Believe it's 52"
Missing cord and may need new bulb.too.
SOURCE: GE D52GW12 52 in. Rear Projection HDTV-Ready Television
The ITC222 chassis actually has two different boards that are related to the power supply.
(1) Main power filter board #MIS222E0000.00
(2) Power supply #PP222E0000.37
The first board is a small board where the power cord enters. The second board is the large board that the small board plugs into.
Most likely bad solder connections around the flyback area of the circuit board, that model is famous for bad solder around the flyback and bad flybacks them selves. But if the led doesnt flash 3 times then go out, its most likely a solder issue.
SOURCE: where can i get picture tube for Ge D52GW12
you can get one at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
SOURCE: GE D52GW12 52'' HDTV POWER SUPPLY OUT
You can get any replacement board that you require for your model from www.tvrepairworld.com they will also help you determine which board is correct for your model and symptoms.
SOURCE: My 2004 GE 52" hdtv
If you need a tube replacement, your best bet is to get a used one from ebay. You need to verify the numbers on the side of the tube. Note: this is a very hazardous part to be handling. If you do not have an electronics background I strongly suggest you not attempt to replace, then re-align the tv.
