Question about MagnaFlow 2003 Subaru Outback - 2.5L 4-cyl. engine, with federal emissions system - Catalytic Converters
Pcv valve location
Were is the pcv valve located at
  • MagnaFlow Master
  • 16,987 Answers
Look on the top of the valve covers.
Posted on May 19, 2013
Pcv location ford escape 2010 2.5 gas engine
The PCV valve is located under the intake manifold on the non-hybrid 2.5L engine. The intake manifold MUST be removed in order to service the PCV valve.
The PCV valve sits in the crankcase vent oil separator.
May 16, 2014 | 2004 Ford Taurus
Location of pcv valve on 1998 mercury mountaneer
the PCV valve is is typically located in the valve cover near the brake booster-4.0L pushrod V6. On a 5.0L V8 engines, the PCV valve is located at the back of the intake manifold.
Dec 12, 2009 | 1998 Mercury Mountaineer
Changing PCV valve
you pcv valve should be located on the top or around the intake on top of the engine. It is covered by a little pcv valve rubber hose...it is easy to identify because it is similar to a radiator hose but a lot smaller...no where near the size of a radiator hose...but when located, the pcv valve just pulls out and to check for it being bad, shake it and it should sound like something loose inside the pcv valve (thats a good pcv valve) but what they look like, they should be a silver looking color with a small little neck on it
Nov 21, 2009 | 1990 Buick Reatta
Front PCV Valve on chrysler town and country
PCV valve location-2.4L engine
PCV valve location-3.3L and 3.8L engines
Nov 13, 2009 | 1999 Chrysler Town & Country
Where is the pcv valve located on a 1999 ford explorer? Is there a picture?
PCV BasicsPCV stands for Positive Crankcase Ventilation.
All car engines have a PCV valve and it is located on top of the motor's valve cover. There is a vacuum line attached to it. It pulls out of the valve cover and if you shake it, you should hear a marble knocking inside it. If you shake it and don't hear anything, it's bad. It costs less than 5 bucks to replace.
Location
  • 4.0L is located in the valve cover near the brake booster
  • 5.0L is located behind the intake manifold (engine rear)
Oct 04, 2009 | 1999 Ford Explorer
Location of pcv valve on 03 ford focus
http://www.focushacks.com/images/pcv.jpg
Here's a picture to locate it..
So, when looking at the engine from above, on the right of the exhaust.
Procedure to replace it
1) Lift and support the front end of your car, or drive up on ramps
2) Get under the front of your car. The PCV Valve is located behind the exhaust manifold, a few inches below the valve cover.
3) Push up on the PCV valve to pop it out of the tube, or pull. You can get it out of the rubber tube with some effort.
4) Remove the rubber elbow from the top of the PCV valve. This can be re-used if it's not squishy. It can also be replaced cheaply.
5) Put the elbow on the new PCV Valve
6) Re-attach the elbow to the PCV tube
7) Push the new PCV valve back down into the large rubber tube
Sep 25, 2009 | 2003 Ford Focus
Pcv valve location on a 89 camry
There is not a PCV valve on the 4cyl. 6 cyl. is located under hood, center, upper engine area, mounted in rear valve cover Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 05, 2009 | 1989 Toyota Camry
Location of a pcv valve on a 2005 honda accord
The general location mentioned is correct. However, unlike most PCV valves there is no hose connection to the valve. There is a single bolt that attachs the PCV valve to the valve cover. Loosen the bolt, then remove the PCV valve from the valve cover. It is inserted inside the valve cover. Very different from most PCV valves as far as attachment method to the valve cover.
Apr 08, 2009 | 2005 Honda Accord
Pcv valve location
it is normally located on the valve cover itself look for the black tube going into the top of the valve cover gasket
Feb 04, 2009 | 1999 Ford Windstar
PCV Valve
The PCV valve is located directly under the fuel rail on the driver's side, right behind your valve cover. Should be very easy to spot if you know what it looks like and you're looking right in that location.
Hope this helps :)
May 17, 2008 | 1993 Honda Civic 4 Door
MagnaFlow 2003 Subaru Outback - 2.5L 4-cyl. engine, with federal emissions system - Catalytic Converters Logo
Top MagnaFlow Electronics - Others Experts
Fred Sops
gbob59
Lawrence Oravetz
Are you a MagnaFlow Electronics - Other Expert? Answer questions, earn points and help others
