Question about True T49F Freezer
Freezer troubleshooting true t 49f
My freezer temp keep fluctuating
  • 116 Answers
SOURCE: True commercial freezer
The ice could be preventing the freezer from freezing properly, try defrosting the unit. if this does not help then this could indicate a more serious problem like a bad temp sensor or refrigerant leak.
Posted on Apr 27, 2007
roadbird383
  • 40 Answers
SOURCE: TRUE freezer model number GDM-49F.
Your unit should have a defrost timer.The timer may be stuck in a defrost.It should be located at the bottom of the unit next to the compressor.Open the door to the timer and observe the position of the timer.If you turn the knob and the unit starts up,it's the timer. If this is the case, you can purchase a new one at any local a/c supply.Let me know,Mike
Posted on Dec 14, 2007
  • 1218 Answers
SOURCE: looking for true freezer defrost heat element for
Most commercial refrigeration supply houses should be able to help you with getting the heater or if not at least give you a steer
as to where to go or who to contact. Some are really helpful, others can be real jerks. Sorry but without knowing the area you are in I cannot give you more info than that. Did you Google the Brand name of the freezer ?????
Posted on Oct 29, 2009
  • 1238 Answers
SOURCE: true 49f goes into defrost
in many cases, these units have relays or contactors where the contact points actually weld together. this causes the unit to stay running even though power to the coil has been stopped. I'd start looking there first. don't over look the possibility that someone could have mistakenly miswired the unit.
Posted on Aug 21, 2010
bobicehouse
  • 1524 Answers
SOURCE: TRUE T-49F FREEZER DIAGRAM REQUIRED.
http://www.pdfdownload.org/pdf2html/view_online.php?url=http%3A%2F%2Fhvac%2Dtalk%2Ecom%2Fvbb%2Fattachment%2Ephp%3Fattachmentid%3D129111%26d%3D1285929051&images=no
Posted on Dec 13, 2010
What is the standard setting defrost timer control of ts-49f
our freezer is set to defrost every 8 hours for 15 min. this seem to do the trick. we have a true t-49f reach in freezer. try this setting and see if it works for your situation.
Mar 30, 2015 | True TS-49F Stainless Steel Freezer 2...
I have TRUE freezer model number GDM-49F. the compressor start but the evaporator fan wont start what culd be the problem
Could be a number of things. It has a thermistor that sits on the evaporator to keep the fan off until it gets cold. It also has a switch above the door that switches the fan on when the door's closed. It could be a loose connection in the wiring, or, lastly, it could be a seized fan
May 04, 2012 | True 49 cu. ft. / 1388 liter Commercial...
Proper defrost time true t-49f
They don't even ship them properly set. They expect that a trained technician is on site at start up. I generally use 4 defrosts in 24 hours at 30 - 45 minutes each. It depends on which timer is installed.
Mar 28, 2012 | True 49 cu. ft. / 1388 liter Commercial...
Product in my true gdm-49f freezer is frosting up and there is an ice build up around the inside of the case. what could be the causes of this.
Try defrosting the unit by shutting it down until all ice is gone. If this corrects the problem and the ice returns you may either have a defrosting problem or a low freon charge.
Jan 20, 2011 | True 49 cu. ft. / 1388 liter Commercial...
Dec 06, 2010 | True 49 cu. ft. / 1388 liter Commercial...
We have a True TS-49F freezer that the interior fan have stopped working. Holding the door switch does not activate them. Unit is out of warranty.
Most all commercial freezers like yours have, what is called, a fan delay. It is located in the evaporator case and is usually attached on or very close to the actual cooling coil. It may also be a combination switch known as a defrost terminator/ fan delay. It's purpose is to keep from circulating warm air. If the cooling coil does not reach a preset temp, the fans do not come one. Another thing is that the fan motor may just be bad. If you have more than one fan, then chances are that it's going to be the fan delay. I would start there to see that either the fan delay switch is bad or there is a reason that the coil is not getting cold enough to activate the switch.
Nov 09, 2010 | True 49 cu. ft. / 1388 liter Commercial...
True 49f goes into defrost mode the contact opens for the compressor but the compressor keeps running
Aug 19, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Model # t49f 2 dr. freezer unit tripping 20amp
Request a T-49F-RC wiring diagram directly from True.
Nov 20, 2017 | True 49 cu. ft. / 1388 liter Commercial...
True T49F Freezer Logo
59 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
