Question about Car Audio & Video
P-con on wireing harness wha t does it mean - Car Audio & Video
    President:
  • 676 Answers
It what controls the amplifiers to turn on.
Posted on May 09, 2013
Which cord out of the harness is supposed to run to the remote wire on the subwoofer amplifier. The one labeled Remo.con, or the one labled Ant. ~Thanks in advance
i believe the remo.con, and it should be the blue/white if that color is there. the only difference when there is 2 remote wires is that the antenna power shuts off when switching to a cd or other source. e.g. cd player will have no audio if system is amplified.
Jan 30, 2011 | Kenwood DDX-512 Car DVD Player
Code set po335ckp senor.ck 3 pin con. corrosion both at pin con. and on sensor male pin in ckp sensor, replaced sensor clean pin con out with elect.cleaning solvent,check pin key on. three wire, yellow has...
insure timing belt is correctly installed and check cps trigger check continuity from cps sensor harness terminal 1 and pcm terminal A7 if all ok replace pcm with known good unit
Sep 21, 2010 | 2002 Honda Civic
Brake Light wont go out
The brake lights stay on even when the vehicle has been restored to the "before" condition?!? Now that's strange. I'm assuming the brake lights worked properly before you did anything with the trailer hookup. Is that correct? Do the brake lights work OK when a trailer is hooked up to the trailer lighting harness? Regardless, if the brake lights stay on all the time, there is a continuous 12V to the bulbs to ground. You have a wiring short somewhere in the vehicle. Have you checked the wiring for bare spots (caused by rubbing) or cuts in the wires.
Since the brake lights won't turn off, you have created a continuous path of 12V through the bulbs to ground, regardless of the brake switch operation. If you did not use the plug in type of wiring harness to attach the "trailer plug", then I would systematically undo each wire that you attached to and see what fixes the problem. I assume you know that the Blazer has a trailer connection plug-in location tucked up under the rear bumper. You simply unplug the mating harnesses, plug in the trailer wiring connector, plug in the disconnected harnesses and wha-la you should be good to go.
Hope helps.
Aug 18, 2010 | 1996 Chevrolet Blazer
V6 1994 ford mustang.engine wire harness
Sounds like you need to visit a salvage yard.
Jul 27, 2010 | 1994 Ford Mustang
Wiring Harness
I had some two conductor wire, which is used generally for alarms or for low voltage items, umm what i would recommend is you can use some of the two con for the Purple positive on your harness, but get something a bit thicker in gauge for the Yellow battery, use something more that would accutaly hold better power that you can use in terms of powering items, you should be able to get away with using something like that sorry if this isnt too much help, best bet is using alternative wires, otherwise try a Radio Shack they might have a Radio Harness or even bestbuy
May 07, 2007 | JVC KD-G210 CD Player
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
