Jensen CD3610 CD Player Logo
Mike Jones Posted on Aug 11, 2007
I need help with My jenson cd player
It wont turn on .. give green to blue screen and then goes away
Anonymous
Level 1:
Problem Solver:
  • Contributor 3 Answers
  • Posted on May 11, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
405
Points
Now you make sense Lets Drag.
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Aug 11, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
2808
Points
13
Take it out and by a new one =)
3helpful
Jensen DVD player (JDVD 4301) does not show picture when DvD is inserted. Message on screen "Warning Stop Watch Video" display on blue screen although I can hear the movie playing. Did I connect...
Jenson requires the green wire to be connected to the vehicle parking brake.(Safety feature) this green wire requires a negative switch to activate the screen.
1helpful
Need to know what wire colours r what on the harness of a Clarion DXZ635MP CD player lost manual
Your ground wire is going to be black. Your normal wire colors are violet and violet/black, green and green/black, white and white/black, last but not least you have grey and grey/black. Those are your speaker wires. Solid blue is usually to power your antenna, and blue/white is for your amp turn on lead. Those two wires are approximately .5mV of power, and you can actually use either one to turn an amp on. Speakers: normally your solid color is positive, while the black stripe is your negative. As for which one goes to which speaker, left front is white, right front is gray, left rear is green, and right rear is violet. Hope this helps.
2helpful
Cd player installation
CAR WIRING
Constant 12V+ Orange To Radio Yellow
Switched 12V+ Yellow To Radio Red
Ground Black To Chassis Ground
Illumination Gray Orange/White on radio
Dimmer Brown n/a on radio
Antenna Trigger Pink Blue/White on radio
Left Front (+) Tan White on radio
Left Front (-) Gray White/black on radio
Right Front (+) Light Green Grey on radio
Right Front (-) Dark Green Grey/black on radio
Left Rear (+) Brown Green on radio
Left Rear (-) Yellow Green/Black on radio
Right Rear (+) Dark Blue Purple on radio
Right Rear (-) Light Blue Purple/Black on radio
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jenson VM9311TS will not play all speakers in cd mode
YES!! You used the blue wire to turn on factory amp (blue wire to GM pink) you NEED to use the Blue/White wire. That is the amp turn on. The blue wire goes dead when you play a CD or DVD because it's for a power antenna. So, Blue/White ok?
Enjoy,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jenson CD330X CD Player
The problem is that the bat handle is broken. you need to dissassemble, and repair the blue plastic piece. Use epoxy, that's what I did. It worked.
I can't set my clock either.
7helpful
4answers
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Dvd player on Jenson VM9311TS
well if u haven't fixed it yet this is what u do. now that u have the toggle switch and that blue screen is gone ,now u put that code in . u put a dvd in when it starts u press stop twice on the remote then press1264 . as soon as u put in that last number a menu will appear on the screen that says
this what u should have it at if not then change it to this
REGION:1
BRAKE OVERRIDE: ON
MACROVISION: OFF
JENSON vm9312 Video Bypass
check this out man, go to fm/am mode. with the remote hit the setup botton. then enter 543210 and be sure it beeps on every diget. then hit the hammer/screwdriver icon and turn the parking brake "on"
Top Jensen Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
