Hard drive failure
When i try to start-up my computer i get a black screen with the message error loading operating system or it says missing operating system. Is my hard drive failing because i have gotten a blue screen more than once during its operation recently? I would also like to know if its possible to switch to a solid state hard drive or should i just replace it with the same one?
  • Jeremy L. Winchester May 09, 2013
    i tried to boot it up using safe mode, but it doesnt even give me the option it just shows those error messages from before. could i switch to a solid state drive to replace his hard drive or do i have to replace it with te same one?
  • David Greene
    David Greene May 09, 2013
    Please try the 2nd option which is to do a start up repair. Insert the installation disc before replacing it. The replacement should be the same hard drive.
    Master:
  • 663 Answers
Try booting to safe mode. Restart your computer and tap F8 until you see the options to boot to safe mode. Use the arrow keys to highlight safemode and hit enter.
If it doesn't gets in, then you would need to do a start up repair.
Look for the operating system installation disc and insert it. Restart the computer and let it run the repair.
If it's not fixed, then you can try doing an operating system reinstallation. If it doesn't work, then I suggest you buy a new hard drive.
David
Posted on May 09, 2013
maklean
  • 1665 Answers
SOURCE: Trouble Reloading Start-Up Disk on Toshiba Satellite 1905-S301
Checl all internal cable connections (unplug-plug
Check all internal cable connection to be correct, start and observe messages to see if your HDD is recognized by bios and memory test is ok.
If problem remains try to boot from CD with original operating system disk in CDROM.
Posted on Mar 07, 2008
kakee
  • 1269 Answers
SOURCE: 0200: Failure Fixed Disk 0 IBM T-41
There's a possiblility that you can still recover your files. Try to plug your hard drive to a different PC and check if it detects it. Otherwise, there's no hope but to buy a new hard drive.
Posted on Jul 26, 2008
  • 244 Answers
SOURCE: PXE-E61: Media test failure, check cable
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
Posted on Oct 01, 2008
SOURCE: Hard Drive Replacement T30
change your boot sequence in the bios to 1st: cd 2nd: DD etc.... i think it is trying to boot fron LAN
Posted on Oct 03, 2008
ibleedblue18
  • 50 Answers
SOURCE: Sony Vaio PCG-TR3A, Blue Screen states cannot find operating syst
There should be a factory image on the HD when you try restarting it. Hold down the F8 key or F10 key while its rebooting this should start the recovery process you shouldnt need a windows disk.
Posted on Dec 04, 2008
How to fix a missing operating system on acer aspire 4920 series laptop
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
May 13, 2014 | Acer Aspire Computers & Internet
Dell dimension 4550 Bootmgr missing error message
you would have to removed the hard drive and possibly buy the external adaptor for your hard drive then plug it in to another computer via USB and reformat the hard drive..
Jul 09, 2012 | Dell Computers & Internet
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
Upon starting my emachines t3025 it goes to a black screen and give me the error message missing DLL and Kernl. I am also unable find the recovery area and will no permit loading in the safe mode. I have...
Hi, You have a bad hard drive sector. If you have other PC install the hard drive as a slave and create a partition. hope this info will help you solve the problem
Jul 06, 2011 | E-Machines eMachines Desktop PC
My acer is not getting past a start screen, its loads an error on a black screen, saying it cannot locate the operating system. It will allow me to go to set up but I'm not sure what I'm doing?
This error comes out when the pc cannot find the hard disk.
Does the bios detect it? What is the exact error?
If the error you get is NTLDR missing you should install again the operating system (i.e. Windows)
If the error you get is no bootable device can be an hardware problem. Please check the connection of your hard disk. If connection is good you may want to remove the hard disk and buy a new one. The old hard disk you can put into a usb drive and copy your personal data so you can have it back.
If with the new hard disk you are not successful it could be a motherboard problem and you should take it to assistance
Mar 01, 2011 | Acer Aspire 5735 Notebook
I tried turning my computer on and right after the dell logo comes up to load, I get a black screen that says NTLDR is missing Press any key to restart, but when I push a key, the same error message just...
Hi,it is possible that your hard drive has crashed thats why you r getting that message or its just the Operating system,and in the event of the former i'll advise you replace your Hard drive.But in the case of just the operating system being corrupt try repairing it,if it does not work,back-up your files using and external SATA converter and format.
Dec 23, 2010 | Dell Inspiron 1525 Notebook
Compaq 6720s notebook, hard drive failure, gave me blue screen described with psyical memory dump, try to start up and it repeats the "Press F11 for Recorvery" over and over, press f11 and it trys to load...
Hi there
A clue is in the error message you get "hard drive failure" this means the hard drive which holds the operating system is corrupt and will not allow a reinstall, you have to purchase a new hard drive before you can reinstall the operating system and then you'll be good to go.
If the laptop is still covered my the manufacturers warranty i recommend you take advantage of that and send it in for repair, if its out of warranty you'll be able to get one from any reputable PC store.
Good luck and thanks for using FixYa!!
May 14, 2009 | HP Hewlett Packard Compaq 6720s Laptop...
I start up my computer, I get a black screen that says press F1, after I do that I get a black screen with a message that reads, operating system not functioning
Have you take note the error message about the operating system? does it say a corrupted windows file?
With regard to the error message about F1 to continue, i would say that your hard drive is looking for the operating system. There is a possibility that your operating system is corrupted due a virus infected file or a system file was accidentally deleted from your computer or it could be an issue with your hard drive itself.
You may need to check also if your hard drive is detected by computer. You may call your computer manufacturer if your system still under warranty. In case the hard drive need to be replaced.
I suggesst to run a system diagnostics first to check if the hard drive still functioning before you run windows repair using the operating disc you have with your system.
Keep me posted.
Oct 12, 2008 | HP Computers & Internet
Hp pavillion zt1170 - not booting
You have lost your operating system and/ or you hard drive went bad. Try reformatting your hard drive and them reinstalling your operating system. If it reinstalls, try booting up your computer. Turn it off afterwards, wait a bit, then try booting it up again. If it still boots up, then you are good to go. But if it doesn't boot up, or it doesn't boot up after you restart your computer, then your hard drive is bad, and it needs to be replaced. Hope this helps.
Sep 13, 2008 | HP Pavilion zt1170 Notebook
Laptop won't boot up
This is an operating system error, and sometimes indicates a hard drive failure. Start by running a system repair with your recovery or operating system disc. This usually takes care of it, if it doesn't, reformat the hard drive and install a new operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced.
Jul 31, 2008 | Toshiba Satellite A70 Notebook
Computers & Internet Logo
David Payne
David Payne
