Just replaced my lamp on a 47 inch Samsung hlt4675sx and it try's to turn on. About 3 times then shuts off n all lights start blinking
    Top Expert:
  • Televison & ... Master
  • 75,169 Answers
You haven't mentioned here about did you reset the lamp time after lamp replacement. You must do it. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
Posted on May 09, 2013
Slinteriors
  • 8617 Answers
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Posted on Mar 26, 2008
SOURCE: Samsung HL-R5067W no picture or sound.
I have an HL-R5067W  no picture, no sound.. What is the solution
Posted on Mar 13, 2009
  • 304 Answers
SOURCE: samsung model # HLP5063WX/XAA 3 lights blinking
It can be the Lamp Ballast as well as the Color Wheel.
Posted on Jul 16, 2009
  • 556 Answers
SOURCE: Samsung HLR5067W replaced color wheel, LAMP light blinks
according to samsung this is indeed the problem.
Posted on Oct 20, 2009
Testimonial: "Excellent expert advice. Confirmed what I believed to be the problem and it was. Very knowledgable"
  • 336 Answers
SOURCE: my red light is blinking 3 times, the picture
Hi,It sounds like an issue with the board that powers the lamp it's called the ballast.The ballast has a sensor that it detects when lamp is not responding or if ballast is not able to provide enough power to light it up,that's when you get the lamp indicator.This is the most common failure .When you put a new bulb in sometimes the ballast is not able to power it since it uses more voltage that what it was providing to the old lamp.The ballast is something easy to replace and it's cheaper than the lamp.Have a bless one!
Posted on Apr 27, 2010
Testimonial: "Thank you so much, and God Bless you. Also how can I replace tha Ballast and where is it located. Thx."
Samsung hlt4675sx/xaa lamp ballast keeps going out
Hello Leeann,
Wow 3 ballasts is too many too quick. Did this solve you problem every time?
Have you checked the voltage going to the ballast? this might be a power supply issue. The power going into the ballast should be between 320V - 380V. Please do not try to measure the power going to the lamp! The ignition charge can be 15kV and it is dangerous to you and a multimeter.. please let me know and I will try to help you get to the bottom of this
Jan 06, 2014 | Samsung HLT4675SX/XAA OEM TV Lamp
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Have a 50 inch samsung projection tv model hlt5075sx/xaa lamp code bp9601653ap132w turn tv on lamp stays on for approx 20 seconds then 3 blinking lights on right bottom side start blinking if it is the...
The blinking lights will be flashing a code.....
Can you please indicate the sequence of the flashing lights, as this will determine what needs to be done to fix your fault.
Cheers,
Jun 16, 2011 | Samsung - Projection TV replacement lamp...
Our tv was shutting off within 10 min of turning it on. 3 lights would then start blinking. We replaced the lamp today and it is still turning off within 10 min of being turned on. We checked the door to...
If turning the lamp on fails, the set automatically tries turning the lamp on 3 times. If all attempts fail, all LED's on the front panel will blink. Check the lamp and the ballast and replace them, if necessary.
Check lamp fan too, make sure fan is rotate smoothly. Thanks.
Jan 24, 2011 | Samsung HL-S6187W 61 in. HDTV
Samsung HC
Replace the Power deflection board that should solve your problem. You can get a replacement board for your model at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/p59a-pwr-def-board/cName/samsung-parts
Apr 27, 2009 | Samsung HC-P4752W 47" Rear Projection...
No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Apr 22, 2009 | Televison & Video
Samsung projection tv
change lamp change fans
and replace color wheel.
make shure to remove jumper when replacing samsung color weel.
the jumper is black on the back panel of dmv modual.
jumper needs to be removed due to the new air cor motors thay are yousing, i had this same situation at one time.
Dec 16, 2008 | Samsung HLP6163W 61" Rear Projection...
Samsung 42 inch projection
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Feb 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
