Question about Genie Aire PACR12 Air Conditioner
Manual I'm looking for a manual to install a Genie Aire portable air conditioner. Any advice?
5 Suggested Answers
sloooo44
  • 156 Answers
SOURCE: How do I reach Genie Aire without you popping up?
Here is the direct link. http://www.geniecompany.com/
Posted on Sep 28, 2010
pctech1
  • 1940 Answers
SOURCE: need to know how reset
The only reset for this device is to unplug it, and then plug it back in. Is there are particular problem you are having with this A/C?
Here is your manual:
http://www.climette.ca/Lit_Archives/Portable_Room_Air_Conditioners/PACR12/PACR12-OM-E-04.pdf
Posted on Jun 10, 2011
  • 1833 Answers
SOURCE: My Genie Aire portable a/c
Hi, For this problem first make the AC clean. It need a servicing. If the servicing doesn't solve your problem then you have to repair or replace the compressor.
Posted on Sep 08, 2011
  • 45410 Answers
SOURCE: i have a genie aire portable air conditioner model pacr12-ge
check your local hardware
Posted on Feb 09, 2015
Fan runs loud after shut down - unit is hot to touch
Portable units were never designed to be serviced, only replaced. There's no money to be made on portables. It' cheaper to buy a new unit.
Oct 03, 2013 | Genie Aire PACR12 Air Conditioner
Humidifier gets ice on top of cabinate. It still produces water.
Most dehumidifiers have a defrost cycle that they run through, as needed. But, apparently, your is not functioning. Eventually, yours will stop collecting moisture, if this continues. In the interim, I would suggest turning the Master OnN/OFF Switch to OFF and unplug the unit until it thaws. While it's unplugged, remove and clean the air intake filter on the front of the unit. If it's clogged it causes the unit to strain and may cause it to ice up. Once the filter is clean and the unit is un-thawed. Plug the unit back in and turn the Master ON/OFF Switch to ON and set the controls as you normally do. Hopefully, that period of being unplugged will have allowed the unit to reset itself and work properly.
I have included a link to your Owners Manual that you can download and print for future reference.
aire.com/index.php?option=com_rubberdoc&view=doc&id=436&format=raw">http://www.comfort-
If the above link fails go to the following link below and click on Owner Manual, near the top of the page.
aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g">http://www.comfort-aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g
Hope this helps you solve the problem.
Apr 27, 2011 | Comfort-Aire BHD-301 Dehumidifier
Comes on and runs then cycles off, and may not come back on. fans run every thing seems to work compressor dose not come back on.
if a portable air conditioner, is the water tank full of water ? if so empty it.
Other option for any a/c unit (not just portable unit) is that it has a gas leak.
Apr 21, 2010 | Genie Aire PACR12 Air Conditioner
Exhaust hose
Hi; Pull out Your phone book and look up air conditioning supply houses in the yellow pages. They will be able to order You a hose providing You have the make,model number of the unit...
Jan 19, 2010 | Genie Aire PACR12 Air Conditioner
Genie Aire PACR12-GE - Warning light flashes 3 times-No cold air
Turn the unit off, check the bottom rear of the unit and place a shallow pan under the drain outlet and remove the rubber plug to drain the condensate out of the unit then replace the plug and turn the unit back on.
Jul 26, 2009 | Genie Aire PACR12 Air Conditioner
Need a manual
looking 4 manual 4 comfort aire a.c. model#pe-121a serial# 070301060
Dec 29, 2008 | Comfort-Aire PAC-121 Air Conditioner
Genie Aire PACR12 Air Conditioner Logo
Top Genie Aire Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Genie Aire Heating and Cooling Expert? Answer questions, earn points and help others
