Question about Electrolux ICON Designer E30SO75ESS Oven
F23 err I was baking squash and added a pan of pan the I needed to brown top...so I put on broil. That is when the problem started.
  • Official Brand Answer
  • 4,342 Answers
Good Morning Edward - Typically error code E-21 indicates an issue with the preheat temperature not reaching within 30 minutes. This often occurs due to heat loss around the oven capacity. At this point, the convection heating element, convection heater thermal cutout, oven thermal sensor, and wiring connections may be faulty. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
Posted on May 13, 2013
Bake and broiler element come on when bake is selected. Why?
Understand that I am not a professional, so this answer is subject to revision by someone who is more knowledgeable.
Where I live now I'm on Natural Gas, but in the past I've had electric stove/ovens. Based on my best recall the situation you describe is NOT abnormal.
When in the Broil mode, the Bake element is NOT on, but the Broil element is on FULL-bore to provide that strong radiant heat required for the Broiling process, AND for the good browning /crusting of the product being Broiled!!!!!
On the other hand, when Baking, not broiling, IF the Broiling element were on high it would provide too much radiant heat to the top of the product being Baked, and would burn the top.
While Baking, by energizing the Broil element in a lower power setting, the Baking process is enhanced with more heat by the assistance of the Broiler element, BUT without the hazard of burning on the top!!!!!
Hope this is right and helps your understanding.
Jan 16, 2015 | Ovens
First start up
You're actually referring to the "broiler" elements. Most electric ovens have these at the top of the main oven space. (Some gas ovens are set up the same way, but many put the broiler elements in a bottom drawer.)
As their name implies, broiler elements are active only when you're broiling. They will not go on for baking.
Broiling is the process of cooking food by exposing it directly to a high heat source at close range. To broil a steak, for example, you would place the pan holding the steak on an oven rack raised to the top or next to top position in the oven (consult the manual) and set the oven to broil. The top elements will then turn on and cook the meat by direct radiation.
Most people, however, use ovens for baking far more often than for broiling. Baking is the process of cooking food (cakes, casseroles, roasts etc) by indirect heat. In other words you raise the oven to a certain temperature, put the food on a rack more in the middle of the oven, and let the surrounding heat cook it over time. When you bake the top broiler elements usually don't come on at all.
I hope this helps.
Apr 30, 2014 | KitchenAid Ovens
Instructions for a ignis electric oven as there is no temperature guide or modes on front of oven
I don't see what looks like your model anywhere, or a manual for any model, or a company website, so if no one can help you try this.
The left dial could be- bake, broil, fan, convection cook, now the bottom pan should come out so you can see the bake element.
Turn it one setting and see what happens, either broil (top),,, bake (bottom), convection fan (bottom), turn and wait to see what happens.
Right should be temp, not sure if the dial has a stop or you can spin, but it at 12:00, put at 6:00 I say this maybe 300deg F.
Get over temp gauge (cheap).
If you don't get any help, then you need to try and see what does what and mark it down.
If you can't see top burn, maybe top pan come out so you can see it.
They get red hot, so you can tell which one turn on.
Sorry, can't find any info.
Apr 01, 2013 | Ovens
Frigidaire oven fefl68 broil element comes on on broil only will not come on on bake or clean
Hello - - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Nov 17, 2012 | Ovens
How to bake pizza, how much time to keep
Do you have one of those microwaves with the built in broil and bake unit where you would pull the pan out from the top?! If so, I don't know! :o ....but based on my experience in making pizzas, I strongly recommend that you put it on for 5 minutes intervals at about 375 degrees (+/- 25 degrees) and check it until the cheese in the middle is melted. I would NOT recommend putting it directly in the microwave using infrared radiation bc pizza like that tastes really bad. In an oven, put the pizza on for about 15 minutes and check every 3-5 min after that.
May 05, 2012 | Ovens
My oven is not baking properly. The tops of banana bread and cinnamon rolls are browned and bottoms still soggy.
It's possible the lower bake element is not working. If the oven takes a long time to come up to temperature, that's a good indication that a baking element (bottom, broil element is on top) is bad.
Apr 27, 2011 | Whirlpool GBS307PR Electric Single Oven
What could be the problem when i put the oven on broil every thing is ok the top element come on ,but when i put it on bake only the bottom comes on
Hello, W/D here.
That's the way it is supposed to work. The top element comes on only for broil, but not for bake, and the bottom element comes on for bake, but not for broil.
Best regards, --W/D--
Feb 22, 2011 | Maytag Ovens
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
Frigidaire single oven broiling
hi,
The pan and it's grid is all you need, The broiler pan and it grid allow dripping grease to drain and be kept away from the high heat of the broiler. DO NOT use the pan without its grid. DO NOT cover the grid with foil. Some helpful info.. Preheating is suggested when searing rare steaks. Broil on side until the food is browned; turn and cook on the second side. Broiling times vary, so watch the food closely. Time not only depends on the distance from element, but on the thickness and aging of meat, fat content and doneness preferred. The first side usually requires a few minutes longer than second. BE SURE THE DOOR IS OPEN AN INCH OR TWO WHILE BROILING
Mar 21, 2008 | Frigidaire FEB24S2AB Single Oven
Broilers suddenly stopped working
gerrie824 look at the elements and see if there is cracks in them. If so then yes they failed. During bake the broil elements come on in 1/2 power to brown the top of what you are baking. If there isn't a break in the elements, then the issue could be a burnt wire, failed relay, or such.
Feb 02, 2008 | GE JKP45 Electric Double Oven
Electrolux ICON  Designer E30SO75ESS Oven Logo
213 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
