Question about Fulltone Ruby GrabBee Deluxe USB 20 NTSC PAL Video Grabber for Capture Record Snapshot VHS to DVD Converter
Honestech tvr video recorder
Why can ntsc video tapes only play in b/w? pal tapes are fine but ntsc do not play in color.
  • Fulltone Master
  • 9,587 Answers
The Color subcarrier is different on pal. NTSC tapes , cameras, VCR's will all show B/W on a NTSC TV.
Posted on Jan 08, 2014
Picture rolls on playback
Try cleaning the heads, but it seems like the heads may be faulty, you might need to replace the vcr, they don't cost much these days, the repair might cost more than a new vcr these days.
heres a cheap headcleaner, look for one at local shops, wallmart bestbuy and so on
http://www.pcconnection.com/IPA/Shop/Product/Detail.htm?sku=7632166&oext=1038A&ci_src=14110944&ci_sku=7632166
Sep 24, 2008 | Panasonic PV-V4021 S-VHS VCR
Honestech tvr
Use a regular TV to see if the analog channel is still transmitting. Maybe it is only in digital now.
Sep 30, 2013 | ATI Tv Wonder VE Tv / Video Input Adapter...
Can I use Hi8/Digital8 NTSC tapes in my DCR_TRV250E?If so would I be able to playback recorded tapes on the UK televisions?.
DCR-TRV250E is a PAL version camera of the Digital8 format.
Yes you can use Hi8/Digital8 NTSC tapes. The camera will record a PAL digital picture on the tapes which means that you can play back the tapes in PAL and therefore you will be able to playback recorded tapes on UK televisions because they are also of the PAL format.
Oct 10, 2009 | Sony Handycam DCR-TRV250E Digital...
Sony Hi-8 plays new recorded video buy not playback
Are they PAL or NTSC tapes ? They may not be compatible with your new equipment.
Jun 13, 2017 | Sony Handycam CCD-TRV40 Camcorder
Converting NTSC home Video tapes to Pal DVD or NTSC DVD
You need either an NTSC DVD recorder (keep in mind that the US has 110 voltage, while Australia does not), or a computer card that supports NTSC. Some video capture cards support both NTSC and PAL (often switchable). Choose good quality, and pay attention to video/sound sync - some bad quality cards loose sync. Once the tapes are transferred to DVD - and keep it native NTSC all the way, they can be played on virtually any PAL DVD player/TV combo. With an NTSC source, it's best NOT to convert to PAL, while with a PAL source in the US, you'd need to convert to NTSC or only show the DVD on a computer (where NTSC/PAL doesn't matter).
Feb 19, 2009 | Panasonic DMR-ES35VS
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Pal to NTSC
Hi, Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions. You are quite correct "Plays NTSC tapes to NTSC, Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom. Hope this be of some help to you. Good luck and kind regards.
Aug 22, 2007 | Samsung SV5000W VHS VCR
NTSC to PAL
You have to buy first a VHS player that can play NTSC, might not be available locally in Ireland so you have to probably buy online (US). The DVD recorder is fairly comnon nowadays and all of them are capable of recording and playing NTSC and PAL. You can then connect the AV out of VHS player to the AV In of the recorder. Or you can use a VHS-DVD combi. You can google in UK, here is an example: Toshiba RD-XV45, according to the specs, it can play NTSC on the VHS and you can record to DVD on any format that yoou want You can go to this link to view other product: http://audiovisual.kelkoo.co.uk/b/a/sbs/100304323/16875665.html My father died of cancer 6 years ago and I am also transferring the Hi-8 videos to digital format using PC.
May 23, 2007 | Samsung SV5000W VHS VCR
VCR not working for some cassettes
What do you mean by "not able to play my VCR with some cassettes. " Is it that some tapes do not display images? No Video? From your name it seems that you are from India, Assuming that to be so, I also presume that you must be possesing a Multi-System VCR, to play back PAL Tapes from India, and NTSC tapes from the US. And if that is the case, I guess it is a simple problem of resetting the System standards. Please go to the Main menu of your VCR using the Remote, and select AUTO in System (You will be given choices of AUTO, PAL, NTSC 3.58, NTSC 4.43 and NTSC PB PAL. Likewise, it is entirely possible that your Television SYSTEm Standard has been accidentally changed. If it is Multi System TV, Then, again, using the Remote of the TV, select Menu, and then select AUTO in System. In all likelihood your problem should get solved.
May 13, 2007 | RCA VR605HF VHS VCR
Fulltone Ruby GrabBee Deluxe USB 20 NTSC PAL Video Grabber for Capture Record Snapshot VHS to DVD Converter Logo
158 people viewed this question
Top Fulltone Televison & Video Experts
Electro Med Services...
Are you a Fulltone Televison and Video Expert? Answer questions, earn points and help others
