Question about Maytag Refrigerators
Maytag refrigerator model mbr1953wes2
How to remove freezer fan guard cover
mikedurland
  • 481 Answers
SOURCE: maytag refrigerator clicking
it sounds like a bad:
  • ·       start switch (on the side of the compressor) or
  • ·        compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Posted on Jul 06, 2008
SOURCE: maytag refrigerator side-by-side model MSD2756GE
remove the baskets and shelves in the freezer and remove the rear panels after shutting the fridge down. If you see heavy frost on the coils then the defrost model needs replaced. If not, check the that the fans runs, and then that the thermostat works and then that the damper that allows the air to the fridge compartment is opening correctly.
Posted on Sep 05, 2008
  • 1462 Answers
SOURCE: MY MAYTAG REFRIGERATOR
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
Posted on Oct 02, 2008
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
  • 4 Answers
SOURCE: Refrigerator side doesn't feel cool but the
Is there ice build-up in the back of the freezer? If so take the panel off the back of the freezer section inside the freezer and replace the heating element.
Posted on Jul 23, 2010
One of the lightbulbs in the refrigerator is out. There is a guard over it that I can't figure out how to remove.
It looks like the cover clips on at the base of the bulb. This is a picture of the diagram, but I can't tell exactly how the clip works. But by looking at the diagram and know where the clip is, maybe you can tell more by seeing it in person. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48360&diagram_id=28491204#d28491204
Hope this is some help to you
Jan 21, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Maytag 27.3 cu ft model #MSD2756GEW freezer freezing refrigerator side not cooling
Check the air damper if it opens as you adjust the temperature control. If yes then check the freezer fan motor. First, disconnect the unit from the power source then remove the freezer shelving.
Loosen the two top screws and remove the two bottom evaporator cover mounting screws then grasp the bottom of the cover then carefully pull it forward and down to clear the upper flange.
Disconnect the evaporator fan motor leads. The wire leads are self-locking and it is important to squeeze the clip before pulling the leads off the terminals.
Remove the evaporator fan motor assembly and place it on a work surface. Connect the motor terminals to a service cord and plug the cord into the 120 VAC power source. If the motor fails to operate, it is defective and must be replaced.
Here's the service manual for further troubleshooting.
Jul 06, 2010 | Refrigerators
Freezer isn't working and refrigerator isn/t cooling. What is the problem? We can hear the fan running however.
my refridgerator is a Maytag side by side did the same thing checked the freezer compartment fan was working removed cover to look at the cooling coil, the coils were frozen solid ended up defrosting freezer compartment every other day. replaced the adaptive control board located in the refrigerator side top, haven't had another problem since.
Nov 15, 2009 | Maytag MSD2756GES Side by Side...
The refrigerator no longer cools. The freezer
ok take your shelves off
the center air hum, it will take a lil strength but lift the air channel up thaen pull staright out, is should pop right out and give you access to the fan...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=49270&diagram_id=635220#d635220
makse sure you order the correct part 7
does your fan have a blue and white wire
Oct 22, 2009 | Maytag MTF2156GEW Top Freezer Refrigerator
The food and drinks in the refrigerator does not feel and taste cold enough. The freezer is just fine.
Check for proper operation of the freezer fan. This fan moves cold air from the freezer to the refrigerator. If the fan is not turning, the freezer will be too cold and the refrigerator will not be cold enough.
The fan should be behind an access plate at the rear of the freezer. Listen for the sound of the fan. If you can't hear it, remove the cover and look at the fan. If it's not turning, you will need to replace the fan motor.
Oct 15, 2009 | Maytag MZD2766GES Side by Side...
Hello, I own an Admiral Refrigerator (Admiral Ultima 2000) and the evaporator motor occassionally squeals. If I turn off the refrigerator for a while and turn it back on a few hours later, the fan will run...
Motor bearings are more than likely going out. The fan spins until the bearings heat up. Suggest you replace motor take model and serial number to get part at the appliance parts house Good Luck
Dave
Jul 29, 2009 | Refrigerators
I installed my U-Line CO2175DWR with no problems, however the internal freezer fan gets very noisy at times, like an annoying buzzing bee flying overhead. At first I thought it to be the plactic guard, I...
well this unit is loud during operation. your case is bad freezer evaporator fan motor. if it is under one year , it will be cover by Warr. U-line ph #800-779-2547
Dec 28, 2008 | U-Line Echelon Combo® CO2175DWR Stainless...
Maytag french door bottom freezer: Fan not working.
very easy the fan cover snaps into place and make sure you get the new motor that is metal not the plastic one they are the problem
Dec 11, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag refmodel number mff2557hew
sounds as if perhaps the fan in the freezer is not circulating air up to refrig sect. pretty common issue, if you pull out freezer door youll be able to hear the fan on the back wall, behind the vent on top sect of freezer. that cover pops right off with a pry of the screw driver.. heres the part number if indded that is the issue 12002744 comes with instuctions on how to install
Nov 09, 2008 | Maytag Refrigerators
Maytag side by side slowly getting warmer
YOU ARE BE GETTING A WEEK COMPRESSOR.
Jun 09, 2008 | Refrigerators
Refrigerators Logo
69 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
