Question about Alesis MasterLink ML-9600
Digital input cable optical
No signal on digital input
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
The Alesis doesn't have an optical input.
It will only receive digital input in PCM, at the sample rates shown on the front panel - 44.1k to 96k
If you're trying to feed it an encoded Dolby Digital, or similar Home Theatre-type signal, it will not work, as these are not PCM-encoded signals.
Posted on Oct 27, 2013
I want to connect my DVD and TV to my Samsung Sound Bar but there is only 1 optic cable port on the sound bar
You can use the other inputs as long as they are labeled a/v or left, right , video. or are coaxial cable. optical means it is digital light input , not optical {video}.. the optical is actually a piece of monofilament that a light signal passes thru.
May 13, 2017 | Samsung Televison & Video
No sound using optical cable connected to LG smart tv 60LN5600
Your receiver has 2 optical inputs. If you plugged in the cable to Input 1, you can select the "CD-R" Input on the receiver. Then use the "Signal Select" button to select Optical 1 (O1).
You can also use the "Input Select" buttons on the remote until the receiver says "Digital". Then use the "Signal Select" button to select Analog (A), Coaxial 1 (C1), Optical 1 (O1), or Optical 2 (O2).
Mar 08, 2015 | Pioneer VSX-820-K Home Theater Receiver
Din unlock c71
the input source you have selected is not working. If digital it might be a copy guarded source which the deck cannot read...
If you get fancier and are trying to record the optical output from a newer device like a 5.1 or 7.1 receiver although the signal will go through the MD deck cannot decode the advanced optical signal. There are adaptor boxes on eBay which decode 5.1 & 7.1 optical signals to an optical signal the older MD can read and record from.
Try selecting another source like analog RCA. The digital stuff I mentioned applies to digital RCA and Optical Cables like toslink.
Feb 08, 2014 | Sony MDS-JE520 Mini Disc Player
How do I set my receiver to read TV/CBL Dolby Digital. It is a AVR 789
The Dolby digital signal is outputted only through the Optical or Coaxial socket of the CBL box. you will have to get an optic fiber or coaxial cable depending which cable box you have and connect it to the digital input of the Denon receiver. The Denon's digital input are already assigned at the back. Eg: Optic input might be labeled CD so if you are connecting the CBL box to the optic input remember to select CD on the Denon to hear the cable sound, same goes with the coaxial input.
Aug 27, 2011 | Denon AVR-788
I try to connect a satelite to optical audio input for a digital radio signal. This doesn't work. Is it only possible to use a coax input cable for the radio signal?
The nature of whatever is on the upstream side of a digital signal is invisible to the device at the other end of the cable. Bits is bits, as we say. The undefined 'satelite to optical audio' device is probably at fault or not set right. PLUS, on theOnkyo you have to assign digital inputs. Read the manuals.
Aug 11, 2011 | Onkyo TX-SR501 Receiver
The optical digital input is not lit up in the back of my dvd player. I am trying to play connect it to my digital cable box, which does have a lit up optical plug.
You need to select the digital input after you connect an input source.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-Q45T-Home-Theater-Systems-manual/id/287bh742/t/2/
Optical signal strength is sensitive to small-radius bends in the cable.
DON'T LOOK DIRECTLY INTO AN OPTICAL CABLE or PORT.
May 17, 2011 | Samsung HTQ45 System
Problems with optical input. I am having intermittent problems with the optical sound input on my Onkyo. I am using a DVR with optical output for the source. Sometimes when I turn the DVR and Onkyo on I...
sometimes with cable, satellite, or any dvr, the digital signal actually is intermittent and there is little we can do about it but add an analog audio connection for each device as a backup. per se, and put the receiver in auto input mode. the receiver will utilize the analog signal to fill in where the digital signal fails
good luck
Dec 07, 2009 | Onkyo TX-DS747
Input signals Marantz SR4003
There are four digital connectors on the back of the unit: 2 optical and 2 coaxial. They are marked a s 1 2 3 4. 1 and 2 are optical, 3 and 4 - coaxial. Also you have front optical connector marked as F.
You can connect 5 digital sources to your receiver. For example, connect your DVD to input 2 (optical) by optical cable and connect your DSS to input 3 by coaxial cable. Assign DVD to digital 2 and DSS to digital 3 in input setup menu.
Aug 14, 2009 | Marantz SR5001
VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
Jan 29, 2008 | Pioneer VSX-D511 Receiver
Kenwood vrs-6100 receivers optical digital
You want to receive the optical signal from the TV's built in decoder / receiver to play through your Kenwood? Maybe you need to select the digital input. The manual says:
Use the INPUT SELECTOR key (or Input Selector keys)
to select DVD, VIDEO or FRONT AUX.
2 Press the INPUT MODE key.
Each press switches the setting as follows:
1 "F-AUTO": Auto detect
("AUTO DETECT" indicator lights up)
2 "D-MANUAL": Fixed to digital input
("DIGITAL" indicator lights up)
3 "ANALOG": Fixed to analog input *
("AUTO DETECT", "DIGITAL" indicator goes off)
Also check your TV to make sure it is outputting to the optical jack.
Jan 11, 2008 | Samsung HTP-1200 System
Alesis MasterLink ML-9600 Logo
43 people viewed this question
Top Alesis Televison & Video Experts
Are you an Alesis Televison and Video Expert? Answer questions, earn points and help others
