Question about Car Audio & Video
Power control wire
What do I hook it to
    President:
  • 676 Answers
Is it going to stereo or to amp. This is to control an amp or powere antena.
Posted on May 09, 2013
Gm stock trailer brake controller wiring ,when hooked up to the controller , turns the parking assist off (disabled),why or whats the fix ( all power wires hooked up, trailer brakes work fine )
the sensors are designed that way normal function when tow is set up behind vehicle if not the park assist alarm would be ringing/beeping all the time because of distance the trailer or what ever is hooked up to tow is to rear of vehicle your owners manual also explains this function
Sep 05, 2016 | 9030 Voyager Electric Trailer Brake...
Where do i hook up power control wire to
You hook it up to the two (usually yellow zip tied wires) in the back of your head unit. the actual power (red cable) goes to your battery and the ground goes to the ground on your battery. Hope that helps
May 09, 2013 | Car Audio & Video
Were to hook the power control wire to ?
The power control wire must go to the SWITCHED ouput from the HEAD unit which is normally a
BLUE wire.
So when the head unit is ON the amp will be switched on and vice versa.
Jul 14, 2011 | Kenwood KAC-829 Car Audio Amplifier
What does the red wire attach to for a k4221 photo control?
The power wire coming into the control has a black, white and copper (ground) wire. Hook the balck wire to the control black, All the gound wires hook together, all the white wires hook together, then hook the red wire to the black of the light that you want to turn off and on.
Nov 13, 2009 | Intermatic K4221C Photo Cell Control 120 V...
Brake Box Will Not Work
First try a 12 volt "stab in" test light pushed into the blue wire at the brake controller. Red is brake feed from the truck, black is 12 volt power and white is ground. If all is wired correctly, the blue wire should power up when you hit the brakes. Be sure to turn the controller up to highest setting to test it. When you hook the test light up, the connection indication light should come on. Then turn red when you hit the brakes. Also see http://www.etrailer.com/faq-wiring.aspx for more info.
Oct 22, 2009 | Pioneer Voyager 4000 HD-DVR
I changed my dryer power chord from 4 to 6 feet. I have all the correct wires hooked up. There is a pigtail coming off the dryer power bar. As a result, I have this loose white wire flopping around. My...
That wire flopping around is probably the ground wire and needs to be hooked up, it's probably grounding out the power for the control.
Oct 05, 2009 | Dryers
Need a basic diagram to wire a ceiling fan.
Depending on how your place is wired will dictate the solution here.
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Hunter 52" Ceiling Fan With Light And...
WIRING DIAGRAM
Sep 18, 2009 | Panasonic FV-08VQL4 Fan
Pioneer DEH-225 Car Audio
The system remote control is usually a blue wire on your decks harness and it is for an amplifier for a sub or other speakers. It sends power to the subs amp when the deck is turned on. You may need to find the wires coming off the antenna and splice them into the red power switching wire 12v on you decks wire harness. Good luck
Oct 07, 2007 | Pioneer DEH-225 CD Changer
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
