Question about Car Audio & Video
What is the pcon wire - Car Audio & Video
    President:
  • 676 Answers
Power control wire should be connected to the amp turn on wire on the stereo.
Posted on May 09, 2013
Color code wiring for radio
1996 Chevrolet Suburban Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Ignition Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Oct 11, 2012 | 1996 Chevrolet Suburban
Can l have instraction to conect projector with pc
connect the vga cable to your projector and to your computer.
set your projector input to pc
on your computer you will have to set it to duel screen
usually this is the f8 key or some are fn + f8
or you can get a vga splitter on desktop computers.
hope this helps
Jul 08, 2012 | HP VP6210
How do i correctly install the radio in a 2000 kia sephia
Here are the radio connector wiring colors and what they do.
2000 Kia Sephia Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/Red
Car Radio Ignition Switched 12V+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Stereo Illumination Wire: Red/Black
Left Front Speaker Wire (+): Black/Yellow
Left Front Speaker Wire (-): Blue/Orange
Right Front Speaker Wire (+): Blue/Green
Right Front Speaker Wire (-): Light Green
Left Rear Speaker Wire (+): Green/Red
Left Rear Speaker Wire (-): Green/Black
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Red/Blue
Jun 28, 2012 | 2000 Kia Sephia
The exclamation and the toner lights are steady on yellow and i can't print
needs pcon or toner replacing exausted hence toner light and ! mark and will not print por before changing or it will stay the same
Nov 17, 2011 | Lexmark E260dn Laser Printer
I replaced the ignition switch in my 1995 ford ranger now the alarm won't stop
95 Ford Ranger Auto Alarm Wiring Diagram.
You need to re-check your ignition wiring. Here is the wiring for the alarm.
Battery Constant 12v+ Positive Wire (+): Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Red/Light Blue
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Light Green/Purple
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Light Green
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Gray/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): White/Black Or Brown
Parking Light Positive Wire Location: At Headlight Switch Or Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Pink/Yellow (Type B)
Power Door Lock Negative Wire Location: In Either Kick Panel
Power Door Unlock Negative Wire (-): Pink/Light Green (Type B)
Power Door Unlock Negative Wire Location: In Either Kick Panel
Door Trigger Positive Wire (+): Black/Light Blue
Door Trigger Positive Wire Location: In Drivers Kick Panel
Domelight Supervision Wire: Use Door Trigger (Requires Relay)
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Yellow/Light Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Any Wire With A Tan Stripe Or A Yellow Stripe
Tachometer Wire Negative Wire Location: At Ignition Coil
Brake Light Positive Wire (+): Light Green
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Dark Green/Purple
Factory Alarm Disarm Wire Location: Low In Drivers Kick Panel
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 16, 2011 | 1995 Ford Ranger Supercab
GE digital timer. Instructions say to: 1) connect Hot/live wire of main to black wire of timer, 2) connect neutral (White) wires together, 3) connect Hot/live wire of load to red from timer. 4) green to...
Find the Hot wire:
Your switch has 2 wires. One of these wires is Hot, and one goes to load. Disconnect wires from switch. Turn on power. Do not stand on wet surface. Test each wire to bare copper wire. When tester lights up, that is Hot wire. The other wire goes to load.
Connect wires:
Hot wire goes to Black timer wire
Wire to load goes to Red timer wire
White wire connects to white wires that are twisted together
Bare copper wire connects to Green wire from timer
How to connect white wire to white wires that are twisted together.
a) Strip white timer wire so you have 1-1/2 " of bare wire. Stranded wire will wrap around other wires easily.
b) Remove wire nut. DO NOT UNTWIST wires.
c) Hold all whites together so bare copper lines up. Wrap stranded copper around the twisted wire.
d) Replace wire nut, or use larger wire nut. Twist real tight. Do not use tape. You can solder the connection.
e) When done, pull on white time wire to make sure it is held tight. Push whites back into box.
Sep 25, 2010 | UPM Programmable Wall Switch Timer
Will not scan. Says I do not have this option
Hi
I am just a helper
Your scanner maybe not be working because you not got the right driver software for it maybe or some thing gone wrong with your software.
So I have put a driver for your pcon my website for you to download and try, the driver is for your printer Hp officejet J5780 all-in-one so you can download it from this link. XP Driver
Click The Link = http://www.4all2sell.com/driver/Officejet-J5780-All-In-One-InkJet-Printer.exe
When you download save it to your desktop so you can find it, then all you have to do is double click on the icon to run the software and follow the instructions.
All the best: Pineworks
Jan 29, 2010 | HP Officejet J5780 All-In-One InkJet...
Need brake circuit diagram for 1991 chrysler new yorker
1991 Chrysler New Yorker Auto Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): Red and Pink
Starter Positive Wire (+): Yellow
Ignition Positive Wire (+): Dark Blue
Accessory Positive Wire (+): Black/Orange
Parking Light Positive Wire (+): Black/Yellow
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Positive Wire (+): Orange/White Or Orange/Violet
Power Door Lock Positive Wire Location: In Drivers Kick Panel
Power Door Unlock Positive Wire (+): Pink/Violet
Power Door Unlock Positive Wire Location: In Drivers Kick Panel
Door Trigger Negative Wire (-): Yellow
Door Trigger Negative Wire Location: In Drivers Kick Panel
Dome light Supervision Wire: Use Door Trigger (Requires Relay)
Dome light Supervision Wire Location: N/A
Trunk Release Positive Wire (+): Black/White (Requires Relay)
Trunk Release Positive Wire Location: At Trunk Release Switch
Horn Negative Wire (-): Black/Red
Horn Negative Wire Location: At Relay In Fuse box
Tachometer Wire Negative Wire (-): Black/Gray
Brake Light Positive Wire (+): White
Brake Light Positive Wire Location: At Switch above Brake Pedal
Factory Alarm Disarm Wire (-): Light Green/Orange
Factory Alarm Disarm Wire Location: In Drivers Kick Panel
Thank You for contacting Fixya.com
Aug 03, 2009 | 1991 Chrysler New Yorker
Can,t figure out how to wire it up to my 1995 jeep and would like to find out how to wire it up?
Dont know what model you have so here u go!
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
1995 Jeep Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Switched 12V+ Wire: Red/Gray
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (-): Blue/Pink
window.google_render_ad();
Jun 03, 2009 | Pioneer DEH-P2000 CD Player
Cannot connect my ipod touch
You need to press the [pcon] button while in the iPod mode of the TV. Then use the Touch to select the file you want to playback. It will playback on the TV. Ensure the iPod is set to output video to TV.
Jan 13, 2009 | JVC LT-42X579 42 in. LCD TV
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
