427TE 27" TV
Once i turn it on once the fuse blows
Unless you're a technician, you'll need to take it in for repair. There's nothing a layman can do if a new fuse blows also.
Sep 28, 2008 | Sylvania 6427TE 27" TV
Not accepting video via RF connection
Why use a seperate tuner? Have you tried removing the seperate tuner and plugging the antenna into the TV?
Oct 06, 2007 | Sylvania 6427TE 27" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
