Question about B-52 ACT 18X Active 18" 1200W Subwoofer
Diagram for b 52 act18 digital ampplifier
Fender telecaster with serial number Z6129343
It was made in 2006 to 2007, and unless it has 5 numbers stamped on bridge plate its just your standard tele. If it has the 5 numbers it is a '52 reissue.
Sep 20, 2014 | Music
Guitar serial number lookup us11131155
Possibly... Here's what Fender says...
US11 + 6 digits
V + 5 or 6 digits (American Vintage Series except '52 Telecaster, which uses a five-digit number stamped into the bridge plate)
2011
(for American Vintage series, check neck date for specific year)
What model Fender is it?
Jan 25, 2014 | Fender Music
Need replacment inputs for boss digital delay
the jacks are not diffiult to find nor to install, but don't buy cheap radio shack jacks, go to a good music store and buy jacks ( the price may be 3 to 5 dollars each). take the unit apart and take not of where the wires go, wirte it down/draw a diagram, note colors of wire and where they go. cut the wires loose and take the old jacks out, then solder in the wires where they belong, and you're good to go.
Mar 20, 2011 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
I need a diagram to show how to take the keys out.
Here is EVERYTHING you need about servicing the keyboard... 11.7 Mb PDF.
http://elektrotanya.com/yamaha_psr-s500.pdf/download.html
The key removal is around page 15 of the file.
Jan 10, 2011 | Yamaha PSR-S500 Digital Keyboard
I have a Jackson erie dess Dinky.The serial number is 04041727. I would like to know the actual model #, where and what year it was made and where can I get an ACCURATE wiring diagram for this sc/sc/hb 1...
Search this site based on how many pickups you have for a configuration matching your guitar.
Apparently some of these were 2008 models.It is possible the date code is imbedded in the serial number. That MIGHT mean it was made in Apr 2004.
You may find date codes on some of the internal parts. Thes usaull will be 2 digit year followed by 2 digit week of manufacture.
Dec 22, 2009 | Jackson Dk2m Dinky Electric Guitar
I NEED A TRANSFORER for A WULITZER ELECTRONICS ORGAN
If you need 52 VAC I would get TWO 25 VAC transformers and series the secondaries to get the 52 VAC. The 25 volt ones are usually readily available. Sources include Digikey.com, Mouser.com, Allied, Newark.com.
You will need to have ones with at least the current rating necessary.
Sep 08, 2009 | Music
I need a wiring diagram for the main circuit board in a behringer djx700 mixer
Behringer only gives schematics to their authorized service people.
I find I can usually trace stuff out as needed as the mixers are a very symetrical repeating circuitry.
Most components are readily available from other sources.
Aug 26, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
B-52 ACT 18X Active 18" 1200W Subwoofer Logo
Top B-52 Music Experts
Vito Vacirca Jr.
Are you a B-52 Music Expert? Answer questions, earn points and help others
