Question about Car Audio & Video
Hi, I have a JL Audio 500/1v2 amp hooked up to a w7 sub. My uncle who is a mechanic installed it. Since i have the stock head deck in my car still, the amp does get power from turning on my car. At first I just had to pop the truck and unplug the component cables from the amp, and plug them back in. And it worked great. Recently I blew a fuse. I got it replaced today and the amp gets power, but no sound. Can anyone solve this?
  • 113 Answers
SOURCE: Car amp's stopped working. Putting out a heart beat sound through subs but no bass.
could be low current ,disconnect all power including ground for 20min N.B most amps will seem to be shorted at output but this is normal due to damping ratio.
Posted on Aug 09, 2007
capesound
  • 4 Answers
SOURCE: fuse keeps blowing when sub volume is turned up
the amp draw rating on the amp is 100 you need to put a larger fuse in, such as a 150 amp, it would be a good idea to go to 0 ga but not needed. you might also want to upgrade your altenator.
Posted on Aug 22, 2007
GooFyTiS24
  • 33 Answers
SOURCE: i bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Posted on Aug 12, 2008
etirbynnor
  • 655 Answers
SOURCE: jl audio 1000/1 problems
Hello l_miller36,
Depending on how much you paid for the amp on eBay, and how well you like the JL product, it may very well be worth the money to get it fixed. As for the wallet damage, you'll have to ask JL or one of their dealers. But, since the Slash2's routinely sell for over $1,000, I'd estimate the cost to be pretty high.
First, I'd send an email to JL Audio tech support and see if they have a "flat-rate" repair option or if they can give you an estimate of the repair costs. My second option would be to talk to a local car audio shop that does component level repairs. In the first case, you'd get exact replacement parts and whatever warranty JL gives on repairs. Not so with the local option, but it would most likely be less expensive.
Hope this helps, good luck.
Posted on Jun 01, 2009
  • 13 Answers
SOURCE: no sound from subs
No sound is produced. ? The output disable mode is turned on. ? Refer to the instructions at ?Output Disable Mode? to turn the output disable mode off.
Posted on Jun 10, 2009
My 12w7 has like a springing sound inside it, what is it?
Blown voice coil,,,,it was connected to a JL AUDIO amp correct? w7`s can ONLY be powered by JL amps due to ohm load.Advice buy a better quality sub,w7 is over-rated
Feb 07, 2013 | Jl Audio 13W7 Car Subwoofer
I have a couple of questions regarding my jl 500/1. the first question: i just transferred my amp/subs (subs are JL W3s) to a new vehicle, and the place i had install it switched the "high/low"...
ok..well theres a lot of question in there, lemme take a shot at it.
the hi/low switch explained: the hi/low switch tells the amp what signal voltage is being delivered to the amp...hi-power (4-15volts) or low-power(micro-volts). Your aftermarket head unit had what are called pre-outs (or preAmp outs) meaning the source signal (your music) is not amplified before being delivered to the amplifier...sooo...your amplifier setting for your aftermarket radio would be 'low' to tell the amp that the music source being sent to it is low-voltage.
Typically a manufacturers radio will not have pre-outs, they will be amplified by the radios internal amp to anywhere from 4volts on up, and you need to tell your jl audio amp that the source music being supplied is 'hi' voltage.
soo...of course...if you are sending 10volts to the amplifier and tell it that your sending micro-volts (low setting) your amp will over-amplify the signal and thus the overwhelming bass you experienced.
May 14, 2011 | Jl Audio 500/1 Car Audio Amplifier
No sound
ok if u have a radio with sub controll make sure its on an make sure that you have the gain bassboost turned up an if it has a crossover switch make that its on
Jul 24, 2010 | Jl Audio 1000/1 Car Audio Amplifier
Installin car systems
you dont want to connect both of those amplifiers together. You could run them separately to separate subs or the jl to your sub and your alpine to your front speakers. But you dont ever want to mix and match amps to the same sub. Even if you had 2 jl500/1's you wouldnt want to just hook them up together. Because they both have to be putting out the exact same amount of power. Which no 2 amps are ever exactly the same. Some companies make bridges to properly connect 2 exact amps together. I Hooked up 2 JL 1000/1's to each voice coil on a 13.5 W7 and i smoked the sub. So i definitely dont reccommend doing it unless the amps are conneccted to separate things.
Apr 28, 2010 | Jl Audio 500/1 Car Audio Amplifier
JL audio w7 is not working but not blown
Possibly the voltage spike/surge destroyed your subs. I am surprised you didn't lose your amp as well.
Apr 18, 2010 | Jl Audio 12W7 Car Subwoofer
When I hook my JL W7 sub to my alpine mrd m1005 amp the sub is pushed out and stays that way
Hello christensen7,
It sounds like there's DC current on the amp output terminals. Disconnect the sub and test the output with a multimeter. If there's DC there, most likely the amp is shorted internally and needs repair.
Hope this helps.
Aug 17, 2009 | Alpine MRD-M1005 Car Audio Amplifier
You need to have the amp bench tested at a car audio shop. Sounds like a dead short in the amp. Try turning the crossover on the sub "off" and connect any other speaker to it. if you have the same outcome, your amp needs serviced. Post a comment with your results and if I can think of anything else you could try beyond that I will. Hope this helps
Aug 17, 2009 | Car Audio & Video
Jl audio 1000/1 problems
Hello l_miller36,
May 31, 2009 | Jl Audio 1000/1 Car Audio Amplifier
If I buy 2 12 inch jl audio w7 subs would it be better to get 1 or 2 jl audio 1000 watt amps
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Oct 30, 2008 | Jl Audio Car Audio & Video
I bought a 500/1 jl audio amp and also a w7 10 sub
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
