Question about Zenith SY2768S TV
Zenith rear projection TV
Tv does not have a clear picture everything is dark.
  • 5 more comments
  • jazzo Aug 11, 2007
    This is a 1997 advance video imaging rear projection tv that has a very dark picture I have tried everything but nothing will lighten the picture.
    Ok that is good to know could you tell me where I could find another picture tube model # red color a-17649-02, blue a-17649-01 green a-17649. How expensive do you think they would be?
  • tondarburt Jul 06, 2008
    1996 zenith rear projection tv...... no picture , but good sound
    it went out all of a sudden
  • mikeruss1 Sep 17, 2008
    it shows picture but its a little dark and its red. does this mean i need color tube? And if so where can i get one?
  • julielyn64 Dec 08, 2008
    I just got this TV today and took the back off thinking cleaning the bulbs and the mirror would help and much to my surprise the mirror is broken and 2 bulbs of 3 are blown out.
    hmm..
    please help!
  • leyba Apr 01, 2009
    the picture is dark it shows no color. is the tubes the only problem or cold there be multiple causes
  • Anonymous Mar 24, 2014
    When I start my color TV,this time not clearly picture.So how to solve.
It's unual for all 3 crt's to go bad at same time, so have you tried turning up screen(G2) control? If so also there is a cap in the high voltage line that when replaced may lighten up set. Don't have model so I can't go further.
Posted on Aug 12, 2007
I have some dark shadow on the right side of the TV screen, I think it could be the lamp, is that true?
No,colors misalignment,shodows pictures and 3D pictures are not cause by the projection lamp.It cause by the tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.The shop will cost u $300-350 for the parts and labors.
Jul 07, 2010 | Zenith D52WLCD 52" Rear Projection...
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
Blurred picture and it's also dark rear projection zenith Z52Z95D
I'd get the lamp replaced for sure. If it has a ballast - change that at the same time. However, a Zenith repair center should be able to tell you whether it's worth doing or not.
Jan 05, 2009 | Zenith Z52Z95D TV
Dark picture
I removed the back from the tv and cleaned the lamps, mirror and inside of the screen with window cleaner. The image is now clear as the day I bought the tv.
Sep 22, 2008 | Televison & Video
Zenith z44sz80 Dark picture
i have same problem. i replaced lamp but picture is still dark.
Aug 22, 2008 | Toshiba 46H83 46" Rear Projection...
Lamp reset.
there are 2 clocks 1 for lamp and 1 for total, the total you cant change. dark picture, make sure your got same wattage lamp for replacement, I find original Philips lamps the best. if it continues follow manufacture instructions on cleaning mirror and lens.
Apr 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
Picture Fades
The more you play set the longer it will last, it sounds like you may have poor connections, cold solder joints try soldering around flyback transformer.
Apr 03, 2008 | Zenith R56W36 56" Rear Projection...
Zenith pv5263bt 53
If this is a projection TV, first you should check you lamp. Is it good (clear) or bad (foggy). If foggy, you should replace it. If it is good (clear) reseat it back onto the ballast (it just might be loose). If you are still having this problem, you probably need to replace the ballast
Mar 25, 2008 | Televison & Video
Zenith Blurry Picture
i got a zenith tv and the picture is really blurry how do i focus it ?
Feb 02, 2008 | Zenith R57W46 57" Rear Projection...
HDTV picture problems
Does the picture just get dark or does the picture go out completely? Does it do this with both the cable and the DVD? Is the audio affected?
Jan 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
180 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
